Anybody have experience in O2 sensor reading
Old Sep 13, 2022 | 09:32 AM
Sltncls63's Avatar
Cls63 s-amg 2014
Anybody have experience in O2 sensor reading ?
Old Sep 14, 2022 | 08:21 PM
jvakos's Avatar
E63 SL55 996TT C5Z06
I would be interested in understanding this as well as I may have this camshaft sensor leaking oil issue, expand to my O2 sensor connectors
my Icaraoft diagnostic tool will read the O2 sensors but I don’t no exactly what I’m looking for with the data
Old Sep 16, 2022 | 11:35 AM
Sltncls63's Avatar
Cls63 s-amg 2014
I have same your problem
Old Oct 5, 2022 | 08:24 PM
xEryx's Avatar
2019 E63s AMG
A year or so ago I troubleshot an issue with one of my O2 sensors. The most notable thing about my troubleshooting was that the failed sensor had big voltage spikes as seen on your left O2 sensor. It should be more steady waves like the voltage on the right sensor. After replacing my faulty sensor, both looked almost identical on the live graph.
Old Jul 22, 2025 | 02:30 PM
dustinN's Avatar
09E350, 07E63, 13CLS63
I have read the causes of the O2 sensor error could be either the sensor is damaged or issue with the fuel injectors. Since i just replaced the 2 downstream sensors last year, its not likely that they went bad. The only thing left is the fuel injectors. Is it a big job? Have not found a video for M157. FCP has one for M156.
Old Jul 22, 2025 | 04:14 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Is it a big job?
Sometimes its beneficial to diagnose active issues prior to swapping expensive items.
What are your upstream lambdas reporting ??
Downstream O2 flag cats efficiency.
Old Jul 22, 2025 | 04:31 PM
dustinN's Avatar
I thought i posted the above on the other thread 😄.
Anyways, i dont have any error code other than P014A i have Foxwell scaner. How can I read the upstream lambdas? Thank you.
Old Jul 22, 2025 | 05:08 PM
Thank you.
I am not familiar with Foxwell menus
Lambdas are directly attached to ECU Module.
ECU Fuel trims may be listed under the OBDII menus.
Old Jul 24, 2025 | 11:02 AM
Siegmann's Avatar
10-second E550
Only the upstream sensors read Lambda. The oxygen sensors are downstream and report voltage.
What were the running conditions during the screenshot data? Idle? Was the engine fully warm?
Old Jul 24, 2025 | 11:14 AM
dustinN's Avatar
I have not had a chance to try it yet. Will take some pics when I do. Thanks.
Old Jul 26, 2025 | 10:06 AM
dustinN's Avatar
The car was idle and warm up to reach driving temperature. The lambdas readinds were winthin normal range. The same reading for downstream sensor.
Old Aug 11, 2025 | 02:47 PM
Plumber452's Avatar
I'm getting that same code when I accelerate hard in my 2012 E63 AMG. Did you ever get this resolved?
Old Aug 11, 2025 | 03:25 PM
dustinN's Avatar
The error code has gone right after I posted the photos of lampda reading.
Old Aug 11, 2025 | 04:46 PM
EXHAUST LAMBDA SENSORS
Upstream exhaust Lambda sensors get contaminated by engine burning thin oil during combustion
and by external contamination through burned up CPS "oil-in-harness" traveling down into sensors.
So new Bosch sensors may bring temporary relief. Replacement restores lost engine performance.
Old Aug 11, 2025 | 05:54 PM
Plumber452's Avatar
So, should I check the harness connections on bank Two? And possibly replace both O2 sensors on Bank two?
Old Aug 11, 2025 | 06:37 PM
Yes to checking your harness connection for oil.
Replace sensors in pairs, both banks at the same time. Engine needs to be given a chance to be balanced, the opposite of unbalanced.
Start with 2x upstream Lambdas only and check all connectors including downstream O2 while under the car.
