ECC Slav tuned performance over stock - 60 to 130
Old May 25, 2022 | 07:59 PM
brutus_tx's Avatar
2014 AMG E63S and 2020 AMG GTC
This is the second thread dedicated to a colleagues W213.
We started down the mod route previously with the addition of a BB Intake and CPC module..... those results can be found here:
https://mbworld.org/forums/w213-amg/...-ecu-tune.html
This thread was created to start the documentation process on the performance gains that the recent addition of a ECC Slav ECU and TCU tune netted us.
The flash went on the car yesterday in 90°F Houston heat.
After allowing the car to adapt to the new tune, we went and ran a 60-130 run to compare the performance prior to the recent flash.
Proof is in the pudding...
Prior to yesterday, the best performance attained from the car was an 8.84 in near ideal temperatures and DA.... realistically we doubt we could have done any better.
In optimum conditions, the car ran.....
To put this is perspective to a run we made in conditions similar to what we ran today, in ~70°F temps, stock the car ran a....
Today, in mid 80°F temps, and on a whim on the highway, we clocked the following 60-130 time....
That is a fantastic time for a W213 running a BB Intake, BB CPC and ECC Slav ECU & TCU tune. 2 full seconds over stock in similar temperatures.
This is on stock fueling and pump 93 octane gas as well!
While we haven't had a chance to put the car on the dyno, Slav sent us a dyno plot of the performance we could expect when running 93 pump.
Given the performance in less than optimum conditions, I'd say the car is making power as advertised. ~ 740 awhp and 790 awtq on pump 93 is pretty damn good in my book.
The logs showed the car hit requested boost targets and there was zero knock and zero timing pull. This tells me there's more in it when the temperatures cool off in the fall.
ECC Slav truly has these platforms figured out and dialed in. Now we just need cooler temps to run a 1/4 mile.
I'll update this thread as more performance figures present themselves. The car will stay with these performance mods for the foreseeable future. It remains to be seen if we will tweak the tune a little more in the cooler months.
Please reach out to ECC in Toronto if you wish similar performance numbers.
www.ecctuned.com
This tune is no joke.
PS Shout out to Chris Mattox of Star Motor Works... recently moved to Houston in the great California exodus of 2022.
Chris has a great working relationship with Slav of ECC.
Chris was gracious enough to work with my friend to install the ECU and TCU tunes and perform street logs and install tune tweaks.
You can reach Chris via his company Star Motor Works in Costa Mesa California.
Old May 25, 2022 | 11:06 PM
raudiace4's Avatar
19 E63s, 23 M3 compX, B9 SQ5
Nice run and good time for a stage 2 car.
FWIW my car ran a similar time (7.22) with EC ECU tune/CPC and BB intakes. When it was stage2.
Old May 26, 2022 | 12:02 AM
5soko's Avatar
AMG
Nice continued break down Brett!
Old May 26, 2022 | 01:37 PM
skim7x's Avatar
Mercedes-Benz E63s AMG
Thank you very much for sharing your detailed results with the community. I feel that there are a lot of fast E63s out there and nobody wants to share their "secret sauce."
Old May 26, 2022 | 06:18 PM
PeterUbers's Avatar
Thanks to Brett et al I'm driving a rocket e63!!
Old Jun 6, 2022 | 08:38 PM
kponti's Avatar
E63
Hey Raudiace, what was the temps/DA when you did that run? I am wondering if these cars are capable of mid to high 6s in stage two trim with ideal temps and DA
Old Jun 7, 2022 | 12:28 AM
Cylinder Head's Avatar
'19 E63S, ‘16 CLS63 RIP, '09 E63 Gone, '06 M5 Gone, '97 Supra TT Gone
certainly puts things into perspective
Old Jun 7, 2022 | 09:48 AM
raudiace4's Avatar
It was 792 DA. So pretty good, I don't think mid 6s is possible on stage 2 power levels with the mods I had (Catless DPs, BB intakes and ECU/CPC only), maybe if you did upgraded fuel pumps with TCU tune and E40-E50 fuel mix. 7.22 was about as fast as i could get my car to go at that time on 93.
For Comparison, this is my car with PTG1000s, meth injection, BB intakes, Catless DPs, ECU/TCU/CPC tune on 93. Not sure why the DA didn't show here, but it was in 80 degree weather, i think I can improve on this time for sure with upgraded fuel pumps and some sort of a E mix.
Old Jun 8, 2022 | 09:45 PM
MBS E53's Avatar
2025 GLE 53 2019 E53 2002 C230K
Where are you getting your work done on your AMG here in Houston? I would love to know who to trust with tuning locally.
Regular service I got covered, I mean the specialty stuff similar to what you're doing.
Thanks, and stay cool - gonna be a bit on the warm side for the next few days.
Old Jun 9, 2022 | 11:58 AM
kponti's Avatar
E63
Those are some badass times man! Congrats on that beast!!
Do you think you would be close to your upgraded turbo times with stock turbos if you had done the pumps instead?
On a side note, my car was slower with 4 gallons of E85 mixed into a full tank of 93 than just 93 octane. My car was stock ECU and TCU
The 7.25 from OP were done with around 2000DA and weather at 93degrees (not sure why the draggy says 80). Looking forward to seeing the same car when the temps go down in TX. Probably not in the mid 6s, but high 6s I can definitely see
Old Jun 9, 2022 | 02:01 PM
raudiace4's Avatar
With stock turbos and upgraded LPFP and HPFP I think you can get close to mid 6s, but not really close to the upgraded turbo times with stock pumps. The stock turbos run out of efficiency and power eventually, however the pumps do offer a huge benefit from what I've seen.
We shall see what she can really do with the PTG1000s and upgraded pumps.... Soon.
Old Jun 9, 2022 | 09:21 PM
brutus_tx's Avatar
If your looking for specialty stuff then you have a couple of options, IMO. There's Matt Chan at Legacy Motorworks... Chris Mattox with Star Motorworks or Emmanuel De Jesus at Imperial Auto.
This car is running the ECC Slav sauce and Chris is the go to guy for tuning.
He can get you tuned no problem. He is listed in the initial thread.
If you are looking for the BlackBoost hardware then reach out to Jose at www.BoostedBenz.com.
