I am noticing a slight shake in the steering wheel when braking at higher speeds. I just had the rotors and pads replaced. Any suggestions? Thx
PeterUbers
close
- Join DateJun 2004
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I drive2014 E63S; AMS 100 octane ECU dyno tune; EDOK TCU tune; BB intakes; sprintbooster
Liked:3,228 Times in 2,241 Posts
Quote:
take it back and they'll inspect their work; they'll likely try and re bed the new pads in the rotors. why were the pads and rotors replaced?Originally Posted by WildWolf
You don't have a winter square wheel-tire Setup that was rotated do you?
bobblehead
close
- Join DateJul 2013
- LocationToronto, Ont, Canda
- Vehicle(s) I drivego fast grocery getter wagon
Liked:809 Times in 612 Posts
rotor(s) is(are) warped ?? ... defective. or they were not installed properly.
I do have a square winter tire setup but not installed yet. I did put new summer tires on a few days after the rotors/ pads. I had them torque the lugs by hand. I had no pads left after 27,000 miles
PeterUbers
close
- Join DateJun 2004
Quote:
it's your new tires - the wheels aren't balanced OR there's a bend in them - were they road force balanced?Originally Posted by WildWolf
hopefully they weren't too aggressive on torquing the wheels bolts
Vibration when braking is usually rotors, not tires.Originally Posted by PeterUbers
it's your new tires - the wheels aren't balanced OR there's a bend in them - were they road force balanced?hopefully they weren't too aggressive on torquing the wheels bolts
superswiss
close
- Join DateNov 2018
- LocationSan Francisco Bay Area
- Vehicle(s) I drive2019 C63CS
Liked:5,323 Times in 3,630 Posts
I concur, if the vibration only occurs when applying the brakes, then the issue is the brakes and not the wheels/tires. However, the Mercedes brakes are somewhat sensitive to incorrect torqueing of the wheels. Do you recall if the vibration was there right after you had the brakes changed, or only after you also had the tires changed? If the latter, then they likely over torqued your wheels and caused the rotors to warp. If the vibration was there before, then one or both front rotors might have been damaged in transport. Somebody may have dropped them accidently.
Are these the OE rotors? You can also consider upgrading them to full-floating rotors. Not only are they way cheaper than the OE rotors, but as opposed to the semi-floating OE rotors, these can also move laterally to center between the pads. Helps with consistent brake performance regardless of thermal expansion. These rotors are technically OE, too. They were used on the 204 C63 Black Series and also on the AMG GT R when not optioned with the CCBs. I'm on my second set on my '19 C63S coupe. Awesome rotors, and FCP Euro has lifetime replacement warranty. You send back the worn rotors and they give you a credit for the full purchase price.
https://www.fcpeuro.com/products/mer...mbo-2304211212
PeterUbers
close
- Join DateJun 2004
Quote:
definitely agree on this generally;Originally Posted by whoover
however - he had two things happen in proximity - new tires and balanced and re installed (possible poor balance or over torque and damage rotor) and he had new rotors installed - bad rotors or damaged rotors or poor install or bedding
hard to say
ExploreOut Of Control!!
PeterUbers
close
- Join DateJun 2004
You can go try re-bedding the brakes yourself and see if that makes any difference, it's easy and it's free and quick.
