Oil change
ML 350 2014
Oil change
Besides MB dealership what oter places you used to do oil change?
Something like Sears,BJ .... What your expirience and price? Also what is the price to do it in MB dealership ?
Can't comment on other places, but since it's synthetic oil it will be at least 70-100 bux I would think.
At MB it's called service A which is 250-300 bux. I know it's a lot for basically what an oil change but it's also MB service history which should help the resale value later on. Also while car was serviced I asked to fix tailgate issue which took over a day, and I had C-class rental to do my errands.
2010 GLK350 4matic and my favorite Vintage 1982 PK Ripper Looptail
Fleece filter
about 8 bucks online
mobil1 0w40 oil
you extract the oil with topsider or griots extractor. No need to even crawl underneath and use the drain plug. The dealer does not use it so why would you
Do the rest of the fluid and visual inspections reset the service indicator fill in the service booklet
no problems
mobil1 0w40 oil
no problems
The crank case should be obvious but the oil filter not so. When you open the hood there is a plastic 2 piece cover over the engine. The front piece closest to the radiator needs to be come of and the filter is right there. The filter is not your traditional one, it is fleece filter as ohlord mentioned. The fleece filter is a inside what looks like an oil filter shaped container (you only buy the fleece part). In addition there are "O" rings that should come with the filter that need to be replaced (without nicking them). As far as siphoning or draining I prefer to drain more difficult but I think it might do a better job of getting out all of the old oil and possibly and contaminating particles floating in or near the bottom of the pan.
I agree with MkenM; any metal shavings in the crankcase will probably not get picked up by a siphon but they will go out through the drain hole.
Do it right or don't do it at all.
CLS63, GLK350
mobil1 0w40 oil
no problems
mobil1 0w40 oil
no problems
My dealer had a promotion of a free Oil/Filter change and inspection. They had it on the rack and pulled everything off the bottom and drained and then put it all back. Did 8-9 qt's of Mobil 1 0w40 and went over the entire vehicle. The price was also great. Only had 2500 miles on car so it was nice to get out the old stuff and start clean. Car was 9 month old since the build date.
9 months old with 2500 miles? You drive as little as I do; ain't it great?!
2010 GLK 220CDI 4M BlueEFFICIENCY
In accordance with STAR TekInfo, March 2009 Mercedes-Benz Reset Service Indicator Guide: http://www.startekinfo.com/StarTek/o...tedDocId=10502
That's one of the reasons I don't lease cars; at 4K per year max I'm giving them back almost half the cost of the lease when I turn it in!
2011 E550, 2013 GLK
BTW, I drained my oil for years but with two new knees, I had to give that up. I started using an extractor and I believe that if gets as much out as draining it.
Unless you do it yourself, take it to a dealer. It won't cost that much more and you'll get the right filter and oil and it will be done by someone who hasn't spent the day working on front wheel drive econo-boxes.
Guess I'm old school, but I always use the drain plug. Here's some pics after changing my wife's oil earlier this month.
The oil filter is located inside the round black plastic cap.
This is what it looks like after you take it out.
Mercedes uses Mann filters at the factory.
Here is the drain plug (you have to remove the lower engine compartment paneling)
This is what a filter and copper washer will cost you at the dealer.
-Nick
-Nick
Yes, if you buy a Mann filter it comes with the 3 o-rings. Not sure about other brands.
The Mann filter is under $10 if you shop around the internet.
Autozone was having a sale on Mobil 1 earlier this month, so 9 quarts was $50ish if I remember correctly.
The dealer doesn't own my car so their convenience is probably more important to them than doing the best job possible.
Metal shavings are trapped by oil filter. Anything too small to be trapped there is meaningless and harmless. (And will probably go up the "siphon" tube, too.)
Of course if you've seen the dealer extraction equipment, you'd know there's not a "hose" stuck down the dipstick tube. It's just a vacuum fitting at the top of the tube. It's a pretty big tube.
Vacuum extraction is universally considered by professionals as the superior method--it's simple paranoia and ignorance to just label it "convenient."
I support MKenM's view on procedure to be followed.
As for paranoia and ignorance, I'm hoping my ME obviates the one and my years of therapy the other!
So let me see if I understand, I have a full glass of soda and a straw, following me so far. I put the straw half way into the glass and proceed to enjoy the soda. This must be a not so fattening soda because I only get half the calories.
OK, they do it by vacuum. I don't think that they get all the oil no less all the metal. Maybe the reason for a magnet on the drain plug is just for that, to pick up some of the metal that doesn't make it to the filter.
Vacuum or drain plug which is quicker. I know the answer. Quicker isn't always better but it is a way for a high volume service department to work more efficiently and charge us more money. Isn't that what its all about $$$$$$$$$$$$$$
I'll take my car to my old fashion mechanic, give him the oil and pay him $20 bucks for which he supplies the filter and let him change the oil and rotate the tires.
When all is said and done we're both satisfied and I have the peace of mind knowing that I watched him do it in what I consider to be the right way.
