SSR Competitions on a C32
Old Mar 4, 2004 | 08:41 PM
Vomit's Avatar
2002 C32 Black/Charcoal
Has anyone out there tried to put SSR Competitions on a C32? I love the way that they look, they are super light, and not too expensive. I think that Speedybenz put them on his C43 (by redrilling the holes?), but I have not heard of anyone with them on a C32. Is it true that the SSR Competition for the Audi A4 (17") is a 112 X 5 bolt pattern and will fit on the C32?
If they won't just "bolt right up," do you know what such an installation would entail (spacers, etc.)? I would like to keep my stock tires, so would really prefer to stay with a 17" wheel. If 17" is not an option, how about 18" SSR Comps?
Any info is greatly appreciated!
Old Mar 5, 2004 | 09:04 AM
Luke@tirerack's Avatar
TR Moderator & Tire God
depends on the weather
I'll look into that for you and post back here
Old Mar 5, 2004 | 03:31 PM
Vomit's Avatar
SSR Comps on C32
Thanks Luke!
If they will fit without having to rape my car, you'll have a sale. Look forward to your reply.
Old Mar 5, 2004 | 04:32 PM
AJChenMPH's Avatar
2008 Subaru Legacy GT Limited
Your only issue is the hub size -- they definitely do make the SSR Comps in 5x112 (I put a set of those on my VW Passat for a track day back in October), so Luke just needs to confirm the hub size. MBZ hubs are bigger than VW/Audi hubs, so whereas I could mount MBZ wheels onto my Passat with hub adapter, it doesn't always work the other way.
Good luck, they're sweet wheels. My friend lent me his set -- Yoko ES100's in 235/40-17 on the 17x8.5 wheels. By far the best traction I've ever had at a track event, to date.
Old Mar 7, 2004 | 11:32 AM
Vomit's Avatar
SSR Comps on a C32
Hey Luke:
Is hub size going to be the problem with the SSR Comps on my C32? If so, is there a remedy?
Old Mar 8, 2004 | 06:57 PM
Vomit's Avatar
SSR Comps on a C32
According to Luke, the issue with the SSR Comps on the C32 is not the hub size. Rather, it is the offset. Apparently, the SSR Comps have a 42 mm offset, which will cause them to rub in the front. Anyone know a safe, economical solution for this problem?
Old Mar 9, 2004 | 08:26 AM
The SSR Comp will clear the brakes, BUT it is only available in a 8.5" width and that is too aggressive with the ET35 ( I located a 35mm offset wheel rather than the 42 we spoke about ) When checked the inside rim section will hit the strut.........
need to go lower offset and, or a narrower width which currently does not exist
a 10mm spacer would probably make it clear but, that is something I can not recommend .....
wheel will not fit properly
Old Mar 10, 2004 | 11:14 AM
Vomit's Avatar
Thanks Luke!
Too bad, I really like those wheels. You aren't kidding about the strut tower-I never realized how close it is to the front wheel! Anyways, thanks for checking.
Old Mar 10, 2004 | 08:09 PM
430's Avatar
430
SLK32
SSR Comps on SLK32
Luke, any chance of the SSR Comps working on an SLK32?
Old Mar 11, 2004 | 12:39 PM
nope ... same issues
