Oil pump solenoids
Old Dec 30, 2025 | 11:29 AM
  #4276
Skbrod's Avatar
2011 Mercedes E550 Cabriolet Sport, 2019 GLE400 4MATIC
Gentleman , I’ve read this whole thread and I’m not sure it covers my issue lol. I have a CEL on my car and it’s giving the P06DA code. How do I know it’s in high stage 2 oil mode and not the lower one? Test the oil pressure? Then if in high …disconnect and replace with dummy solenoid? This will delete the CEL? I start the car just fine I think , I hear the hemi tick a little bit but not too crazy(prolly bc I mixed 5w-40!and 5w-30 just a couple quarts ) …for reference I have the M276 engine and a 2019 gle400. Any advice would be greatly appreciated
Old Dec 30, 2025 | 11:39 AM
  #4277
KristiyanPetrov's Avatar
C43 AMG '17 / Stage II
Easiest way to understand if its in normal (high) pressure if you notice quick warmer temps on engine oil/water
Old Dec 30, 2025 | 11:43 AM
  #4278
Skbrod's Avatar
so my radiator is cracked too so it takes a while for the heat to come to working temp on the car. I have to drive it 15 min about to get up to working temp. If I sit idle my gauge starts losing heat , not sure if I can tell about the oil heat or water
Old Dec 30, 2025 | 11:56 AM
  #4279
Skbrod's Avatar
they’re quoting me 5500 to replace the solenoid and 1800 for the new radiator replacement ..I’d rather just unplug it and repair the radiator if possible lol otherwise I have to junk the car I think
Old Dec 30, 2025 | 12:03 PM
  #4280
aghh so then other way is to follow JettaRed way of measure the oil pressure to be sure its in normal pressure
5.5k ugh.. better visit another garage indy if possible this is ridiculous price quote, also for radiator price is too high quote...
Old Dec 30, 2025 | 12:13 PM
  #4281
Skbrod's Avatar
thank you for explaining, damn yeah this is a Mercedes Benz dealer in south jersey. I will see if maybe I can find a shop around here that’s cheaper , but I will test the oil pressure atleast. Wish I studied being a mechanic and not engineering lol I’d rather pay for guidance and I’ll do it myself ..labor is ridiculous haha …so can I drive it like this with the CEL on? I didn’t notice any real difference in driving but I didn’t drive it long. It idles fine and when I rev it sounds fine but idk …if it is in low pressure mode I have no choice but to fix it correct ?
Old Dec 30, 2025 | 12:17 PM
  #4282
GTIBlack's Avatar
Mercedes SL R231
The only true way to know is to physically measure the oil pressure. I think JettaRed posted a video on how to do this a while back. There are also instructions in WIS how to do this. Anything else is only a best guess. I would not trust how quickly the oil heats up since the oil temperature is calculated and not measured. There is no oil temperature sensor on the M276. Plus, there are a number of factors that determine how quickly the oil reaches operating temperature and it seems to vary a lot among those of us paying attention.
On a side note, I am not a big fan of mixing viscosities more than necessary when changing oil and switching viscosities. If you are going to mix (for whatever reason) it’s best to stay with the same brand and formula group.
Old Dec 30, 2025 | 12:26 PM
  #4283
Skbrod's Avatar
so dicey thing about adding 5w-40 was because when I pulled the dipstick out it was dry then when I put it back in and checked it was at min..so I didn’t know what they added so I guessed 5w40 until I called them and they said they changed it with 5w30 …idk if those 2 quarts I added was bad but I then checked the dipstick and it was at max ..some of the time though I’m pulling a dry dipstick the first time …is this normal?? Lmao I don’t think it is right? I mean I know it’s under vacuum but idk
Old Dec 30, 2025 | 12:39 PM
  #4284
BDC90's Avatar
2014 E63 AMG wagon 1965 Austin-Healey 3000 1970 AMC AMX
Better find an indy shop. Did You get a PPI? when You bought the car, maybe there is some info in the report?
Old Dec 30, 2025 | 12:43 PM
  #4285
Skbrod's Avatar
Yeah I’ll search for one, and sadly I did not. I won’t buy another car until I get a PPI from now on. I bought it preowned at a Volvo dealer ..prolly should’ve raised some flags but I was 4 years younger and dumber 😂
Old Dec 30, 2025 | 12:46 PM
  #4286
BDC90's Avatar
Go to an MB dealer with proof of ownership and they should give You any service history they have. I got Mine from an MB dealer in Ohio for a Canadian market car.
