Oil pump solenoids
Old Dec 15, 2023 | 09:28 PM
  #251
Mojo20032004's Avatar
2014 E63S
Has anyone accessed this from above on the w212? If so - how did you do it (saw someone above with a 2013 do this from above ...)
Unless u got small hands, I wouldn't recommend it. Oil lines and other plastic fittings upfront that can easily break if not careful. Underneath its 10min job honestly.
Old Dec 15, 2023 | 09:32 PM
  #252
PeterUbers's Avatar
Originally Posted by Mojo20032004
Unless u got small hands, I wouldn't recommend it. Oil lines and other place fittings upfront that can easily break if not careful. Underneath its 10min job honestly.
what's in the way of accessing it from underneath when the car is on ramps?
Old Dec 15, 2023 | 09:36 PM
  #253
2014 E63S
Front plastic belly pan cover comes off, reach through radiator hoses and unplug the sensor. Ziptie the sensor to the rubber hoses away from the belts.
If you look closely you can see the black ziptie where I ziptied the sensor away from the belt when unplugged. I circled it in red.
Old Dec 15, 2023 | 09:46 PM
  #254
Baltistyle's Avatar
'13 s212 63 p30. '06 LX470
Yes Peter, I did it. its super tight and I dont have large hands but did not remove anything but the beauty cover over the oil cap. However, you will not be able to zip tie it or protect it. I will be going under this weekend to protect it since I saw no issue so far. I faced the car and used my left hand on the passenger side of the plastic coolant line that connects to the engine block. The pick going in that way needs to be tiny. My fingernails could not do it at the odd angle.. Honestly, you are more than competent but for the struggle, just take off the eight bolts underneath. It took me twenty minutes but I still have to go under, though more to clean and track if this solenoid is leaking and will be replaced under warranty.
Old Dec 15, 2023 | 09:52 PM
  #255
Baltistyle's Avatar
@BDC90 mentioned "I had an extra camshaft magnet sacrificial harness on hand. I cut the wires , taped it up to look like it was normal and plugged it in the solenoid and the harness. Same plug as oil solenoid."
Very early in the thread.
Until now I did not mind this connection to stay opened.
​​​​​​Are you saying this connectors matches the CPS Pigtails?
I have a few left overs V6/8 difference
spare eBay goodies
  • Pull wiring out of pigtail cord
  • silicone the unused holes
  • use M/F connectors as plugs
  • Zip tie down harness side
Old Dec 15, 2023 | 10:05 PM
  #256
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
PIGTAILS....
Originally Posted by Baltistyle
Same exact mech as a cps. Slide up/ out the white part (not shown on this pic) and then squeeze white tab and tilt slightly away from white side and pull directly off. I did mine from the top side using a small s hook like a pic. From below will be much easier and will allow inspection as needed.
ok, it is not a 3-wires CPS pigtail
but the 2-wires timing gear solenoid that everone calls "magnet" short for electro-magnetic solenoid.
That pigtail I don't have and now with normal lubing VVT "Magnets" likely will never get toasted.
Useless pump solenoid going to remain unplugged as-is.
Old Dec 15, 2023 | 10:42 PM
  #257
BDC90's Avatar
2014 E63 AMG wagon 1965 Austin-Healey 3000 1970 AMC AMX
So drove the car 300 miles today to visit Mom. Left in the morning with an outside air temp of 34 F. Garage temp 50 F . Oil temp went blue to white in 15 mins. That's quicker than before the unplug for Me.
Old Dec 15, 2023 | 11:44 PM
  #258
ImolaSix's Avatar
2014 E63s AMG
Originally Posted by kenneyd
I posted my review of it this morning.
I'm happy with it, I think it's most noticeable for me, cruising at 60 in sport mode, and flooring it. It just seems to come on so much more instant than while I was much of a softer gain of power before
I hope I covered everything in this post, I gave credit to the engineers, Cali and s-paradi. thanks guys
https://youtu.be/MuZJSGN8qZ4
Very informative video and a great job at summarizing everything discussed in this thread. I would like to know more about your setup for a mechanical oil pressure gauge. Did you use the fitting on the bottom of the oil filter housing?
Old Dec 16, 2023 | 12:34 AM
  #259
jvakos's Avatar
E63 SL55 996TT C5Z06
So appreciate the research and testing done here on this oil pump mod which is quite interesting.
quick question - what happens if you unplug it for a period of weeks and then plug it back in? I thought I read the thread that there could be issues if you do that or is that not correct?
thanks a bunch
Old Dec 16, 2023 | 02:06 AM
  #260
ONE WAY FORWARD ....
thanks a bunch
That is correct. Did you see the very first post where a brand new engine blew up when the valve got jammed open?
I don't whish that on anyone.
Some solenoid valves are not screened. If the valve has not circulated oil for a while there a chance for piston particulate (carbon or aluminum) to have accumulated in the solenoid gallery ready to get forced in.
That valve is nothing but trouble.
If you suspect your engine has accumulated forbidden glitter then clean the oil pan for peace of mind. Carefully change the pick up tube O-Ring.
Instead of using a fancy dual-rate pump the design team could have limited the pressure using PWModulation to dump part of the normal output. No need for fancy pump.
Right now all we have is 2Bar switched over to 4Bars above 3500.Rpm, after start up and couple shots some times based on load calculations...
Performance suck below 2000.Rpm when VVT Gears are locked by low pressure.
Old Dec 16, 2023 | 09:29 AM
  #261
kenneyd's Avatar
poop
very temporary, very ghetto lol. It like behind the belt and close to the fan, I just wanted to verify it had oil pressure.
