Winter setup
Old Dec 12, 2018 | 09:58 AM
  #201
Michael Khan's Avatar
Anyone here running dunlop tires?
Old Dec 12, 2018 | 01:31 PM
  #202
E634Me's Avatar
Veteran: Army
2018 E63S AMG
Originally Posted by LeonPhelps
Is it possible to go with a square setup on the OEM wheels ?
Didn't work well for the Mythbusters:
Old Dec 23, 2018 | 03:53 PM
  #203
AMG777's Avatar
2018 E63S
Finally have the Michelin PA4's 265/40/19 with the Braelin rims installed!
They look good and ride great. Big thanks to bobblehead for all his feedback and advice!
Old Dec 23, 2018 | 04:02 PM
  #204
bobblehead's Avatar
go fast grocery getter wagon
Just in time to go to Whistler to test out those babies. Happy Holidays, Dave.
Old Dec 23, 2018 | 05:36 PM
  #205
HBerman's Avatar
2024 AMG EQE SUV , 2021 E63S Wagon - gone, 2018 E63S Sedan - gone
Looks good. I wonder why people choose black rims for a black car. I would think it would look better with a brushed alloy appearance to accent the tires. Just my two cents here.
Old Dec 23, 2018 | 05:50 PM
  #206
bobblehead's Avatar
hide dirt because you won’t be cleaning them that often.
Old Dec 23, 2018 | 05:58 PM
  #207
HBerman's Avatar
[QUOTE=bobblehead;7637339]
Gotcha! The the thing is that the silver turns a dirty brown and so does the black. Sort of a losing battle during the winter. I have the power washer set up to clean the wheels quickly. The rest of the car is foamed and hosed down.
Old Dec 27, 2018 | 07:46 AM
  #208
coconut780's Avatar
2020 GLE53
E53 winter setup?
Anyone have any advice for what to look for for the e53? I'm assuming everything that people have recommended here would work just fine? I want 19s (should I look at 19x9.5 or 19x8.5) and for the rubber what size should I be looking for? Car will be used in real winter conditions in Canada. I don't think my dealer has anything and I don't want runflats.
Old Dec 27, 2018 | 09:29 AM
  #209
bobblehead's Avatar
As an option, I believe you can use E43 setup ... which would be
Front Wheels: 8Jx19 ET20 245/40
Rear Wheels: 9Jx19 ET49 275/35
TPMS Sensor Part #: A0009052102
Old Dec 27, 2018 | 11:01 AM
  #210
coconut780's Avatar
2020 GLE53
I'd like a square setup. I have the staggered 20s so I'm not sure what the stock 19s look like. Sounds like most people with E63s are using 255/40 265/40. Would that work too presumably?
Old Dec 27, 2018 | 01:51 PM
  #211
bobblehead's Avatar
Can you provide your factory setup now ?
Old Dec 27, 2018 | 02:10 PM
  #212
coconut780's Avatar
2020 GLE53
Good question. I haven't picked it up as yet so I will ask the salesperson. They are the 20s that come with the AMG package but I can't find the information on them online.
Old Dec 27, 2018 | 03:46 PM
  #213
bobblehead's Avatar
need the wheel width and offset so we can suggest something that is closest to factory spec. without use of spacers.
btw, the mb.ca website says factory 19" winter set offering for E53 cost around $4700 Cdn + tax + installation.
Old Dec 27, 2018 | 04:03 PM
  #214
bobblehead's Avatar
https://www.mercedes-benz.com.au/pas...ifications.pdf
From research ... looks like your E53 has this setup
20-inch AMG 5 Twin-Spoke Alloy Wheels in Bi-Colour Black
F: 245/35 ZR20 on 8.0 J x 20 ET 20
R: 275/30 ZR20 on 9.0 J x 20 ET 49
If you want square 19" setup ... I would suggest
Rear Wheels: 8Jx19 ET40 - 45 or 8.5Jx19 ET 40-49 245/40
Old Dec 28, 2018 | 12:47 PM
  #215
coconut780's Avatar
2020 GLE53
It looks like most aftermarket rims are 8.5 or 9.5 inches wide so I'm going to go with 8.5 40ET all around 245/40/19. Make sense? Thanks for the advice!
Old Dec 28, 2018 | 01:26 PM
  #216
Benowen's Avatar
2019 AMG E63S
I went with stock rims staggered Sottozero 3: Front 255/35R-20, Back 295/30R-20. Have about 800 miles on them, great in the rain- have not had any snow in NY yet to test out. But I am very happy with them so far.
Old Dec 28, 2018 | 02:08 PM
  #217
Pioneer222's Avatar
W213 AMG 2019 E63S Wagon
I went with 9 inch wide wheels as recommended by Tirerack, for the 265/40/19 square set up. Not the best pic - weather has been crappy and I have only had the car for just over 1 wk,...
Old Dec 28, 2018 | 04:24 PM
  #218
bobblehead's Avatar
no. Your front offset is 20 factory and you will need to be in around that figure. Otherwise, your aftermarket front offset with 40 could cause rubbing
Old Dec 28, 2018 | 06:15 PM
  #219
coconut780's Avatar
2020 GLE53
Weird. I can't find any wheels with that offset. I guess I'll have to confirm fitment before I commit.
Old Dec 28, 2018 | 06:34 PM
  #220
bobblehead's Avatar
it will be somewhat hard to find esp. if you are shopping on wheel style first, then wheel width and offset.
for example.
factory front: 19x8 et20
if you go aftermarket front: 19x8.5 et40 ... then based on the calculation ....
an inner rim which is 26.4mm closer to the suspension strut. The outer rim will poke out 13.7mm less than before.
Old Dec 29, 2018 | 03:58 PM
  #221
s26singh's Avatar
2015 Toyota Corolla LE
Not a true winter set, but if anyone is interested in a good A/S tire, the Bridgestone Potenza RE980AS is a great choice. Zero issues in minus temps, over ice and in light snow.
Old Dec 29, 2018 | 04:09 PM
  #222
78degrees's Avatar
2018 E63S
I'm driving in real winter conditions (Longyearbyen, Svalbard). We have ice and snow all winter (from october until may)
Do they allow studded tires in Canada? In that case I would go for the Nokian Hakkapeliitta 9 studded tire. Really just the best winter tire I've been using ever.
I'm using 255/40-19 on my E63S
Old Dec 29, 2018 | 04:35 PM
  #223
HBerman's Avatar
Worked very well here in NC as well when we had 8 inches of heavy wet snow. No issues at all in low temps either. A/S UHD tires in recent years are much better than the ones only 3 years ago most likely because of the increased presence of high performance cars.
Old Dec 30, 2018 | 08:05 AM
  #224
coconut780's Avatar
2020 GLE53
Yes studded are an option and I do like the Nokians. I will probably go with the R3 as I did on my other vehicles though. Studded is a little overkill for the area that we are in.
Old Dec 31, 2018 | 09:23 AM
  #225
Meeru's Avatar
2018 GLE63S Coupe, 2018 E63s
jeeez.. livin that no front plate life!
