Anyone gets new exhaust on their W213 e63s?
Old Nov 19, 2018 | 09:23 PM
lewisjiang110's Avatar
w213 e63s
If so, could you post some sound clips. I’m trying to get a new exhaust on my car. Just want to listen some clips that can give advices. I want the sound that is deep, please give me some davices! Thx!
Old Nov 21, 2018 | 09:29 PM
MuffinFlavored's Avatar
2018 W213 E 63 S AMG Sedan
What complaints do you have over stock/AMG performance exhaust?
Old Nov 26, 2018 | 01:27 PM
w213 e63s
no complaints, just want it louder,
Old Dec 10, 2018 | 11:56 PM
C63SVERT's Avatar
2018 AMG GTC Roadster. 2013 SL65 2018 GLC63
check out Renntech’s 200 cell sport cats. They aren’t cheap, but the best combo of sound and civility and zero issue with your dealership. Best sounding W213 E63S I’ve ever heard.
Old Dec 11, 2018 | 02:03 AM
honeybadger15's Avatar
'19 E63s
Have you considered removing the secondary cats? https://mbworld.org/forums/w213-amg/...er-delete.html
I'm going to see if a local shop can do it. Anyone else have luck with it?
Old Dec 11, 2018 | 01:08 PM
ArtyyArt's Avatar
2018 E63s
I'm going to have the Renntech 200 cell cats installed next week along with a custom titanium exhaust. I'll take some videos and post them up once I get it all installed. It's going to loud
Old Feb 3, 2019 | 10:36 AM
dav461's Avatar
GTR
Installed brabus exhaust, it’s slightly louder adding more bass than stock performance exhaust, not as crazy as Capristo...
Old Feb 3, 2019 | 04:10 PM
bobblehead's Avatar
go fast grocery getter wagon
I do like the tips
Old Feb 3, 2019 | 08:53 PM
momo style's Avatar
C 63 AMG 507 Edition
From where are you getting your custom titanium exhaust ?
Old Feb 3, 2019 | 10:44 PM
Mike Youngs's Avatar
I’m getting these next week , can’t wait . No issues with dealer ? They won’t void the warranty ?
Old Feb 4, 2019 | 06:41 AM
Meeru's Avatar
2018 GLE63S Coupe, 2018 E63s
Akrapovic 😬
Akrapovic Titanium exhaust
Eurocharged Downpipes
Old Feb 4, 2019 | 09:41 PM
b0kix's Avatar
Stock exhaust is horrible design the valves inside will get stuck and ecu will cut power. I recommnd after exhaust for everyone. I can get 10% on awe exhaust on arkapovic
Old Feb 5, 2019 | 05:06 PM
Mandarin's Avatar
e63s
Crisp, retains a bit of the AMG bass
Did you put tranny down in order to install DP?
Old Feb 5, 2019 | 05:10 PM
Meeru's Avatar
no didnt want to pay 14 hours in labour 😂
Old Feb 5, 2019 | 05:38 PM
E634Me's Avatar
Veteran: Army
2018 E63S AMG
Just curious, are these California CARB compliant?
Given the new no fix-it ticket for loud exhausts and requisite required CARB **** probing to validate repairs, one can't be too careful with exhaust related mods now in CA.
Old Feb 6, 2019 | 08:30 AM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
I know of over a hundred W213`s with our down pipes and sure someone will post a clip.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Feb 6, 2019 | 11:14 AM
Mandarin's Avatar
e63s
I think it's better than put tranny down. I assume they also did not cut your stock DP, correct?
Old Feb 6, 2019 | 08:02 PM
What is the DP installation process if they do not drop tranny? What do they cut?
Old Feb 6, 2019 | 08:13 PM
Meeru's Avatar
cut below the turbos and weld.
people drop tranny to avoid losing warranty
Old Feb 7, 2019 | 11:15 AM
Mandarin's Avatar
e63s
Any exhaust mods will avoid your warranty except if you will get approved by Mercedes parts and get them at a dealership. In other cases, you will lose the warranty at least for exhaust components.
I have not done that yet and don't want to confuse anyone with that, but I was talking to "DME tuning" in NJ and they told me when I'll get into a shop to get this done they will explain to mechanic how to cut stock DP. Later you can weld V-band clamps on them and can use them again, in this case, you don't need to put tranny down, what I definitely want to avoid with the new car.
Old Feb 7, 2019 | 12:32 PM
dav461's Avatar
GTR
shardul posted pics (in his thread )in which he shows where it should be cut in order to remove stock dp
Old Feb 14, 2019 | 05:31 AM
dav461's Avatar
GTR
Catless downpipes installed, sounds amazing
Old Feb 14, 2019 | 08:01 AM
bobblehead's Avatar
OMG ! That is heaven
You should also record the sound when it is at near full throttle
Old Feb 15, 2019 | 11:04 AM
Would cutting stock DPs make you nervous at all? Would it make for a pretty ****ty case on lease return? lol
Old Feb 15, 2019 | 11:05 AM
YouTube
Brabus exhaust and what kind of downpipes? Or is it just... same stock downpipes but they just welded cuts, took the cats out of them, then welded them back? Or am I an idiot and that's not how that works at all?
