Oil pump solenoids
Old Jan 14, 2025 | 11:05 PM
  #2526
JettaRed's Avatar
Veteran: Army
Can't believe I missed this, looks like I am missing out again, I am in, where do I sign up? Where about is this on an M276 TT? How should I unplug it?
The plug is on the back side of the alternator. It's be a single wire connector and may look something like this. I had to feel around blindly after locating it with a mirror.
Old Jan 15, 2025 | 10:45 AM
  #2527
JettaRed's Avatar
Veteran: Army
I'll post my observations of the alternator disconnect over on @CaliBenzDriver thread in the Tech Talk forum.
Old Jan 15, 2025 | 10:58 AM
  #2528
W205C43PFL's Avatar
Thanks so much forum member JettaRed as always : )
Old Jan 19, 2025 | 08:44 AM
  #2529
JettaRed's Avatar
Veteran: Army
Great price right now on Amazon...
Old Jan 19, 2025 | 09:05 AM
  #2530
BDC90's Avatar
2014 E63 AMG wagon 1965 Austin-Healey 3000 1970 AMC AMX
May not be SP rated.
Old Jan 19, 2025 | 09:43 AM
  #2531
JettaRed's Avatar
Veteran: Army
Of course it is! Why wouldn't you check? You don't have to use it, but for those that want a good 5W-50, that's a great price.
Old Jan 19, 2025 | 09:44 AM
  #2532
JettaRed's Avatar
Veteran: Army
Here's a link on Amazon.
https://a.co/d/arX9boI
Old Jan 19, 2025 | 09:45 AM
  #2533
BDC90's Avatar
Heh I must have pulled up the wrong one on amazon. So yeah good price. I love the Castrol old car mix for My Healey too.
Old Jan 19, 2025 | 09:48 AM
  #2534
JettaRed's Avatar
Veteran: Army
Good point. I shoulda put the link in the first post. Amazon is often whacky like that.
Old Jan 19, 2025 | 09:50 AM
  #2535
BDC90's Avatar
Plus I'm on My phone which doesn't seem to go the direction My desktop does sometimes. Lol
Old Jan 19, 2025 | 10:18 AM
  #2536
W205C43PFL's Avatar
https://cimg9.ibsrv.net/gimg/www.mbw...4882c213ba.png
Good price but it doesn't ship to Canada and the price is double on the .ca site, thanks for posting regardless, others can enjoy : )
Old Jan 19, 2025 | 11:35 AM
  #2537
JettaRed's Avatar
Veteran: Army
That is a bummer and totally irrational.
Old Jan 19, 2025 | 11:38 AM
  #2538
W205C43PFL's Avatar
Yup, oh well...
Old Jan 19, 2025 | 09:46 PM
  #2539
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
I had a Canada thing just last week (WAY WAY OT)...to fix a lithotripter in the US it is a $2500 repair. We ship to Canada it is $700...but, they can not legally ship it back....
Old Jan 19, 2025 | 10:09 PM
  #2540
JettaRed's Avatar
Veteran: Army
This is what my urologist uses... Breaks those kidney stones up real good.
Old Jan 20, 2025 | 09:48 AM
  #2541
Manny_c450's Avatar
C450
How long have you had this oil in the car now? Did you do it to both the NA C350 and SL400? How is performance so far on this oil. You have had it for a while now..
Old Jan 20, 2025 | 01:31 PM
  #2542
JettaRed's Avatar
Veteran: Army
I don't put a lot of miles on the cars, but I've had it in the cars for about 2 months now and probably 1500-2000 miles. It's been absolutely fine. The cars seem to like it. They start quickly and idle smoothly. I went from a 5W-40 to 5W-50 (both API SP), and my oil temps range from 199°F to 208°F when operating at full operating temps. Both oils were high quality full synthetic API SP rated, so I can't say there was any extreme changes. (NOTE: The Castrol 5W-50 is not MB 229.5 approved.)
The only thing I haven't done is to measure the oil pressure to see if there is any difference. Otherwise, it's fine.
Old Jan 20, 2025 | 01:59 PM
  #2543
W205C43PFL's Avatar
Great stuff and to be fair rarely (if any?) 50 weight is MB 229.5 approved, I guess too thick for the fuel economy and regulations MB is aiming for.
Old Jan 20, 2025 | 03:28 PM
  #2544
Manny_c450's Avatar
C450
Curious.. Did you also look into mobil 5w50?
Old Jan 20, 2025 | 03:58 PM
  #2545
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
ALT-LIN helps MOD-4....
ALT-LIN and MOD may well be having synergistic interaction!!!
-- Variable pump pressure is used to detune the hydraulic VVT-Gear positioning.
-- We know oil pressure is affected by viscosity.
-- Running W50 affords effective protection against viscosity loss to operate VVT electromagnetic solenoids.
Engine adaptation to ALT-LIN so far seems to help bring the unstable engine temperatures under control (FAN OFF!!).
Meaning ALT-LIN could be proven help protect against viscosity loss.
This is still fresh... lets see how adaptations journey goes in relation to "normal" engine temps and fan staying off... Two birds one stone?​​​​​​
Old Jan 20, 2025 | 04:20 PM
  #2546
I keep avoiding this thread as I STILL do not have my new felt shield in my car from the hoses thing...once that is done I have a TON of catchup to do.
Old Jan 20, 2025 | 05:19 PM
  #2547
W205C43PFL's Avatar
Heat is what kills parts, having less heat is the important part of this mod.
Unless.... you sleep in your garage and complain the garage is too cold jk...
Old Jan 20, 2025 | 05:45 PM
  #2548
KristiyanPetrov's Avatar
C43 AMG '17 / Stage II
our engines for sure have a lot of heat even now in the winter my fan is switching on, so next oil change probably would be from 5/40 to 5/50
Old Jan 20, 2025 | 05:49 PM
  #2549
Fix your most important items first
Old Jan 20, 2025 | 06:02 PM
  #2550
KILLER HEAT ... be gone!?
You know something has got to be wrong when your fan runs in winter on a stock Mercedes-Benz.
This means stock engine makes a ton of heat more than oversized radiator can remove.
Any positive factor to help is good, right?
What if you could experiment with :
  1. cancel extreme heat FAN:ON > NO-FAN!
  2. cancel high pressure heatsoaks
  3. cancel laggy throttle
  4. improve gas mileage
  5. reduce frictions wear
  6. limit tranny clutch sludge
  7. ....
Thanks to MBWorld contributors and experimenters
Video is interesting to watch once you understand this managed struggle. Hear the words solenoids, coils, heat...
Keyword: disaster.... 0W8 : LOL
-- next will be No1 Toyota: giant cost!!?
-- Daimler-Benz true leader has immunity.
You have already rated this thread Rating: Thread Rating: 14 votes, 4.29 average.
