Oil pump solenoids
Old Apr 6, 2025 | 07:20 PM
  #3351
JettaRed's Avatar
Veteran: Army
Originally Posted by KristiyanPetrov
what filter you using or you stick with OE?
Purflux is the OE. The bottom picture is the Mercedes Genuine filter. They are the same.
Old Apr 6, 2025 | 07:23 PM
  #3352
JettaRed's Avatar
Veteran: Army
The Purflux filter is $11.39 and the Mercedes is $29.59. Purflux is less than half the price.
Old Apr 7, 2025 | 05:11 AM
  #3353
kevm14's Avatar
04 E55 AMG (totaled), 07 S550 4Matic, 14 E63S
That's an M276 filter. Different than 278/157...
Old Apr 7, 2025 | 08:36 AM
  #3354
KristiyanPetrov's Avatar
C43 AMG '17 / Stage II
im using OE but since its the same as Purflux i will take it, thanks for feedback JR
Old Apr 7, 2025 | 08:59 AM
  #3355
JettaRed's Avatar
Veteran: Army
Correct. The point was to use Genuine (and pay for the Mercedes logo) or the exact same OE part. I would not use Fram or even Purolator for my Mercedes.
For folks unfamiliar with the terms Genuine, OE, OEM, and Aftermarket, here's a good tutorial:
https://www.fcpeuro.com/page/oe-academy
Old Apr 7, 2025 | 09:21 AM
  #3356
thanks for the link i wasn't aware of those terms.. so to rephrase myself i use Genuine parts
in the meantime i thought that genuine parts might be with better quality than the producer (OE ones)
Old Apr 7, 2025 | 09:39 AM
  #3357
W205C43PFL's Avatar
what about x clean gen ii as Cali recommend?
Isn't x-clean a diesel oil though? Plus x-clean sounds like an oil designed for emissions and fuel economy.
Old Apr 7, 2025 | 09:42 AM
  #3358
W205C43PFL's Avatar
I don't think I would ever use an engine flush on a modern engine, especially one with a turbo. I believe flushes thin out the oil and to me that is too risky for a turbine spinning at 30,000 to 50,000 rpm at idle. Years ago, a mechanic told me that adding a quart of transmission fluid before a change was just as good as a flush. Regardless, I still would not do it. When changing every 3000 to 5000 miles, there should not be a problem with sludge. Use a good filter (no, I do not agree with the cheapest filter you can find at Walmart) and change the fluid often and you should have no problems.
I don't hear about flushes for a while as well.
Old Apr 7, 2025 | 09:43 AM
  #3359
W205C43PFL's Avatar
Great video! Thanks for sharing : )
Old Apr 7, 2025 | 11:27 AM
  #3360
JettaRed's Avatar
Veteran: Army
There are those that use OE, OEM, and Genuine interchageably. South Main Auto on YouTube will say Genuine parts and OE manufactured parts are not the same when it comes to parts like O2 sensors. From the FCP tutorial, however, OE parts are the EXACT same as Genuine with the logo removed, where OEM is a part made by an OE manufacturer, but not the part used by the car company. It's a bit confusing because, for example, Lemforder will appear as OE for some parts and OEM for others. The hope is the quality is not different between the manufacturing process used for both. Aftermarket is like the step-child to the family of other classifications -- not necessarily inferior, but no shared DNA.
When looking to replace a part, I consider the price and criticality of the component. For things that are difficult to replace, such as engine mounts, the extra dollars are worth the expense of replacing a prematurely failed part. For others things, like the oil filter, the price difference does not justify the risk of using a non-Genuine part, since they are the same. Then, there is always the decision to pay 2 to 3 times the price for an expensive part just to use Genuine. For example, the HPFP for my SL400 is pretty easy to get to because of all the space in the engine bay. So, I will go with the Bosch OE pump for the price of the Mercedes Genuine pump.
Old Apr 7, 2025 | 11:34 AM
  #3361
JettaRed's Avatar
Veteran: Army
The other thing I consider is who I am buying from. FCP with its forever warranty guarantee assures me that they are not going to sell crap because they are on the hook to replace it if it fails. Other retailers offer similar assurances, so it is always good to compare. If there is consensous amoung the more popular retailers (FCP, Pelican Parts, AutohausAZ, ECS Tuning, UroTuning, EEuroparts, etc.) on a single brand, that is also an indication that the part is good.
Old Apr 8, 2025 | 02:45 AM
  #3362
vdubpower's Avatar
i drive them all, fast and hard
our 2015 s550 uses this filter whereas the e63 uses the one with out the plastic poker
Old Apr 8, 2025 | 05:33 AM
  #3363
i did not check tbh but look what Cali mentioned about Xclean it can be used for cleaning engine
Old Apr 8, 2025 | 05:52 AM
  #3364
Sargy's Avatar
I'm using it in my diesel because of the low ash count.
Old Apr 8, 2025 | 09:59 AM
  #3365
W205C43PFL's Avatar
I mean, I appreciate the recommendation from him although I would probably stick with motul xcess gen 2 since it works for me, I thought of going to 5W-50 before but he also cautioned me against it especially if I drive high RPMs often.
Old Apr 8, 2025 | 10:00 AM
  #3366
W205C43PFL's Avatar
Do you mind ELI5 to me on what does that do?
Old Apr 8, 2025 | 10:06 AM
  #3367
Sargy's Avatar
Sure. Hope this helps
Old Apr 8, 2025 | 10:10 AM
  #3368
Sargy's Avatar
Double post accident. disregard
Old Apr 8, 2025 | 10:50 AM
  #3369
W205C43PFL's Avatar
Sorry I mean your take on it, not through the internet or AI, Thanks! Otherwise I could had searched myself : )
Old Apr 8, 2025 | 11:43 AM
  #3370
since you're using SN i don't think is bad idea if you find x clean SP to make one/two cycles and then move to 5 40 power SP instead using xcess gen 2 SN
Old Apr 8, 2025 | 12:53 PM
  #3371
W205C43PFL's Avatar
I see, let me take a look.
Old Apr 10, 2025 | 07:53 AM
  #3372
W205C43PFL's Avatar
not sure if this video was shared before but he talked about different dipsticks for the M156
Old Apr 10, 2025 | 09:03 AM
  #3373
QuadTurboPrius's Avatar
W212 E63 S AMG
not sure if this video was shared before but he talked about different dipsticks for the M157
Of course there are different types... some of us are engineers, some are doctors, some are just hooligans... it takes all kinds
Old Apr 10, 2025 | 09:04 AM
  #3374
W205C43PFL's Avatar
Different engine dipsticks for different folks, love it!
Old Apr 10, 2025 | 09:05 AM
  #3375
W205C43PFL's Avatar
not sure if this video was shared before but he talked about different dipsticks for the M156 https://youtu.be/tNKoSMr8vIc
Oops I meant M156 sorry for the typo, already corrected in original post quoted. Thank goodness the edit function seems to be working this AM.
You have already rated this thread Rating: Thread Rating: 14 votes, 4.29 average.