Old Dec 30, 2025 | 12:49 PM
  #4287
If solenoid is in position to have low pressure thats not good at all and you shouldn't drive the car
my assumption for getting operating temperatures from cold start quicker when solenoid is unplugged is because the same way i drive from cold start on winter and i noticed there's much quicker in reaching opereting temps than plugged solenoid despite the calculation of temps as I make comparisons with the same conditions
first time when you pull the dipstic always shows empty don't worry, you should put it back and only then you will know how much oil have, and better stick with 5w40 or 0w40, dont rely too much on garage to decide what oil to put
Old Dec 30, 2025 | 12:57 PM
  #4288
Skbrod's Avatar
thanks that’s good to know, I don’t get the low oil pressure gauge on my dash (if there is one) so maybe I’m in high oil pressure? I’ll see if I can make this shop check my oil pressure to make sure and this makes it all worse because of my cracked radiator so the readings are probably way off
Old Dec 30, 2025 | 12:59 PM
  #4289
i would suggest to unplug it and ask them to measure it only then and if pressure is what should be then you can plug in dummy and change the radiator and is win win for you
Old Dec 30, 2025 | 02:48 PM
  #4290
GTIBlack's Avatar
Mercedes SL R231
First, read your owner’s manual on how to measure the oil level. It is very common for our engines to show a dry dipstick on first check. Don’t know why. Can’t explain why. Just happens. Search and you will see.
At operating temperature, let the car set for 5 minutes. Pull the dipstick, wipe and reinsert for 3-5 seconds. Pull it again and check the level.
Between the high and low marks on the dipstick is approximately 1 quart. Adding two quarts when the oil level is at the minimum mark is way too much!
Since you are so nervous about this, measure the oil pressure (see attached). But, even if it is stuck in the low pressure position (which is doubtful because the power off position is at full pressure), remember that the solenoid does not deactivate until 3500 rpm normally. So, just drive gently until you figure this out.
File Type: pdf
Old Dec 30, 2025 | 02:53 PM
  #4291
GTIBlack's Avatar
Mercedes SL R231
The “older” engines (M276, M157, M278, etc.) do not have oil pressure sensors or gauges. They only have oil level sensors.
Old Dec 30, 2025 | 03:17 PM
  #4292
Skbrod's Avatar
that’s awesome information, thank you. I’m almost halfway to another oil change , might as well change it out and get the right and correct amount in there. So Seems like I shouldn’t be too worried about this and just unplug it. I appreciate your response I was worried this would seize the engine eventually lol
Old Dec 30, 2025 | 04:26 PM
  #4293
anyway make sure your solenoid is stuck in position with normal pressure and till then don't drive or rev the car more than 2.3k rpms as preventive measure and make sure you use good oil and if you can borrow approved oil with API SP specification would be great
Old Dec 30, 2025 | 08:23 PM
  #4294
GTIBlack's Avatar
Mercedes SL R231
Here’s a video that JettaRed made after he unplugged his solenoid. He used a mechanical pressure gauge to measure actual oil pressure.
Old Jan 2, 2026 | 05:19 PM
  #4295
Skbrod's Avatar
https://youtu.be/OS1TmSA6iAc
just got word from my Mercedes tech …is he bull****ting me right now?
“From the technician theoretically someone could disconnect the the solenoid, but the oil pressure would default at 2 bar. That being said since oil pressure is defaulted to 2 bar you would run into the concern of not enough oil pressure to fully advance timing and or starving top end of oil when supply cannot meet demand.”
Old Jan 2, 2026 | 05:22 PM
  #4296
BDC90's Avatar
Which means a failed solenoid would default to low pressure. Not likely.
Old Jan 2, 2026 | 05:29 PM
  #4297
Skbrod's Avatar
Old Jan 2, 2026 | 07:48 PM
  #4298
GTIBlack's Avatar
Mercedes SL R231
Yeah, he’s mistaken. What does that video show you? In fairness, other manufacturers sometimes have the default to be low pressure. Your guy just doesn’t know what he’s talking about.
Old Jan 2, 2026 | 08:45 PM
  #4299
Skbrod's Avatar
yep thank you I figured he was just saying that, I get dealerships probably won’t do that and just disconnect it which is why he’s giving me the run around and just wants the money to replace . I told him to unplug it and measure the oil pressure for me at higher rpm’s. I guess we see what he comes back with soon lol
Old Jan 2, 2026 | 09:46 PM
  #4300
GTIBlack's Avatar
Mercedes SL R231
Not sure I would trust what he says if he claims he only reached 2 bar (30 psi). To say otherwise would be admitting he was wrong.
You have already rated this thread Rating: Thread Rating: 14 votes, 4.29 average.
