dumb question- trouble opening hood???
I pulled the hood release lever and hear the clicking noise but i look all over in the grill slots on the front and cant find the lever to pull on to open the hood???? others have quickly opened the hood on my vehicle so am i just not able to locate the lever or whats going on? lol is the lever clearly visible or is it really hidden to open the hood on the e55?
Get a flashlight and look. Upper right center. There are 2 hood cables and they do stretch. Mine were maxed out and had to replace them.
I tried to open it today and just can't find the damn latch!! Mechanic opened it quick few months ago but damn I don't find anything to pull to open the damn hood... I looked through the slits too.... I attached pics of left and right side
I pushed hard to close hood but are there any risks of driving around if the hood isn't properly closed?? Thanks
It's right there. Top center on the right. See that black shadow back there? The is a T that sits at the top of that grille opening. I just pulled mine down by hand without popping the hood.
You can look and make sure it's there. I would pop it and see what happens to it. It's possible it's stuck to the grille. It's got a channel it sits in and is suppose to pop out when you pull the release inside
ok i will try to search in that section and find something aftering pulling the release in the drivers side....i should be pulling it towards me? i looked in there before and couldnt find anything but i guess ill try again,
is this a costly repair at the dealer since the tab isnt popping out when i pull the release?
