Trickle charging a W213 e63 AMG wagon
2018 e63 AMG. This car doesn’t get driven much so I’d like to put my CTEK on it. The battery was replaced by the dealer a few months ago when I bought the car used with 11k miles. I’m not having any problems, but would like to keep it that way. Dealer confirmed it’s an AGM battery. When I connect the charger to the positive blade and the negative stud under the hood, it only charges to 50%. I am new to MB but I know Porsches have a lockout mode for charging unless you do a certain door close/lock sequence. Is that what’s happening here? Recommendations appreciated. Thanks!
Luckily, there is a simple solution that does not require battery charger - Standby mode.
My E63 claims it will be able to start the engine after 33 weeks, if put into Standby with fully charged battery.
Caveat is remote services (me connect) and alarm are turned off when in standby mode…
I also learned (every vehicle has its own charger, but I missed this best practice) that one should recondition a battery at least once a year. So I added a note to my iPhone with all the vehicles and when I reconditioned.
Look up your battery online and confirm it truly is AGM. 2018 OEM/replacement battery is not AGM. If it is AGM, make sure the mode on the charger is AGM, (I've standardized on the MXS 5.0, which has a mode button labeled AGM). I'm not sure what the car could do to stop a charger from completing its full cycle assuming you connected the CTEK dongle directly to the battery terminals (not some spot out under the hood somewhere).
on subsequent charge up, it may take less than 12 hrs (if you do this once a month or two)
