Front brake rotors
Front brake rotors
I'm getting a quote for $570 PER front rotor. Aren't there any alternatives? I can't seem to find an aftermarket replacement anywhere.
2003 Chevy Tahoe
Sorry my friend. We seem to have the one vehicle for which there is not a big aftermarket. I just did my entire brake system. Went with Goodridge Stainless Steel brake lines, Porterfield P4S pads, and OEM rotors front & rear. I can PM you the name of the vendor I used. They aren't cheap by any stretch but they are good.
That's a little on the high side. that's how much the black series rotors are. you should be able to find yours in the 400-450$ range. There are a few aftermarket options for the 2 piece rotors but they're not cheaper... so stick with OEM.
Hi,
We sell the Zimmerman Coat Z crossed drilled rotors for the front for $115.86 each and if you need the rear we have the Genuine rotors for $185.55 each.
Here is the link for the parts on our site:
AutohausAZ - Rotors
Disclaimer: Make sure to check the year and model of the vehicle before placing the order.
AutohausAZ - Rotors
Also Adam's rotors. I have his vented slotted rotors on the rear of my GTI. But don't pay for his hub coating, it's crap. Base rotors are $250/pr front, $225/pr rear, or $375 for all four.
http://www.adamsrotors.com/15259/0/0...cedes-clk.html
RockAuto.com They have amazing prices. I purchased cross drilled and slotted front rotors, Pads and sensors for right around 400.00 dollars for both sides. This was for my CLK 500. This is not 400 a side, This is for both sides! (Front)
Keyless go start push button
Question?
My keyless go wont start my car when pushing the button on top of the shifter. Everything else works just fine. Sometimes the push button works, But most of the time it does not?? anyone have this problem and knows how to fix it.
Former Vendor of MBWorld
check our light weight two piece rotors for 05-06 CLK55 AMGs
https://www.racingbrake.com/ProductD...oductCode=2270
Our two piece rotors shave off 5.95 lbs improving your handling, steering, and braking performance. (5.95 lbs per side!)
In the future when its time to replace your your rotors, you may purchase the rotor ring to save you a fraction of the cost. We provide you with all the necessary components needed to change your old rings to the new.
Check out some of our MB customer reviews
Racing Brake makes me happy
World's First: RacingBrake 2-Piece Brake Rotors ...
The Ultimate Rotating & Unspring Mass Reduction Thread ...
E63 Front Rotor Replacement DIY - RacingBrake
https://mbworld.org/forums/sl-class-...squealing.html
Hi,
AutohausAZ - Rotors
AutohausAZ - Rotors
If your looking for performance and cost effectiveness in mind,
Thanks, I think this is a solution. While they're not much cheaper, that 6lbs of savings is at least a nice upgrade!
I have a 2007 CLK350 convertibel with 9500 miles. I have owned it for 1000 miles and am concerned about the brakes. It doesn't appear there are enough miles for them to be worn but when stopping I notice a definite pulse/vibration. Is this pulse a normal feel for these cars?
MBworld Guru
Being a cabriolet, you'll feel a bit more "imperfections" than you would in a coupe, but no, you really should not feel any pulsing. It could be a bad rotor, but suspension issues can also cause this.
MBworld Guru
Storing should not warp rotors. On some cars that use the disc brakes for the parking brake, that can happen, but not on the W209. It uses an internal drum on the rear rotors for the parking brake.
CLK55 Cabrio, Honda Accord 05 had CLK430 Cabrio
CLK500, we do have them available. $9.60 each for Genuine Mercedes and
$4.31 each for OEM Pex. Let me know if there is anything we can do for you.
Brake Pad Wear Sensor
Hey Kevin, if you're looking for the brake pad wear sensor for your 2006
