RIP 2018 E63 - Lemon Law Buyback Completed
As far as the injectors go, following BMW's previous mess with the N63 I learned that there can be a dozen variants of the same injectors that are just so slightly different (and as ItalianJoe1 said above, you tell the computer which variant you have). In the N63 case BMW threw out the entire injection architecture with the N63TU, which is incompatible parts-wise. I bet that Mercedes uses different injectors in Europe and North America.
In turbo cars you could assume that the heat distribution could mess up specific cylinders, but this happens on cold engine, so no.
Which physical position do cylinders 1 and 6 sit in wrt front/back/left/right?
Pick any other brand. and I will find you examples of lemon threads on boards like this.
2018 M5
https://f90.bimmerpost.com/forums/sh...ighlight=lemon
2015 M5
https://f10.m5post.com/forums/showthread.php?t=1179818
2017 Panamera
https://www.macanforum.com/forum/oth...-panamera.html
Audi A7
https://www.audiworld.com/forums/a7-...-back-2902588/
I drive in comfort mode in city traffic and let the engine start stop and run in 4 cylinder mode. I also will drive in sport mode when entering a highway etc.
My guess is that they don’t want to change the fuel injectors because of labor cost but if done it addresses the issue. They had the car for 28 and after two weeks told MB that I would lemon the car if I had to. I would like to believe the complaints cause MB to focus and fix the issue.
I think the point is that owners are frustrated because of slow timing and lack of feedback from MB. Without sufficient information, everything else is conjecture. Neither you or I have enough information to make these statements.
Unless somebody starts a list with VIN numbers and build dates, these threads doesn't deliver any indication of a broader issue. Does it impact 50 cars? 500? Nobody knows.
This is nothing like BMW's engine issues with carbon build-up and stretched timing chains. It seems more like the F90 early recall that required a software update where engines would shut down anywhere between the day of delivery to 1000 miles.
At Bimmerpost forum, people reported their car information and it was easy to see just how pervasive the issue was in terms of volume. BMW was on the ball and addressed the issue quickly but I think it was likely easier to fix if every car fails than just a certain percentage...
I think it's a software logic issue that makes misfire detection too sensitive. When the car sees a cylinder not firing properly it shuts it down to prevent catalyst damage and triggers the light. This is why some people feel shaking and rough running that goes away after a restart, others don't feel it just get a CEL, it's all about frequency of the misfire faults. You can watch the misfire counter of a running engine and see them pop up randomly around the engine, mostly during very light throttle, slow speed, parking lot style driving. I believe they have the injection pulses so small at those times, in some situations the cyl barely fires and the M/E registers it as a misfire even though it's not. The fact that most of the cars that have had injectors replaced got "better" makes me think it's a stack up of tolerances, as each injector has a coding # on it and we have to perform programming for injector quantity adjustment whenever we replace one, they are supposedly very accurate. They can be activated for just a couple mS, multiple times per piston stroke and DI motors only inject during the late intake/compression stroke, so you have a very small window. I feel, if they could back down the misfire detection logic to be slightly less sensitive, or at least in the conditions when it seems to happen (haven't seen any issues at full throttle or during aggressive driving that would indicate a mechanical problem), it would be fixed.
The engineering TIPS document I posted and some of the other tech topics I've seen make it seem as if every car with misfires has an air leak somewhere. I just can't believe, especially on a system with no MAF using only a SD based tuning logic, that the car can't handle the tiniest leak at a V band clamp or something and it sets misfire codes and acts up like that. Until they revise the docs and tell us what they've decided to do to fix all the cars, I don't know what else to say. As techs, we are limited in our ability to even see the data, much less understand it. We just want to fix the cars and keep the customers happy. Daimler and AMG aren't making it easy at the moment.
To a certain extent this is all software issues. A misfire results in higher emission and after the VW D hoax I am sure the EPA is watching all the German manufactures very close. I hope they resolve the problem but a little worried about cel when the car is four years old and won’t pass state inspection.
Its been a couple weeks since the car was repaired and all is well so far, no new CELs.
I routinely leave the ECO-start enabled. But the misfires and CEL typically happened shortly after a cold start and before I got to a stop light/sign where the car would normally turn off. Still, worth a try.
