Oil pump solenoids
Old May 14, 2024 | 08:30 PM
  #1676
JettaRed's Avatar
Veteran: Army
Here's a fun watch...
Old May 17, 2024 | 06:16 PM
  #1677
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
FOUR THOUSAND Mi OIL
I've just past 4000... here is how my oil looks :
A 4k mark reference
Full post ...right here...
Now MY MAIN FAN is starting to...
NOT ALWAYS RUN NON-STOP on low.
Unbelievable
File Type: mp3
Old May 18, 2024 | 12:19 PM
  #1678
TomZVB's Avatar
R231 SL 63
Originally Posted by kevm14
I responded in another AMG thread but I’ll say it here too…
Keep in mind that Lake Speed Jr does have a relationship with Joe Gibbs Racing/Driven oils. If what you’ve been doing to keep your M276/M278/M157 out of bore score hell, I say keep doing what you’ve been doing.
Old May 19, 2024 | 04:05 PM
  #1679
AMG__POWER's Avatar
2024 c300 , 2006 E55, 2005 e320, 2007 gl450, 2025 glc300, 2025 e450
Getting this mod done Wednesday, very excited!
Just out of curiosity though, if one was to change there oil lets say every 2500 miles or 6 months whichever comes first with Liquimoly 5w-40 would this mod be helpful to them considering there oil is always almost fresh? Just curious
Old May 19, 2024 | 04:43 PM
  #1680
Fresh LM.5w40
Just out of curiosity though, if one was to change there oil lets say every 2,500 miles or 6 months whichever comes first with Liquimoly 5w-40 would this mod be helpful to them considering there oil is always almost fresh?
Just curious
A 5w40 Liquimoly oil at 2,500.Mi should definitely be a good choice. You will experience better engine heat management right away.
Manual on-demand cooling :
you can simply shift one gear down while cruising to raise engine speed near 2500.RPM for couple minutes.
This will help remove your pistons heat out and into coolant heat-exchanger to radiator.
> NO-MIX Workaround:
"On-demand" provides manual temperature control without having to mix oil for automatic spraying by-way of viscosity adjustment.
Old May 19, 2024 | 04:49 PM
  #1681
AMG__POWER's Avatar
A 5w40 Liquimoly oil at 2,500.Mi should definitely be a good choice. You will experience better engine heat management right the very first day.
For manual on-demand cooling you can simply shift one gear lower to raise engine speed near 2500.RPM.
Thanks for the tip! I generally drive the car highways so the RPM are low and in comfort or sport typically, and I will periodically do the downshift to around 3500-4k for the spray, I just wanted to do the mod for longevity as it’ll cool the pistons more. Has anyone had this mod in the summer? Particularly in cali it can get very hot!
Old May 19, 2024 | 04:54 PM
  #1682
kevm14's Avatar
04 E55 AMG (totaled), 07 S550 4Matic, 14 E63S
The fresher the oil the better this mod works. Still waiting for my Blackstone report.
Old May 19, 2024 | 04:56 PM
  #1683
W205C43PFL's Avatar
A resounding yes! It doesn't matter if you change the oil after 100 miles or 5000 miles, this oil pump solenoid will only bring positives, the immediate positive improvement you might notice is better low end torque.
Old May 19, 2024 | 06:35 PM
  #1684
.... UNDERSTOOD ....
I am glad some of your wise guys understand the complexity of this topic... it's more than cut the cord + change oil!
I think just the MOD-2.0 empowers people with more choises and free personal decisions.
We DON'T NEED TO KEEP the stock setup for run-away heat burn-your-oil black BS.
Now my engine temperature is seriously under control: cold garage and NO FAN always ON. I could not ask for more. I am old enough to doctor a few basics with the help of the ultimate dive-buddy MS!
The GDI timings are positively helped by a good clean faster CAN-C bus - I've just re-soldered my ESP module and after only 40.Mi tranny shifts noticeably faster... courtesy of stupid brake module.
ESP re-soldered CAN BUS shared with ECU/TCU... guess how fast tranny shifts now
I think this is a game of BOSCH ESP against CONTINENTAL TCU.
Thank you all contributors and joy to many Lucky friends.
You have discovered the "Secret legacy cooling mode" aka. MOD-2.1.
4000 Miles old MOD-2.1 oil: AMBER, not black
Level is holding very well given all the big torque I got from GDI mixtures. It fly's from low, super direct. Rich-strong mixtures under built-in stock control, a welcomed surprise.
In couple weeks, I am going to dump in an extra 100ml booster shot. I want to give this testing oil all chances not to get cooked by borderline-viscosity.
100ml is a good size shot with current choices.
Old May 20, 2024 | 09:01 AM
  #1685
TomZVB's Avatar
R231 SL 63
This was an interesting find over at Yellowbullet.com... seems we're not the only ones finding issues with variable oil pumps. This is on Ford's "Godzilla" line of heavy duty truck engines (7.3L):
Old May 20, 2024 | 09:04 AM
  #1686
TomZVB's Avatar
R231 SL 63
I have not read through all of the particulars with this, but the failures are due to reduced oil pressure at idle/low RPM. Why they would need to squeeze economy out of a heavy duty truck is beyond my reasoning, but this is the end result.
