CV Shaft/Axle Repair
Old Jun 7, 2024 | 04:40 PM
Scott Gerhardt's Avatar
2014 E63 AMG
Took the car in for an alignment, wheel balance and oil change after doing a nice curb check the other day. As part of the service they looked around the car and noted:
"It was discovered that your cv axle boot is leaking fluid. In order to restore proper axle shaft function and help prevent any premature failure, axle shaft replacement is recommended." They provided pictures showing what looked like black smudge. They have been fair to me in the past, but just making sure they are on the right page for cost (it is an independent shop).
Now I turned it down as they quoted $5,500 to do it for the front. Now I am use to the AMG price tag on getting things fixed, but that seems high even for an AMG to me.
Am I wrong or is that an appropriate charge for a 2014 E63 AMG? Just trying to get a ballpark of estimate on it.
Scott
Old Jun 7, 2024 | 05:27 PM
PeterUbers's Avatar
Is there a parts and labor breakdown?
shaft is $1100 and boot is $70
are they also charging you for front diff service and re seal? That's $1200-1500
https://mbworld.org/forums/w212-amg/...diff-leak.html
Also, likely just the boot can possibly be replaced
from the sticky:
https://mbworld.org/forums/w212-amg/...que-specs.html
https://mbworld.org/forums/w212-amg/...-our-cars.html
The Sticky
Old Jun 8, 2024 | 04:16 PM
kenneyd's Avatar
poop
I did my driver side for about $45 using the OEM repair kit from Mercedes
Old Jun 8, 2024 | 11:10 PM
coolchuck's Avatar
2016 E63s
I think that quote is out of line. If it’s not clicking, you could do an oem cv boot replacement. Same amount of labor to remove the axle but a substantial savings on the parts.
Old Jun 10, 2024 | 01:11 PM
Billy Mays Here's Avatar
2014 E63 AMG S
For your quoting purposes, the dealer noticed torn cv boots up front on my cars first trip there about three months ago. Quoted $3300, I'd have to review the receipt later to see if the actual was same as quote. They didn't replace the shafts in my case, just cleaned up, greased, and installed new boots to my knowledge.
Old Nov 26, 2024 | 09:44 AM
suicidedoors's Avatar
'15 E63 Wagon
Ken, could you link to that repair kit you used? Seeing a few varying options online. Many thanks as always.
Old Nov 26, 2024 | 09:54 AM
rwt14's Avatar
2014 E63S AMG
According to my dealer, they no longer offer the repair kit. You have to buy individual pieces and they recommend buying a whole bunch of items. As far as I am aware, we should only need boots, grease, and clamps... right?
Old Nov 26, 2024 | 09:57 AM
'15 E63 Wagon
Appreciate the quick response - I'll dig further and try and confirm.
Old Aug 18, 2025 | 11:56 PM
Vlad FL's Avatar
2018 CLA250 FWD
I will replace outher CV boots by myself on 2018 CLA250, here the part's list.
Universal Silicone CV boots 2 Pcs on Amazon - $25, and a tool - plastic cone to install new CV boot without disassembly -$10
Clamps ~$15
I also purchased High temperature molybdenum grease at AutoZone $10 plus grease gun $35
I checked service manual, so I will also need axle shaft bolt, it's single use.
Hexalobular Head Screw - Mercedes-Benz (002-990-13-03)2014-2023 Mercedes-Benz (29901303) -$10
Torque: 120nm, loosen and then tighten to 140Nm and turn 45°
Old Aug 20, 2025 | 04:55 PM
FastWgn's Avatar
2016 E63 Wagon
If you look in the link that Perter shared the part numbers are in there
Axle discussion
