AMG GT 63S E Performance
Old Mar 14, 2022 | 02:28 PM
6G Schnell's Avatar
2021 E63S and 2025 GT63
https://www.mercedes-amg.com/en/vehi...mance-pad.html
Old Mar 14, 2022 | 05:48 PM
allanmac's Avatar
2019 AMG E63S Wagon
Why are they coy about "total" horsepower?
470 kW, gains a powerful, electrifying ally that brings a further 150 kW
That's works out to ~831 hp, right?
Also they note the battery is 6.1 kWh which is ~1/3rd the capacity of, for example, an XC90 T8 hybrid SUV.
So I guess that extra ~200 hp isn't for getting to the grocery store efficiently but is all about performance?!
Old Mar 14, 2022 | 05:50 PM
allanmac's Avatar
2019 AMG E63S Wagon
One more question, do you think the fact that the front engine bay is unchanged implies that the wagon will be available in both this "E" hybrid performance variant as well as the the 4.0L ICE variant?
Old Mar 14, 2022 | 06:20 PM
nw66's Avatar
E63S 4MATIC 213
Wonder if you can tune them
Old Mar 14, 2022 | 06:28 PM
superswiss's Avatar
2019 C63CS
Because it's not sustained power or even guaranteed. This is the dirty secret with these new E Performance models. The total power is only available for 10 seconds. Sustained power is lower. And if the battery charge gets low you are left with only the ICE power. The battery effectively discharges over a full tank, so then if you fill up, but not charge the battery you will also be down on power until you can charge the battery again.
Old Mar 14, 2022 | 07:17 PM
allanmac's Avatar
2019 AMG E63S Wagon
That sounds right.
A reply in the AMG forum states there are 4 battery regeneration modes ranging from nothing all the way to full "single-pedal" mode where the electric motor is maximally charging (and implicitly braking) when the accelerator is lifted.
Old Mar 14, 2022 | 10:21 PM
bullmrkt's Avatar
AMG E63 Hammer Wagon. Alfa, Rover, Ferrari, Porsche.
…and don’t forget you’re still dragging around that extra 400lbs of hybrid hardware when the battery is dead.
Old Mar 14, 2022 | 10:56 PM
6G Schnell's Avatar
Exactly, this is why hybrid cars have poor energy efficiency…
Old Mar 15, 2022 | 12:10 AM
superswiss's Avatar
2019 C63CS
Yeah, even before that this is inertia that doesn't just magically disappear. This is a heavy boat.
Old Mar 15, 2022 | 04:47 AM
0002s's Avatar
2022 E53 AMG
It appears all AMG vehicles are going mild, to full Hybrid, then completely EV.. This sounds like the evolution to what the E53 has going on.
I imagine that full performance mode will be able to be recharged, while driving, when used in short bursts. I also imagine that track day or extended full power usage will require the use of the wall charger. I am also going to guess there will be a very limited range, normal econo car HP, full EV mode. This mode will also require the use of the wall charger.
I’m going to guess “one man one motor” eventually disappears too.
The tech in these cars is advancing so fast. Straight line performance will be amazing. Handling will be interesting until the tech goes to Jenny Craig and keeps it off.
Old Mar 15, 2022 | 10:14 PM
Drewsky00's Avatar
2019 AMG E63 S
Man, I can't help but be sad reading this thread about what the future holds.
Old Mar 16, 2022 | 12:41 AM
Drone_S213's Avatar
Veteran: Air Force
2021 AMG E63s Wagon
As an Engineer Hydrogen Fuel Cell propulsion makes more sense. Especially since my 2 residences are 1500-miles apart. Will not get excited about the future until flying cars like in Bladerunner 2049 or Westworld.
EV motorcycles are a different story!!!!
Old Mar 16, 2022 | 12:44 AM
6G Schnell's Avatar
May not be too bad as we still have the choice: keep the mighty V8 until the transitional hybrid story is over…
Old Mar 16, 2022 | 06:25 AM
nw66's Avatar
E63S 4MATIC 213
+1 the V8! have read somewhere the next C63 will be a 4 banger
Old Mar 16, 2022 | 07:59 AM
W205C43PFL's Avatar
Ya unfortunately that is confirmed, still have high hopes for the E63 though, unlikely it is losing its V8.
Old Mar 16, 2022 | 08:11 AM
0002s's Avatar
2022 E53 AMG
Is it about #of cylinders or overall performance? If they produce a better car with better performance, does it really matter, past nostalgia?
Old Mar 24, 2022 | 06:06 PM
W205C43PFL's Avatar
I wish you can disconnect the battery while you are not using it and leave it home that way you get the best of both worlds. Reminds me of removable batteries on smartphones, lawn mowers etc. (but I guess probably not feasible on a hybrid vehicle plus there might be liability issues).
Old Mar 25, 2022 | 12:15 AM
6G Schnell's Avatar
True, ICE only, or the EV only is a better solution than the hybrid. Car industry is taking this hybrid approach (the lowest energy efficiency) as temporary fix until we get the new battery technology enabling the longer range.
My 2c is to stick to the mighty V8 until .. … we get better performance than the existing V8 plus the range of about 500 miles and battery charging time below 15;minutes..
Old Mar 25, 2022 | 05:48 AM
nw66's Avatar
E63S 4MATIC 213
can you imagine a C63 without the V8 growl, sad day
Old Mar 25, 2022 | 07:28 AM
0002s's Avatar
2022 E53 AMG
I can imagine a C/E/S Class AMG AWD, with a straight 6, larger turbos and plug in hybrid motors at the rear. I can imagine 650hp daily setting and 850hp track setting. I can imagine 21/29 mpg. I imagine it sounding like a straight 6 race car. I also imaging a 1000hp EV with piped in sound of your choice.
Old Mar 26, 2022 | 06:30 PM
mercedesmax's Avatar
2015 CLS 550 2015 ML 400 Previous 2020 GLB 250 2019 A 220 2005 ML 350 1989 300 E 2001 SL 500
I've seen the engine bay of the new C Class. No way an I6 fits in there.
Old Mar 26, 2022 | 10:23 PM
PeterUbers's Avatar
Any pics or dimensions?
Old Mar 27, 2022 | 05:10 AM
nw66's Avatar
E63S 4MATIC 213
maybe you should buy a tesla because you'll be waiting a long time for a Mercedes to build a car with those specs
Old Mar 27, 2022 | 09:00 AM
0002s's Avatar
2022 E53 AMG
i imagine we’ll see this in 5 years.
Old Mar 27, 2022 | 09:02 AM
hyperion667's Avatar
2012 CLS63
