Ezs problems
Mercedes w220 S500L 1999
Ezs problems
Hi, I have a 1999 s500L w220, yesterday my battery goes down and i thinks the ezs now fault, I recharge the battery to 12,7 volts so now when I put the key into the ezs nothing happened and the key can't open/close the doors, I never had problem with the key or the ezs so the last owner says that he have problems and replace the original ezs and key with an used one, can someone help me? Thanks
2006 S430 4Matic
You can't replace the key with a used one because they are coded to the car. Once programmed it can't be changed. Either new batteries of new Key. A key is $250 us. Go to a dealer to get it done.
Will the key turn in the ignition switch (EIS)??
(If it was working before the battery change then the battery may still be the issue.)
Read post #4 from our encyclopedia on the opening page of the forum.
Good luck,
Bob
Good luck,
Bob
thanks to reply, i cant buy a new key cause the last owner change the ezs-key-ecu with used parts after a ezs or key problem i dont know, i dont buy a new battery only charge mine until 12,7 volt so nothing happened, i also tried to connect another car(2,5l diesel with 100a battery)with a 300A cables so dont change the situation, maybe the ezs lost the key programming after the battery fault?or i need to put a new battery?thanks
Find someone with start diagnostic and do a scan. it does sound like you key info is lost, seen this happen in old cars like your model. you might have to read the ezs and make new key, or buy another used ezs with key.
If you are getting parts from a wrecked car you need a matched set of all four parts- key, ignition switch , ecu and shifter . Without swapping all four parts it will not work
