Full Euro Intelligent Light system via vediamo
Vediamo can do so many things, including bricking your car! You at your own risk, No responsibility is assumed
CGW231
2.VCD_02_global_variant_coding
Intelligente Fernlichtsteuerung "turn off"
Intelligente Fernlichtsteuerung Plus "Turn on"
perform Hard Reset
IGW212(NOTE: this is only for distronic PLUS equipped cars. module doesn't exist on others)
1 5.VCD_EVC_CfgBit_65_96
28 INTELLIGENT HEADLIGHT CONTROL PLUS (IHC+) "turn ON"
608 INTELLIGENT HEADLIGHT CONTROL "Turn OFF"
2 6.VCD_EVC_CfgList_01_0C
Headlamp Style 640 HEADLIGHT UNIT LED W DYNAMIC LIGHT SYSTEM SAE RHT change to "642 HEADLIGHT UNIT LED W DYNAMIC LIGHT SYSTEM ECE RHT"
perform Hard Reset
IC204
5. VCD_05_VariantenkodierungIntelligent Light System (ILS_Available) "Turn ON"
6.VCD_06_MenueaktivierungIntelligent Light System (Menu_ILS) "Turn ON"
perform Hard Reset
HLI-FL212 and HLI_FR212
3.VCD_Fahrzeugdatensatz_Allgemein Daten3 212M ILS SAE Change to "212M ILS ECE RV"
4.VCD_Fahrzeugdatensatz_Autobahnlicht Daten 4 nicht aktiv change to "aktiv Fzg mit ALA Hella"
5.VCD_Fahrzeugdatensatz_Erweitertes_Nebellicht Daten 5 nicht aktiv change to "aktiv Fzg mit ALA"
8.VCD_Fahrzeugdatensatz_IHC Daten 8 IHC aktiv Hella change to "IHC plus aktiv Hella"
9.VCD_Fahrzeugdatensatz_LDC Daten 9 212M ILS SAE change to "212M ILS ECE"
10.VCD_Fahrzeugdatensatz_LUC Daten 11 "?" --thats before) change to "212M ILS ece"
14.VCD_Schrittmotorparameter_ALA Daten 16 Hella VarioLED SAE change to "Hella VarioLED ECE"
16.VCD_Schrittmotorparameter_VLA Daten 18 "?" --thats before) change to "Aktorvariante Hella Haltestrom 1"
perform Hard Reset (I did soft function and hard physical)
SMPC212 OR MMPC212
Soft Reset on(whichever one you have)
ILS in action:
In the w212, the best way to describe it is the low beam is always on.
When following a car, the high beam splits on half with very define edges at the center, it never touches the car in front of you, you can see your low beam cut off line on their car.
When there is an opposite direction car, the high beam will dip just on the one side to not blind the oncoming driver.
There is also a fog light function, when you click it, the beam will aim more down and spread out.
Start by googling how to use vediamo, actually found two PDF files here on this forum. They're quite long but will help. You can also watch YouTube videos of all the Russian guys lol making changes on their car.
Second play with simulation mode, get a feel for it and practice what you're going to do.
Third, start by just downloading your current coding for these modules by connecting to the module, and hitting save to file. Then you can either print these, or just inspect them on your computer. This will also tell you the variant, so when you use vediamo and simulation mode, you know what variant to click.
Fourth, once you've come up with your plan, again practice it in the simulation mode.
Once you're brave enough to try it, work slow, so as to be careful you don't click the wrong button etc.
It took me about 10 tries to get it My current outcome.
I literally recorded the screen with my phone while I was doing coding. That way if I messed anything up, at least I could watch the video to see what happened. I have about an hour and a half a video lol.
Yah first step is I’m going to go through the diff ECUs you’ve highlighted and review the options I have vs the 212 and map em and try to see if I can find where the differences are. I’m going to probably do it through Monaco VS Vediamo. Should be the same just diff tool.
how much is that system for coding lol
also quick question slightly off topic, any idea if a difference language can be coded to the stereo? Anytime I have foreign music playing the characters show as squares lol
I'm one of the people that instead bought Vlad's module, and I can say that once you use the ILS you wonder how you survived before. Esp in two scenarios:
1. Following another car in a two lane road, it's amazing to see the light on the side of the road uninterrupted from your car all the way to the end of the car in front of yours' headlights.
2. Highway driving where the high beams light up the side of the road - great for spotting animals (reflective eyes)
https://www.ebay.com/itm/MERCEDES-w2...gAAOSwDyhgDp5R
My setup came from the user here named BenzNinja.
I'm fairly happy with the system.
If an indie shop is comfortable using vediamo, I'm sure they would.
In the mean time, i took some just ok cell phone vids. The problem is once it gets uploaded to YT, they compress it and you lose all the highbeam on the trees to the side on the video.... which is like 90% of the benefit we are looking for lol. Oh well, you can still see the "box" on the ground
Or if you for any reason ended in Lexington KY area ping me.
