Removing Wheel Weight Adhesive
Old Aug 15, 2006 | 08:59 PM
StephenK's Avatar
2006 SL600, 2001 S500, 1996 SL320
Does anyone have any recommendations on how to remove the wheel weight adhesive left behind after having the wheels rebalanced. I am trying not to damage the finish on the rims in the process.
Old Aug 15, 2006 | 11:02 PM
sprink49's Avatar
2004 S500
I had that mess on a set of BBS rims on a BMW 540. I used mineral spirits and a shop rag. I finished it off with a clay bar to blend the satin finish. Take your time..it WILL eventually come off.
Old Aug 15, 2006 | 11:26 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
wd-40 and a soft clean rag.
Old Dec 28, 2006 | 09:00 PM
Parisv's Avatar
C230K
Removing Weights
I realize that this response is delayed, but I am having the same issue. I did some digging and Oil Flo Safety Solvent/Degreaser has been recommended quite a bit. It comes in a 16 oz Pump Spray. I just ordered it from Car Care Specialties (http://www.carcareonline.com/detail....oduct_id=11001)
I'll let you know how it works. However, I assume you must have removed the adhesive by now...
Old Dec 29, 2006 | 01:35 PM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
agreed
Old Jan 4, 2007 | 10:38 AM
lorinser's Avatar
S550, C36 AMG, 911 Turbo
Try Goo Gone. Its works great for this type of job.
Old Jan 4, 2007 | 04:37 PM
sdunham's Avatar
05 E500 4matic, 08 ML320CDI
I tried "Goo Off" on my clearcoated Corvette C5 rims and it removed the wheel weight glue AND THE CLEARCOAT...
Needless to say, I don't recommend it...
Old Jan 8, 2007 | 10:54 AM
Parisv's Avatar
C230K
I first tried "Goof Off" (similar to Goo Gone) and that didn't work. However, I used the Oil Flo Safety Solvent/Degreaser the other day and it worked like a charm with no damage to wheels. It takes a little elbow grease, but not too much. I just sprayed it on and rubbed it in on each wheel, then went back to each wheel and kept reapplying until it all came off. Pretty easy, but the solvent was about $20...
Old Jan 11, 2007 | 11:50 AM
komp55's Avatar
ML550
Another excellent option is 3M Adhesive Remover.