Old May 20, 2024 | 09:05 AM
  #1687
kevm14's Avatar
The Hemi also has this issue, without even implementing variable oil pumps.
Old May 21, 2024 | 11:21 AM
  #1688
Mojo20032004's Avatar
2014 E63S
Just came from a 2000 mile round trip drive from Chicago to north Carolina to visit the famous tail of the dragon.
​​​​​​Drove there a few hundred miles, drove down to Helen ga, drove a few more hundred miles, and drove back to Chicago another 840 miles.. Car didn't skip a beat, running up and down the mountains, keeping rpms at 3-5k, downshifts, full throttle runs, car just kept on pushing! Oil change coming soon. Liquid moly 5w40, also iat pump rewire with a upgraded side mount intercooler
Old May 21, 2024 | 11:47 AM
  #1689
PeterUbers's Avatar
reminds me of this excellent read:
https://mbworld.org/forums/w212-amg/...vs-dragon.html
When the E63 works ... it's one of the most fun sports sedans on this planet
Old May 21, 2024 | 11:50 AM
  #1690
2014 E63S
Yes sir. Plan is to visit the dragon every year between may 14-19. This year I lost my spoiler, I guess improper tape was used and flew off at 170 😔, brightside I got new wheels hehe
Old May 21, 2024 | 12:11 PM
  #1691
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
I am in FL and it has been 90's for a number of weeks. In general (and in the 'other' thread about temps), for me my fake oil temp sits about (in theory) about 12-20F higher than the actual oil temps.
Old May 21, 2024 | 12:38 PM
  #1692
So...you are a litter bug? That 'spoils' the trip
Old May 21, 2024 | 12:40 PM
  #1693
2014 E63S
🤭 I was sad for a few mins
Old May 21, 2024 | 08:16 PM
  #1694
JettaRed's Avatar
Veteran: Army
🙄 (Keep your day job. There's no money in comedy.)
Old May 22, 2024 | 02:33 PM
  #1695
AMG__POWER's Avatar
Mod completed!
Solenoid mod completed along with LM 5-40 oil, ceratec, engine flush and diff fluid change! Thanks to the people who recommended it, excited to see how it runs now
Old May 22, 2024 | 03:25 PM
  #1696
kevm14's Avatar
Just packaged up my oil for Blackstone. Changed the oil yesterday. A shade over 5,000 miles on Molygen 5W-40 (I did have to add 1L during). About 104k on car.
I didn't drive it very far because during this service I realized the insides of my rear tires are beyond spent (whoops). But I did drive it a bit and it feels like the unplugging mod is doing more for me. It's back to that responsive throttle off the line. We'll see what Blackstone says. I will post.
Over 2 weeks later finally got car back on the road. It actually feels different enough that I felt the need to do another MCT clutch relearn. So I did that yesterday afternoon and it, yet again, feels different. Remember, I had just done a relearn at the end of the last oil change and did one with less than 50 miles on the new oil and it is smoother.
Old May 22, 2024 | 03:43 PM
  #1697
AMG__POWER's Avatar
by relearn you make sneaky trans reset? Initial thoughts for me 15 miles post solenoid disconnect is not to much different, oil heats up quicker and seems to still stay at the same temps 210/197. No change in engine feel I will be doing sneaky trans reset today as well
Old May 22, 2024 | 03:53 PM
  #1698
kevm14's Avatar
No, wet clutch adaptation. Requires Xentry.
Old May 22, 2024 | 05:12 PM
  #1699
PeterUbers's Avatar
so in general does your car and it's driveability continue to improve, or do I interpret your feedback to suggest you keep moving forwards then backwards a bit prompting another adaptation
Old May 22, 2024 | 05:36 PM
  #1700
AMG__POWER's Avatar
Drove my car about 50 miles post oil solenoid disconnect and here are my findings.( also did the following at the same time- Liquimoly 5w-40 oil, 2 cans ceratec, 2 cans engine flush, 2 movotech control arms + alignment, liquimoly diff service, liquimoly speed tec and jetron) I do live in Los Angeles so currently it’s about 73 degrees and sunny and I’m not sure if my findings are from the solenoid disconnect or all the other engine servicing I did. My car is running about 8-10 degrees cooler, rarely passing the 210/200 mark, on the freeway cruising around 85-90 in S I was getting 195/195 which is excellent and it would only rise in traffic then cool down again. I also don’t know if it’s placebo but the motor seems smoother and quieter, I’ve only had the car a week so I don’t know if it drives any different per say but I think it’s definitely a good mod to do as it’s free and really has no negative affect.
You have already rated this thread Rating: Thread Rating: 14 votes, 4.29 average.
