SL/R230: Bluetooth capability?
Is there a way to get your iPhone to play music using Bluetooth instead of using an ancillary cord? Has anyone figured this out yet on their SL?
To play music the bluetooth receiver has to have A2DP capability. Most cars before 2009-2010 don't have that. It can't be added normally. Something like this could be added through the aux connector though.
I have one of these. It works great with my iPhone. You simply plug it into the glove box 3.5mm socket and pair it with your iPhone. Switch your radio to AUX and enjoy. Great sound too.
http://www.ebay.co.uk/itm/Wireless-B...item27e4cff7da
iSimple ISFM22
Check this item and model number on ebay or Crutchfield. I just put one on my SL and wired it under the dash. It plugs into the AUX jack just like the others. Difference is that it is powered by the car, NOT a rechargeable battery. The ones referenced above (I've tried them) are a royal pain in the butt because you have to repower them on AND reconnect in your phone's BT options EVERY time you get in the car, even after running into the cleaners for five minutes!!! Also, the sound is stronger with this car-powered unit...a whole lot closer to the radio/cd sound level.
AUTO-RECONNECT is the only way to go. This model does not have phone call (microphone) but they have a model that does have that, ISFM 2301 or something--I just didn't care about phone, only music.
It has Aux plug
Sorry I did not mention, this unit I installed DOES plug into the AUX input. It has dual (red, white) RCA outs and you will only need a dual RCA to 3.5mm adapter cable for the AUX input jack. I got one at Radio Shack that was 24 inches and just kept it coiled up, but if you order with the unit from eBay or Amazon you
can get a very short cable that will be only 6-9 inches and more convenient to use. Remember the cable must have male rca's and male 3.5mm AUX plug.
Good luck,
Good luck,
I just bought a 2008 Sl600 and it has the blutetooth module in the center console, but I don't have an aux jack in the glove box Is there anyway to connect an aux cable to the deck unit?
Anyone try the Visseo Tune2air WMA1000 Wireless Bluetooth Music Adaptor?
From manufactures web page
Plug and Play
Wireless connection with Apple device via special Bluetooth technology with automatic reconnection
Compatible with Audi AMI, Mercedes Media Interface and VW MDI or any other cars with the original or aftermarket iPod integration installed that has a 30 pin iPod connector(WMA1000).
Support Airplay and A2DP Bluetooth music streaming protocol.
Read and display entire iPod library from your iPhone, iPad and iPod touch on car display.
Access and control the playlist via multi-functional steering wheel.
Keep connected with the Bluetooth handsfree devices while in connection with tune2air at the same time.
Plug and Play
