E63s AMG (W213 facelift) WINTER TYRE SETUP HELP
E63s Final Edition
E63s W213 Facelift (UK)
Hello guys,
Sorry if this has been asked before, can’t find anything. I currently run Pilot Sport 4s on all four during the summer, but would like to know an alternative for the winter season.
Rear: 295/30 ZR 20
Front: 265/30 ZR 20
Can anyone recommend any high performance winter tyres?
Preferably Michelin, open to suggestions.
Hello guys,
Rear: 295/30 ZR 20
Front: 265/30 ZR 20
Last edited by hyder1995; 07-02-2024 at 01:53 PM. Reason: Mentioning country location and tyre use season
Hello guys,
Rear: 295/30 ZR 20
Front: 265/30 ZR 20
Hello guys,
Rear: 295/30 ZR 20
Front: 265/30 ZR 20
Let me know if you’d like part numbers.
I.T. Guy (07-02-2024)
E63s Final Edition
I see you’re running Pilot Alpin. Ive had a look online but can’t seem to find the Pilot Alpin 5 in my tyre size? I might be wrong though.
I dont want to up the profile incase it messes with the speedo and sensors.
These were a full kit from Mercedes - rims, TPS and tires. They showed up to the dealership mounted and ready to go. They are 19" wheels, but I was fine with a little cushion for pothole season. They also came with MO PA4s, which I was also fine with. If I had a choice I'd have liked to try PA5s, but they were not available in the kit when I placed the order.
Front: Q8409065
Rear: Q8409064
Hope this helps,
Front: Q8409065
Rear: Q8409064
Hope this helps,
asc (07-05-2024)
I’m running the same oem 19” wheels and Michelin PA4 or 5 as well. The Michelin are the best balance for grip if you encounter real ice and snow (I’m in Canada) and yet don’t melt away if you do bursts to 200+ and handle fairly well on pavement too,
Ive used all the Mercedes winters like Sotto Zero etc. snd the Michelin wins hands down.
wgnlust (07-02-2024)
Front: Q8409065
Rear: Q8409064
Hope this helps,
Front: Q8409065
Rear: Q8409064
Hope this helps,
Thanks for posting this. The problem I have with the MB setup is the INSANE markup. They want something like $8k for a staggered setup (265/295) with PA4s on 19s. Tire rack will sell me a similar setup (but square, 255 all around) with either Pirelli Scorpions, Blizzak LM5s, Vredestein Wintrac Pros, or Michelin X-ICE/SNOWs, and my choice of wheels (Borbet, Enkei, OZ, among others), all for under $2.5k. There would be a labor cost to swap the wheels, or course, but in my experience that's no more than $200 (2x/year). Overall it's WAY less expensive to go aftermarket. Looks better too imo. So I'm torn. Anyone have thoughts on this and what to do? I need to make a decision in the next couple of months. On a '23 E63S (not final edition). Thanks!
I ran cheap winter rims on my W212 and had to keep a spare on hand, they bent so easy. I was spending $250 on a new wheel constantly + remount and balance, for the life of the car. It adds up never mind so much wasted time too.
With the "expensive" OEM W213 forged winter rims, - that I bought used -, they are still rocking it and ZERO bends. Strong.
asc (07-05-2024)
This might help
I ran cheap winter rims on my W212 and had to keep a spare on hand, they bent so easy. I was spending $250 on a new wheel constantly for the life of the car. It adds up and wasted so much time too.
This might help
Maybe it’s worth price checking another dealership?
Not sure where you’re located.
If you go aftermarket, please share pics?
asc (07-05-2024)
I think I was out the door for just over 5K. For me, there wasn’t enough delta to shop. OE quality and fitment plus my dealership handles swaps and storage with a couple days notice.
wgnlust (07-05-2024)
You might have better luck not looking for the assembly. Get the rims quoted, and buy the tires separately.
Fun fact: all MB parts counters can give 20% off without manager or higher up approval. I don’t even have to ask anymore, my parts guys at the dealer know me and just always give it.
If it's any help
When I plug in just the rim part numbers on a site like this
https://www.mbdirectparts.com/
They come up as about $1k/rim
When I plug in the assembly part number (including tire) on the same site they come up as about $1700/corner
And, ebay has full sets for about $2k USD used, with tires. Might get a tiny bit of road rash, look at all pics carefully
Good luck in your search
The following 2 users liked this post by I.T. Guy:
asc (07-07-2024),
Drone_S213 (07-07-2024)
If it's any help
2021 AMG E63s Wagon
Observation from a NYC ex Patriot who bought his first vehicles in LA & ELP
Wish you luck on your dedicated 19" wheels and winter tires.
I just recently bought my first Avon but am already thinking about the winter in CT
i had a OEM dedicated set up on my M3 but they were smaller and uglier.
has anyone considered just swapping over winter tires? My local spot will store your summer tires for $100
i think that’s what I will do, saves garage space also
Ah, Ok! Interesting. That sucks! I guess I’m shopping for a wheel and tire package then
Can you get all seasons in our size? Obviously a compromise. Our climate isn’t that bad, our roads are well
maintained with grit, and I have an other SUV to drive if it’s really bad
Not that I'm aware of. Hence all the discussions here about winters. I'd be open to all seasons on my current wheels, certainly easier than a full swap.
2023 E63s Sedan, 2020 E53 Sedan
You can try what I did, which was to buy Michelin Alpin PA5's, although they don't have our size/dimensions in 20", I settled for the slightly taller sidewalls, it puts a 4% hit on your speedometer though, but stock clearance is more than enough on the wheel wells. Just a thought.
G80 (07-10-2024)
Interesting, what size side wall profile did you go for? Bigger side wall in Winter is a good thing, loads of clearance in our arches for sure
You can get Michelin All Seasons in
265/35ZR20
295/35ZR20
A lot of winter tires would be out of stock in July so maybe there will be better availability in September time
Tire Rack Have Pirelli Scorpion Winters available right now, $1700 for all four.
265/45R20
295/45R20
There are a few sets of used OEM winters on ebay Germany for $2k delivered. Even if the tires are a bit old, it's a good deal on the rims assuming they are straight
When switching from 19' from 20' wheels, does the ECU need to recalibrate? I'm just wondering if there is a way to adjust for the speedo being off by 8%?
Also, I know the ratio of size from back to front needs to be within a certain tolerance or you can throw the AWD system off.
asc (07-10-2024)
265/35ZR20
295/35ZR20
265/45R20
295/45R20
265/35ZR20
295/35ZR20
265/45R20
295/45R20
