GT/C192/R192: New GT55, thoughts from a previous C63s owner
Next up is some appearance work. I really want a discrete spoiler like the Brabus one that I recently saw online. I also have a $1k ceramic coating package that I have sitting before I got this car with the matte paint. I’m reading both ways, some places say not to mess with ceramic on matte cars.
Obviously I dont have a dyno to prove this one way or the other but if I felt a loss of power on my roads where I test the car to about 140mph; I would revert back.
The install is not fun
Sounds like someone just didn't want to do it and feed you a line of BS.
There are quite a few videos from experts on YT about the BS back pressure myth on turbos... I need to post that up.
My guy is straight chop style in Santa Ana = 300 but no exhaust leaks
The Renntech Valve Controller does make a difference. You can do the ACC start up mod so that its open on firing but once you start driving in low rpms the valves do shut and open based on the rpm range. Mine never close ever.
Here is a vid of the RT rear can section = not loud enough vs stock.
Its on the SL but same sht
https://www.youtube.com/watch?v=V4VhSICcM9w
I do see your guy did go a different route than mine did.
Mine used the non valve section to be more thru and thru... 6 or 1/2 dozen
Cheers
Last edited by G63GT63SE; Aug 8, 2025 at 10:59 PM. Reason: Directed question at OP
Cheers
