Oil pump solenoids
#976
Received 1,805 Likes
Truly woke would be "Low Velocity Water Vessel from Eastern Asia Elevated Automotive Components Produced by Involuntary Human Energy, Limited"
OldManAndHisCar (02-04-2024)
#977
Unplugged W166 2014 ML63 with Performance Package.
Plug was pain in the axx to get to due to coolant pipes being in the way.
No oil present on plug and taped up end of plug with electric tape but could not zip tie anywhere because the plug wires were very short.
Confirmed with scanner as code P06DA00 showed up.
No CEL also confirmed.
Test drove after unplugging and oil temperature is definitely moving up much faster than before.
Cannot yet report shift patterns due to short test drive but will report back soon on what changes.
The following 3 users liked this post by xxdemo:
#978
W212 E63S Wagon - GSL580 - E63 - E350 - C300
Have to wonder if at some point the wire harness got torn and at that point was shortened because my car had plenty and on the other vehicle right to the exact same thing it had plenty..
#979
Since that exposed end is part of the wiring harness leading to the ECU, you definitely want to close it up with either a female connector (or male--I'm woke and can't figure it out) OR attached a dummy, decoy solenoid. Lots of discussion above about using a matching connector housing to connect and protect that wire connection. See post #942 and after.
#980
Also found the wiring harness a stretch to secure on my ML63 but managed to get a cable tie around the coolant hose to keep it out of harm's way. I used a spare camshaft magnet harness to protect each end from the elements.
#981
Ok, here's the solenoid for my other car (once I get it back). I sealed off the open part with heat shrink and clear RTV.
The following 3 users liked this post by JettaRed:
#983
Rickman30 (02-11-2024)
altesporsche (02-10-2024)
#985
#986
Received 3,667 Likes
MY'14 W212 M276 3.5NA @60kMi
optional plugin load...
It's an optional replacement to help conceal the unplugged pump control.
It's great on chassis with CEL and nice on chassis with silent DTC.
KEVM: are you going to write a summary for your thread post #1000 ??
jcarsnz (02-10-2024)
#987
- Solenoid activation sux.
- Disconnect solenoid.
- Happy engine, happy life.
#988
#989
ChatGPTAs of my last knowledge update in January 2022, I don't have specific information on every engine with dual-pressure managed oil pumps, as detailed specifications can vary among models and manufacturers. However, I can provide you with a list of some automotive manufacturers that are known for incorporating advanced engine technologies, including dual-pressure managed oil pumps, in some of their models. Keep in mind that newer information may be available since my last update, and you should check the latest sources for the most accurate and up-to-date information. Here are some manufacturers that are known for incorporating advanced engine technologies:
- BMW: BMW has been known for incorporating advanced engine technologies in their vehicles.
- Audi: Audi is recognized for its innovative engine designs, and some of their models may feature dual-pressure managed oil pumps.
- Mercedes-Benz: Mercedes-Benz often incorporates advanced engine technologies in their vehicles, and some models may feature dual-pressure managed oil pumps.
- Porsche: Porsche is known for high-performance vehicles and advanced engineering, and certain models may include dual-pressure managed oil pumps.
- Volkswagen: Volkswagen, particularly in its higher-end models, may feature advanced engine technologies.
- Ford: Ford, in collaboration with other manufacturers, has developed advanced engine technologies. Some of their higher-performance models may incorporate dual-pressure managed oil pumps.
- Chevrolet (General Motors): GM is a major player in the automotive industry, and certain Chevrolet models may include advanced engine features.
- Volvo: Volvo is known for its commitment to safety and innovation, and some of their vehicles may feature advanced engine technologies.
https://chat.openai.com/share/2d2d91...b-c09eda8187ae
CaliBenzDriver (02-10-2024)
#990
Which Mercedes-Benz engines use two-stage oil pumps?
ChatGPTAs of my last knowledge update in January 2022, I don't have specific details on individual Mercedes-Benz engines that use two-stage oil pumps. Automotive manufacturers often update their technologies and specifications, and new models may be introduced with different features.
Mercedes-Benz is known for employing advanced engine technologies across its lineup, and the use of two-stage oil pumps might be present in certain models, particularly those designed for higher performance or efficiency. To get the most accurate and up-to-date information, I recommend checking the official Mercedes-Benz website, contacting a Mercedes-Benz dealership, or referring to the technical documentation provided by the manufacturer.
Keep in mind that engine technologies can vary across different models, trim levels, and model years, so it's essential to refer to the specific technical specifications of the vehicle you are interested in for the most precise details.
#991
I'm using the free version of ChatGPT, which is at least two versions behind the latest. However, the latest version of ChatGPT requires mulah.
#992
design by AI, built by robots ...
I bet Bosch ran a custom version of intelligent design CAD to discover random engine oil pressure could save gallons of gasoline worldwide... the low pressure pump was born
TomZVB (02-15-2024)
#994
spinning
>>> in California everything
may cause cancer litigation!
++++ Interest Survey @ 50k Views
In relation to this "OIL SOLENOID MOD" we share:
> What would you be interested in at this point... ?
> What would you like to do... primary interest?
> What do you think may be missing or valuable to add?
>> Personally I'd like to know ...
-- How is your journey unfolding with normal oiling
-- What stage you've reached, mileage,...
Some of these side topics may be better branched off in specific threads.
TomZVB (02-15-2024)
#995
I also installed a dummy solenoid after getting a CEL while unplugged (2018 GLE 63S).
Can confirm no longer have CEL but haven't had a chance to drive it much yet.
Thanks for the suggestions everyone.
#997
Received 2,135 Likes
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
certain S class and GLE class amgs got a CEL, yep - unclear as to why - possibly due to oil pressure feedback per @JettaRed and @kevm14
https://mbworld.org/forums/mercedes-...es-me-cel.html
#998
Hmmmm... was going to pull it tomorrow on the GLS 580
#999
2014 Mercedes-Benz E350
Looking at WIS and the oil pressure test procedures and acceptable test results. I was not aware that between .9 and 1.1 bar oil pressure is acceptable at 600 rpm. No wonder the Camshaft Adjusters fail, I'm surprised they last very long at all.
Seems I remember someone presenting a document from the VVT maker requiring more pressure to operate properly.
13 to 16 psi at idle, and 25 to 36 psi at 2500 rpm... When 3500 rpm is 50 to 70 psi, so idle should be at least 35 psi and 50psi at 2500 rpm unplugged, if not better. I'm basing this off of other engines I've tested oil pressure on in the past, so your mileage will vary.
My old 1981 HD Shovelhead runs 15 psi at idle, but it's air cooled with roller bearings for the crank, rods, and camshaft.
I'm sorry, but this is a no brainer.
The following 2 users liked this post by Rickman30:
CaliBenzDriver (02-12-2024),
TomZVB (02-15-2024)
#1000
So instead of "fuel efficiency" is this a case of engineered obsolescence?
