Rear brake pads and rotors change
Old Aug 14, 2021 | 01:51 PM
Esparza45's Avatar
2016 E63s
Hey everyone, my parts to replace my rear pads and rotors came in and I will be doing the job myself along with my dad. If anyone has any useful resources such as videos or any tips I would appreciate it!
Thanks fellow AMG enthusiast!
Old Aug 14, 2021 | 03:16 PM
Valvestud's Avatar
2014 E63 AMGs, 2015 F-150 Lariat, 2010 Porsche C4S
MB Procedure below.
Regards,
Joe
Old Aug 14, 2021 | 08:36 PM
jvakos's Avatar
E63 SL55 996TT C5Z06
i posted this in the other thread below yours about same question but here you go....
FRONT ROTORS - BREMBO - $412 EACH
Mercedes AMG Brake Disc - Brembo 2194210212
C63 AMG, CLS63 AMG, CLS63 AMG S, E55 AMG, & more
2-piece Cross Drilled, Slotted, 360 x 36mm
https://www.fcpeuro.com/products/bra...mbo-2194210212
FRONT PADS - EBC RED STUFF - $140 EACH FOR BOTH FRONTS
Mercedes Brake Pad Set - EBC Redstuff DP31939C
EBC Redstuff. Not for vehicles with Carbon Ceramic front rotors (Option Code B07)
https://www.fcpeuro.com/products/mer...rakes-dp31939c
REAR ROTORS - ZIMMERMAN - $95 EACH
Mercedes AMG Brake Disc - Zimmermann 2124230412
C63 AMG, CLS63 AMG, CLS63 AMG S, E63 AMG, E63 AMG S
Cross Drilled/Vented, 360 x 26mm
https://www.fcpeuro.com/products/mer...mer-2124230412
REAR PADS - EBC RED STUFF - $190 EACH FOR BOTH FRONTS
2015 Mercedes-Benz E63 AMG S
Position: Rear, Not for vehicles with Ceramic Brake Rotors
https://www.fcpeuro.com/products/mer...stuff-dp32117c
BRAKE PAD SENSORS - $6 EACH (NEED 2 - ONE FRONT AND ONE REAR)
Mercedes Brake Pad Wear Sensor - Bowa 1715400617
C63 AMG, CL550, CL600, CL63 AMG, CL65 AMG, & more
https://www.fcpeuro.com/products/mer...or-1715400617b
Old Aug 17, 2021 | 11:37 PM
1SLO63's Avatar
E63S
HOW YOU LIKE THE REDS
Old Aug 25, 2021 | 10:18 AM
brucew444's Avatar
E 450
What did you install and do you like them?
Old Aug 25, 2021 | 10:33 AM
sunil517's Avatar
2014 E63s 1993 mazda rx7 on Boost
I jsut did rotors and pads all around.
Make sure you can remove the torx that hold the rotor on the hub before going forward. Everything else is simple. The front is simple just make sure you have all the correct tools Hex Torx 18mm box wrench for the rear caliper bolts.
I used a flat screw driver to push back my pads before I remove them and unbolt the caliper..
Old Aug 25, 2021 | 11:38 AM
Valvestud's Avatar
I used the Red. Good pads so far, but a nightmare to install. This was due to the improperly cast and finished groove for the wear sensor on the rear pad. I had to spend quite a bit of effort and time filing out the groove to accept the sensor. I emailed them to let them know of the frustration and received no response.
Regards,
Joe
Old Sep 30, 2022 | 05:11 PM
deanfuller2's Avatar
'14 E63 AMG
I see nothing about putting the e-parking brake in service mode. Is that not required in the '14?
Old Sep 30, 2022 | 05:42 PM
sunil517's Avatar
just mak sure eEB is not depress
We dont have electronic EB on our cars. We have the good old cable system.
Old Sep 30, 2022 | 06:17 PM
'14 E63 AMG
Thanks. That's what I suspected but couldn't confirm . . . .
Old Sep 30, 2022 | 11:45 PM
maxusa's Avatar
2013 E63 P30, 2010 GL550
There is plenty of feedback on EBC Redstuff in the forum. Search is your friend. Here are a few threads. The first link has DIY videos. The second talks about bedding in.
https://mbworld.org/forums/w212-amg/...rake-pads.html
https://mbworld.org/forums/w212-amg/...ey-should.html
Old Oct 3, 2022 | 10:02 AM
cotmfk's Avatar
On the shoulder
There is a company making CCBs for the stock steelie size and calipers. I'm wondering what the cost would be. Should be a huge weight savings. Blackmamba racing I think it is.
Has anyone purchased those?
Old Oct 3, 2022 | 01:48 PM
FastWgn's Avatar
2016 E63 Wagon
This may also be helpful to you:
Different pads
