Anyone install dual catch cans for RMS leak prevention?
I came across this dual catch can offered by 63 Motorsports, which they claim prevents the source of the issue with respect to the oil separators. Anyone have them installed and can share feedback?
https://www.63motorsports.com/afterm...ual-catch-cans
to date:
- no one has installed them and reported back any real world benefit in a thread on this forum
- no one has reported any repeat OVS and RMS fails with the new part numbers: https://mbworld.org/forums/w213-amg/...ml#post9012993
- any repeat leaks seem to be failure of the mechanic installation
to date:
Had them installed for 3 months now and driven 3k miles or so with them on.
Cons:
Poor packaging when they ship. I have mentioned this different forums/FB.
Emptying them sucks majorly and you will want to buy a manual pump fluid extractor from amazon.
Pros.
They catch a lot of oil so yeah it does what its intended.
I have a Radiator leak and when I asked a shop to check for other leaks, especially oil pertaining to RMS. There was no leaks and still no oil leaks under my car.
I'd say its doing its job. (knock on wood). Go for it.
Cons:
Pros.
Just very very annoying. Comes with a syringe. This means one pull that your hoping to extract oil from a long tube thats connected at the bottom of the can which is fighting all sorts of gravity and length.
Limited space in our engine bay obviously plays a large role.
Buy this in addition and use it to pump and its fine after that.
That would be the best evidence if an RMS leak is abated with these cans (despite how limited the data is as it stands)
sadly we don't know the real prevalence of the RMS leaks across the board to know if these cans are worth it but I can understand dropping $1500 to find out if you don't have an extended warranty
I may have to jump on this bandwagon.
Mike
Catch Cans - $1,500 before tax/shipping + install will be $2300 maybe more or less
Failure and having to go either indy to fix or stealership = from numbers ive seen thrown around here = $6K minimum.
correct; but GWC/easy care still covering 2021+ AMG e63S
**fair and you have to maintain the cans and the oil within them periodically and no guarantee these will solve anything - one report by one installer doesn't offer much but it's a start
and so far no repeat fails with new parts; and the work and parts usually comes with some type of warranty which the catch cans will not in terms of guaranteeing no leaks after catch cans installed
#1 catch can is a known device/system. It's not a bad thing. No matter what, its going to help something. But it may void a warranty, strangely. It's a great preventative device/system if you have older separators and NO warranty, but as others have said, that's anecdotal at this point.
#2 I opted to NOT purchase/install BECAUSE I have a warranty that will cover the RMS so I didn't need a potentially preventative device that may void the repair I'm seeking to avoid.
#3 it's definitely overpriced. During my research it went on sale, no particular reason given, just a few sets at a MUCH lower price point, ~$1000 iirc and I still didn't buy it. Mostly because of #2/warranty but also because if a $1600 item goes on sale for $1000. That means it's an OLD offering and new one will be coming, unlikely on this case but I have no idea, OR.... IT SIMPLY ISN'T WORTH the asking price and isn't selling so they need to move units. I do believe some people here got it at the lower price but they can chime in.
PFA
PFA
catch cans have proven themselves in the industry, that is not under scrutiny.
can these catch cans from this company avert RMS LEAKS in the 213 amg, given that MB has updated the OVS and RMS parts recognizing their previous iteration deficits?
Looking forward to more data posted.
My E63's had an upper pan gasket leak when I purchased it. The dealer fixed it, and when they were in there saw that my RMS was seeping. Since they were there, they replaced it at 36k miles. They did do the test of the OVS and they came back "good". However, if the RMS was seeping, then how good were the OVS working? So I had my RMS replaced, but not the the OVS. That was 9k ish miles ago, and since then my car has been modified and tuned.
I do have an extended 3 year 36 mile warranty through another company not represented on the boards. I have roughly 2 years and 27k miles left.
I have an appointment with my local MB dealership for Monday the 18th. Car is getting an oil change, new spark plugs, and I asked them to run the diagnostic test of the OVS as well. We will see what they come back with.
I will install the 63 CC's when I get the car back, and we can go from there.
For a motor that only has 46k miles, I am really disappointed in the seals and gaskets with this platform.
dang - valve cover eh? I've read one or two other people with that issue on this platform. It's so hard to estimate a cost since dealers can be all over the place, but usually very north $$ of independent mechanics.
What did they think of your OVS? You had them test it. And you have the updated RMS part?
Mercedes Scottsdale (The only AMG Performance Center in AZ) charges $290 a hour. Alpha Warranty only covers $210 an hour so I have to pay the difference.
The OVS tested good. I do have the updated RMS part.
It is just super disappointing that this car will have almost 10K in repairs to leaking gaskets. An upper oil pan gasket, a valve cover gasket (roughly 10k for both). Add in $5600 for an effing headlight, plus $2700 for a windshield....all in 11 months. All covered by insurance or warranty, but geez......
If I ever go with another 63 series AMG and I will probably only lease one in the future at this rate.
