Sponsored by: Innova
Keyless Go and Trunk Closure aftermarket
Old Nov 4, 2005 | 01:50 PM
sfgirl69's Avatar
Does anyone know if you can add Keyless Go aftermarket?
Also had I known the trunk was going to be so heavy and hard to close I would have gotten automatic trunk closure feature. So same question for that one, can I get it aftermarket?
I should have just gotten it all when I ordered it, oh well live an learn and hopefully add later :-)
Old Nov 4, 2005 | 02:54 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
The Trunk closer Can be done By Steve @ www.mbenznl.com
He has done several!
The Keyless go can be done ..BUT it will cost You a FORTUNE!!!!!!!!!!
Old Nov 4, 2005 | 04:16 PM
benzmodz's Avatar
W203 slightly modified
For keyless go to make any kind of sense in dollars it needs to be done with as many mods as possible so that the costs even out. Even then you need to really have a long chat first.
Old Nov 4, 2005 | 05:04 PM
sfgirl69's Avatar
Thanks for the tip guys!
This is my first Mercedes, I seem to have a large learning curve when it comes to these beautiful cars. I am still trying to fingure out what W209 means? LOL
Old Nov 4, 2005 | 06:20 PM
benzmodz's Avatar
People often ask me "how hard is it to install options into my car"
reply - Just hand over the money and go for a walk.
Old Nov 5, 2005 | 03:35 AM
MBenzNL's Avatar
Former Vendor of MBWorld
some slow@$$diesels
trunk closer: yes...check this link (W211 E-class)
keyless go: no
greetingz,
Old Nov 5, 2005 | 06:31 AM
z1co's Avatar
Steve, how much for trunk closer on my W209?
Old Nov 5, 2005 | 10:37 AM
M1M2M3's Avatar
Mercedes
could this work on a w208?
Old Nov 22, 2005 | 02:40 PM
davew's Avatar
have you guys actually looked at the keyless go systems and tried to retrofit? or are you just repeating what you have heard. I ask because everyone said the same thing about a few of the other cars I own that come with keyless go in europe but not US. After doing a little investigation and reverse engineering we determined that all the electronics were already in place in the US cars. all that was needed was the addition of the switch and some wiring and we were good to go. I now have 2 cars with keyless go that didn't come factory with it and each was about $300 to do.
so my question really is: has anybody traced this down in a newer model to see exactly what is present and what is missing in models between and without keyless go??
dave w
Old Nov 22, 2005 | 08:48 PM
dave w
Where did YOU get Your Information from?...Mercedes does NOT Pre install the Electronics in the car...Please correct me (IF) Im wrong!
$300.00 yeah right....Price out the Keyless go door handles...and shifter?
And the remotes/control unit.....Just one WILL Be over that
Those are NOT Pre installed
Old Nov 22, 2005 | 09:11 PM
SUNILP's Avatar
2015 E250D
Mark, you are absolutely correct. The handles alone are more than 200 EACH!!!! Plus the rear bearing at 80 EACH. That's more than 500 in parts for just 2 doors and you still need 4 control modules, 5 antennas, harnesses, ignition switch, etc... Trust me. There is no way you will get a keyless go system for less than 2 grand plus key. The mercedes key system is much more sophisticated than a normal metal key.
Old Nov 22, 2005 | 09:50 PM
rrpnow's Avatar
2006 C230 SS
i think he meant 3000...
Old Nov 26, 2005 | 04:11 AM
MBenzNL's Avatar
some slow@$$diesels
he probably meant 300 allright - but has a completely different "keyless go" then whatever is refered to when talking about option code 889 keyless go.
greetingz,
Old Nov 28, 2005 | 01:09 PM
sfgirl69's Avatar
So then what Keyless go is he taling about?
And can it be used the same as the 889 option?
Old Nov 28, 2005 | 08:52 PM
SUNILP's Avatar
2015 E250D
he must be referring to a aftermarket system for "other" cars. There is NO WAY you can make any other system work with the benz. You have to use all Original MB parts for keyless go.
Old Nov 30, 2005 | 06:34 PM
freakinfreak's Avatar
2009 BMW 750i, 2008 Toyota Prius
dave w
Maybe keyless entry? Remote start perhaps?
Old Nov 30, 2005 | 11:25 PM
Kev04C320's Avatar
'09 911 C4S
yeah, the GM version of Keyless Go...
Old Oct 7, 2009 | 09:03 PM
TxQTPi's Avatar
Mercedes CLS 500
What part numbers do you need to install the Keyless Go to a car that doesn't have it installed. I know I can buy the shifters online, will I need a module, antennas and amplifiers... How will I program my Key to work with it? Very interested, please respond.
Old Oct 8, 2009 | 08:17 AM
rob13572468's Avatar
PREMIUM SPONSOR
ML350, Lotus Elise
antennas, module, door actuators and modules, KG keys... oh and a full harness will need to be built (or you can buy new vehicle harneses for $4500).. you will need access to a dealership SDS machine to code the vehicle as well as to program the key track to the KG module. the aftermarket or bootleg SDS copies will not work for programming KG.
Honestly you can expect to pay around $5000-$8000 to add it... if you really are serious about doing it we can build you the harness if you dont want to order a whole new vehicle one...
Old Sep 24, 2012 | 04:58 PM
Fat Freddys Cat's Avatar
2007 ML350
Keyless Go
I guess it pretty much depends on what you have to start from. My ML350 has already holes poked for the 2 (!) front doors. ( Who the hack needs 4 doors to close the car ???? ).
Hardware to be modified / changed :
1. Install * close * buttons on the 2 front doors. ( I assume the electrical wires are already installed ) : $150
2. Install Start / Stop PB , $ 200
3. Install antenna. $ 100
4. Control unit $ 200
5. The keys probably work with the control unit already.
this is all what is required to modify my 2007 ML350 for option xzy original MB keyless go. I will get a MB prize this days.
I don't see there $ 5000 - $ 8000, sorry.
Old Sep 24, 2012 | 05:04 PM
yikes's Avatar
06 e350 17 glc300
i dont think steve from mlbenz is in business anymore. i have emailed him 2x and was never responded to although his web site is still around
Old Oct 6, 2012 | 09:55 PM
kjb55's Avatar
2025 AMG E 53; 2018 GLC300 4Matic; 2003 360 Modena
That would be a real disappointment if he has moved on. I worked closely with Steve for over 3 years doing my mods.
Old Oct 6, 2012 | 10:39 PM
yikes's Avatar
06 e350 17 glc300
yes that would be disappointing, but unless he decided he did not want to respond to me purposely....im afraid hes no longer in biz
Old Oct 8, 2012 | 11:39 AM
MBENZNL
Steve is still doing mods,He has Not been to the states due to the demand and his family
Check out his site MBENZNL.com LOT of Current Mods
He is on the German sites as well MERCEDES FORUM.NL
Old Dec 25, 2013 | 08:42 PM
BeaverMjr's Avatar
2015 C350 Coupe
keyless go
My buddy got a ML350 and when he picked it up, the dealer installed the keyless go button in the ignition. Can I buy one and go keyless or is there a whole kit that needs to be bought?
I don't care about the doors. I just want the button.