It's a 6mm plug, so you need 6mm Allen socket, a swivel head 3“ extension. Then some creative zip tires to get it out of there belt and fan, I just ran the line back to the engine door and hand held the gauge
I suppose if you have a 90° brass connector, you could probably permanently install one, but it was too sharp of a bend and mine was only straight out with like 2 thread size adapters.
So, cuz of access I can do barely more than hand tight
Old Dec 16, 2023 | 09:34 AM
  #262
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
just removed mine from the E350 from above. I used a mirror to get my bearings.
Then, used a short flat screwdriver to push out the grey tab. Garage was quiet, so I heard the click clearly. Wiggled the connector a bit and back pushing it out softly and it just slides out.
I bent the harness on itself and zip tied next to the ziptie that is already there. Cut to length
Checked with Xentry, the code is now there. Warmed it up. Quieter at the start, and pedal feels more like S than E mode. Need to go out, and give it something throttle
Old Dec 16, 2023 | 10:35 AM
  #263
kevm14's Avatar
04 E55 AMG (totaled), 07 S550 4Matic, 14 E63S
thanks a bunch
It seems risky. An approach could be to rig up a test harness to apply 12V and ground directly, and cycle it a few dozen times. Assuming you can hear it click through the timing cover, crisp clicking would seem to indicate the plunger is not seized. Not definitive proof but at least the seized one Tasos showed was totally seized and not clicking at all.
Old Dec 16, 2023 | 12:10 PM
  #264
Baltistyle's Avatar
changed my statement, was really meaning the way the mech works is the same.
Old Dec 16, 2023 | 02:35 PM
  #265
PoonFlavordTang's Avatar
gle63s
put my GLE63s on the lift last night after reading this thread top to bottom. Watched @kennyd 's video. I pulled the plug and zip tied it to some coolant hose. I don't have xentry so I can't see the invisi-code, but no CEL's for me. I don't have much to contribute to discussion. I did take these videos though.
Pre disabling
Post disabling
Old Dec 16, 2023 | 03:08 PM
  #266
BDC90's Avatar
So during My Friday 3XX mile run to Mom's , 80% highway so below 3000 rpm I didn't see any measureable change in MPG. Too close to normal even considering OAT , traffic, wind etc.
Old Dec 16, 2023 | 03:13 PM
  #267
Baltistyle's Avatar
So everyone, who’s going to manufacture a block off plate? Can this unit be replaced “while in there” with a plug that will also prevent further leaking. Any negative to the thought?
Old Dec 16, 2023 | 03:34 PM
  #268
jvakos's Avatar
Originally Posted by TomZVB
Yep… whoops. I watched the video but didn’t get to that part… got interrupted.
Might be easier to go from underneath.
One thing I noticed when putting my hand down there, there’s definitely signs of oil leaks. I know that the timing cover has been done, etc. Guess I have some cleaning to do.
do you have the leaks on the passenger side? I am sorting this out myself. I see some oil on my alternator and the drip pan and under the pan where the oil level sensor sits.
This started about a year ago and still just very minor drop. my timing covers and seals are original at 51,000 miles on a 2015 e63s
Old Dec 16, 2023 | 04:21 PM
  #269
ONE LEAK AFTER ANOTHER OR ZERO...
These engines are built to be greasy with undersized seals.... NO Problem, it's only cosmetic unless it gets into the harness and alternator.
As soon as you seal one leak, you'll get another one and another one as replacement, until rear main gets activated.
Leaks only witness the high crankcase pressure of piston blowby and vaporized oil. Fix that then done!
With pump mod, as soon as crankcase pressure improves (~ 1000Mi) the oil leaking will quiet down and the brake booster vacuum will be noticeably improved by reduced vacuum pump intake pressure.
> 2¢... I think the collection of plastic TT cooling pipes are much greater concern. A perfect winter project in the North-East.
Old Dec 16, 2023 | 04:30 PM
  #270
JUMPED RIGHT IN...
Pre disabling
https://youtu.be/e_LeD8ccDXw
Post disabling
https://youtu.be/B56Z0BdnlBo
Your beast sounds deeper now
Give it time to improve your mixture below 2500RPM.
Right now most of what's improved right away is limp tensioners + VVT Gears working.
PATIENCE: The mixture has mot been relearned - This is when you'll go: WOW OMG!!!
It will get there little by little as lambda clean up and blown-by ring get sealed under MAP watchful control.
Old Dec 16, 2023 | 06:49 PM
  #271
CZ 75's Avatar
E63 AMG
Just did this mod. Watched Kenny’s video. Once I put the car up on ramps, it took about 10 minutes from removal of splash pan to unplugging the sensor. Used a right angle pick to pull the clip up, then my hands to pull the harness off. No oil present on the harness.
Old Dec 16, 2023 | 07:58 PM
  #272
PeterUbers's Avatar
In the stock format with a functional oil solenoid. - Is there increased oil pressure for a cold engine start? If so - for how long?
Old Dec 16, 2023 | 09:12 PM
  #273
san40's Avatar
2015 e63 wagon
Is there a way to see oil pressure (or a proxy) in xentry? Would be nice to see pressures before/after and confirm solenoid is not "stuck" as in Tasos' video
Old Dec 16, 2023 | 10:14 PM
  #274
BDC90's Avatar
My guess is it's tied to the ECO function so until warm enough for the ECO stop start the solenoid isn't activated.
Old Dec 16, 2023 | 11:57 PM
  #275
JettaRed's Avatar
Veteran: Army
No, because there is no oil pressure sensor. Even in the WIS, you are instructed to attach a temporary external oil pressure gauge to measure oil pressure at different RPMs.
You have already rated this thread Rating: Thread Rating: 14 votes, 4.29 average.
