Vacuum Check Valve Repair
Old Aug 3, 2025 | 06:01 PM
  #126
Baltistyle's Avatar
'13 s212 63 p30. '06 LX470
Originally Posted by andrewwiencken
Has any one made custom move with the always failing check vale? I have a thought of putting an inline check valve inline on the top of the motor where the vacuum line starts making a straight run. The check valve is off a volvo however the check valve has zero relief in in one direction ,as the crappy little stock one has relief in both directions . So i am unsure if this is a good idea or if i need a different inline check valve with some relieve in both direction ? Any thoughts or feed back would be appreciated.
Its been done by members in this thread... Users have varying experiences in whether their valves of any type arrive working or not. The three valves I just purchased all only had one way flow as designed...
Old Feb 9, 2026 | 05:41 PM
  #127
SpizzleKicks's Avatar
C43
Ordered 2 from china (amazon) only 1 stops air in one direction
Waiting for a Ukrainian one in a couple days to check
Whats the screw size to remove?
Old Feb 9, 2026 | 08:02 PM
  #128
E63SAMG2014's Avatar
2014 E63 / 2017 CLS 63 / 2015 G63
Food for thought, why not just replace the whole shabang? If money wasn’t a factor.
Old Feb 9, 2026 | 08:13 PM
  #129
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
vacuum check valve
money can not fix this engineering failure setup.
Turbo boost forcing higher crankcase pressure blow up this tiny valve.
The positive pressure should be relieved before this vacuum valve is exposed to it.
Old Feb 10, 2026 | 01:35 AM
  #130
So have we found a reputable check valve? Not the chinese stuff.
if so,what is the link to it?
Old Feb 10, 2026 | 02:48 AM
  #131
C43
when the Ukrainian version comes i’ll do a comparison
Old Feb 10, 2026 | 07:42 AM
  #132
speedlaw's Avatar
C 43
I bought an ebay valve, it worked, I replaced it. Now that I know the signs of failure, when it goes again, I'll buy another one. Supposedly there is a Ford/Volvo valve too.
Old Feb 10, 2026 | 02:06 PM
  #133
What are the signs that the valve failed?
6 Father's Day Gift Ideas Your AMG Loving Dad Will Cherish
Old Feb 11, 2026 | 01:26 PM
  #134
san40's Avatar
2015 e63 wagon
oil in vacuum line leading to wastegate actuators (among other things), see https://mbworld.org/forums/w212-amg/...ml#post9188182
Old Mar 2, 2026 | 11:39 PM
  #135
Dean Chiu's Avatar
W212 E63 AMG
Originally Posted by S-Prihadi
I bought the Amazon one like 6 months ago, as back up, but never use it yet.
https://www.amazon.com/Vacuum-Repair...ct_top?ie=UTF8
It seems there is a slight difference between Ukaraine Klifex to the China Amazon.
Below :
# 1 = It seems the Klifex has plastic material at the middle of the star shaped opening, while the China one has none.
#2 = I seems the Klifex silicone membrane maybe a tiny tiny bit wider diameter than China one.
#3 = If I were to use the China one someday, I will power glue the black round membrane holder to the check valve body. The silicone membrane is thick enough to be robust, I believe so.
What I think can fail is the black round membrane holder which is only friction fit into check valve body, slipped out of its parking position and then hell broke loose.
If say the membrane dot lock get cut, that is another failure point. I mean the membrane sits and lock itself to the black round membrane holder is also a friction fit of a rather fat membrane
dot, as a lock....but this dot does not do much work actually.
I suggest try the power/crazy glue to secure the black round plastic membrane holder to valve body when you have the China one or even the Klifex one.
What about this valve? Image attached
Can it be found independently ?
Old Mar 2, 2026 | 11:40 PM
  #136
Dean Chiu's Avatar
W212 E63 AMG
Arrow
Hi guys, this this part/valve also be replaced ? What's the part number?
Old Mar 2, 2026 | 11:50 PM
  #137
Dean Chiu's Avatar
W212 E63 AMG
I guess it can be fluttered in low revs. Lost of boost. Oil leaks around vacuum pump or turbo actualators.
Slideshow: Six Father's Day gift ideas your AMG loving dad will cherish.
By | 2026-06-03 16:34:48
