Coolant Temperature E43
Old Mar 21, 2025 | 01:14 AM
e43__'s Avatar
Hey guys i own a 2018 e43 amg. Usually my coolant temperature stays around halfway. Today i noticed that when i was on the highway my coolant temp became colder, when i got off the highway and onto city roads my coolant temp went back to the middle where is usually is. I don’t know if this is normal since i’ve never paid much attention to it. I have attached my coolant temp gauge of when it was cold on the highway and on the city road a minute later where it went back to normal.
Old Mar 21, 2025 | 09:08 AM
PeterUbers's Avatar
Normal. More cooling while at higher speeds on the highway due to more air movement - this effect may be more aggressive in colder weather.
Old Mar 21, 2025 | 11:35 AM
W205C43PFL's Avatar
As said, it is normal. Do keep in mind that the gauge is still doctored.
Old Mar 21, 2025 | 11:36 AM
W205C43PFL's Avatar
Reason why it is doctored it is because in the past, people complained about the gauge kept fluctuating and thought something is wrong.
Old Mar 21, 2025 | 11:37 AM
W205C43PFL's Avatar
https://mbworld.org/forums/e-class-w...inda-liar.html
Old Mar 21, 2025 | 11:38 AM
W205C43PFL's Avatar
https://mbworld.org/forums/w212-amg/...-liar-too.html
Old Mar 21, 2025 | 11:40 AM
W205C43PFL's Avatar
I am not sure if the workshop menu will show real time and actual temperature worth looking and checking. Otherwise only through scanners.
Old Mar 21, 2025 | 01:29 PM
natesamg's Avatar
2020 E53 AMG Sedan
on my car when i bring up the dash/speedo on the right side i can switch to the tire pressure menu which shows me a number for oil and water temps. would that not be sufficient?
Old Mar 21, 2025 | 03:51 PM
e43__'s Avatar
So am i good? Should i look out for anything or just let it go? Also thank you!
Old Mar 21, 2025 | 03:52 PM
e43__'s Avatar
Thank you, so i should be good. Does that mean the gauge is not accurate or made to please owners of Mercedes to prevent overthinking.
Old Mar 21, 2025 | 04:00 PM
W205C43PFL's Avatar
not just MB, many makes have doctored gauges and only really start to move higher when the temperature is too hot.
Old Mar 21, 2025 | 04:02 PM
W205C43PFL's Avatar
3 guages to keep in mind. Engine oil temperature is not doctored at least not as doctored as coolant and the 3rd one is transmission fluid temperature.
Old Mar 21, 2025 | 04:17 PM
e43__'s Avatar
Got it, so my car is working as it should be?
Old Mar 21, 2025 | 04:41 PM
W205C43PFL's Avatar
It looks normal to me but I want more members to chime in to your thread just in case.
Old Mar 21, 2025 | 06:01 PM
e43__'s Avatar
Very true, what i have done i was going through my phone camera roll looking for that little gauge for the coolant and it seems that my coolant used to stay either at the middle or a fingernail passed the middle which is the hottest my coolant still gets now. I am assuming it stays around that area. But does coolant temp change by a couple degrees? I also ask this because today i noticed my coolant went a fingernail passed the middle(which it has done that in the past which i saw in my camera roll) and then a little bit after it went back to exactly on half. so is this normal behavior for my coolant gauge to change by a fingernail on daily use or is it supposed to stay at one spot on the gauge and not move at all. During this drive i drove in sport + where the coolant went up by a fingernail and in comfort where it went to half again. Also i didn’t push the car at all in sport +. Sorry for the information dump. Also my car has no issues getting the coolant to get to optimal temps when i turn it on.
Old Mar 21, 2025 | 08:02 PM
W205C43PFL's Avatar
I am not as observant as you, and you being observant is a good thing, I mean it is good to find a problem (if there is a problem) and fix it before it gets worse. I have a C-Class and not the E-Class so quite a different car.
Old Mar 21, 2025 | 08:03 PM
W205C43PFL's Avatar
You know what.... I know the person who might be able to help @Keith66 do you mind giving OP a hand? I remember you got a E 43 as well right? Thanks!
Old Mar 21, 2025 | 09:23 PM
e43__'s Avatar
I know we share the same motor the m276, and a lot of the same parts except for the turbos. I think we should have a similar coolant system. Next time you go for a drive try to reach around 100 mph and stay there for 20 seconds to see if your coolant temp will go down from the usual middle mark.
Old Mar 21, 2025 | 10:11 PM
W205C43PFL's Avatar
I see, let me keep an eye on it.
Old Mar 22, 2025 | 05:29 AM
W205C43PFL's Avatar
I just realized you mentioned 100mph, I sadly might not be able to help as I don't think I ever reached more than 150 kph here in Canada as the speed limit is 100 and 110 kph here, at 100mph so about 160kph is stunt driving.
