Sponsored by: Innova
COMAND 2.5 Reverse engineering project
Old May 8, 2022 | 11:11 AM
tim687's Avatar
CL 600 '00 5.8L V12
This thread is home to my attempt to reverse engineer the COMAND 2.5 Firmware.
The MY 2001 software update stores the binaries unencrypted and with symbols so I think there is a high chance that the flash/eeproms will just contain the raw binary firmware.
For those who don't know, the COMAND 2.5D is devided into to devices, the radio/tv/tape/telephone and the navigation system. Both devices use different bioses/firmwares.
I'll refer to the RTTT and NAV bios from now on.
Why do I want to reverse engineer the COMAND 2.5D's firmware?
  • It's fun, so why not?
  • To finally understand the DX navigation cd structure
    • To create custom up-to-date maps for the system
What do I know at this point:
  • The MY01 update CD stores the firmware delta (I assume) for the flash/eeprom chip in a file.
    I'm not sure if the disc also stores the navigation system's firmware, but several users have said that they could look up an address by ZIP code after applying this update
    • ODEM0718.DNL
  • One of the (I suspect many) processors inside the device is the Renesas V850E2M.
  • All the .EXE ELF files (either on the update disc or on the navigation disc) contain the V8xx header. This CPU is recognized by all the decompilation tools I tried.
Opening the COMAND 2.5
In order to seperate the NAVand RTTT systems, you'll need to undo these screws, on both sides
Seperating NAV from RTTT
To seperate the RTTT from the screen, remove the screws on both sides of the unit and remove the top lid. Use a flat head to carefully pry it loose
Seperating RTTT
To remove the screen, unscrew these screws and remove the ribbon cables
Screen removal
Screen removal frontpanel
Disconnecting screen cables
Removing the PCB's
Unscew all the screws at these levels on both sides
Then unscew and remove the cover of the RF connector and disconnect the screw of next to the D2B interface.
RF and D2B
After removing the 3 connectors, you should be able to seperate the first PCB from the rest. Make sure to be very gentle with the connector and PCB.
Power and data
To remove the PCB tray in between the last two PCB's, unscrew the following screws
Remove the power supply PCB. Be very careful with this! The board can break very easily and the pins can damaged too.
That should reveal the last PCB in the RTTT unit, when you do want to inspect the last PCB's bottom, please remove the bottom of the COMAND unit itself. It will pop right off, you are not able to remove the PCB from the housing unless you desolder it.
NAV Unit
To remove the CD reader from the NAV unit, remove these screws
Remove these screws and the ribbon cable
And the CD reader should lift out and put it on top of the NAV unit. BE CAREFUL since we haven't disconnected everything yet.
Disconnect the final cable and the CD reader is out
There is the main PCB of the NAV unit
Old May 8, 2022 | 11:12 AM
tim687's Avatar
CL 600 '00 5.8L V12
Printed Circuit Boards
You can find the raw pictures here: https://archive.org/details/pcb_20220513
Tape PCB
Tape PCB Dolby chip
I/O board
(LCD) Power supply board
Main control unit
Navigation CD drive
Navigation system
Old May 8, 2022 | 11:13 AM
tim687's Avatar
CL 600 '00 5.8L V12
  • Tape PCB
  • I/O board
    • 2x Texas Instruments R50642FNA
    • ST Microelectronics TDA7338D (SO20 package) Stereo decoder: (TDA7338.pdf)
    • Motorola MC33079D Dual/Quad low noise op-amp: (MC33078P.pdf)
    • 8409-005
  • (LCD) Power supply board
    • Motorola 9 825 904 475 (4475DP0430); I can't find any info but I assume this is a CPU/MCU of somekind
    • Philips 74HC2400 Octal butter/line driver; 3-state; inverting (74HC2400.pdf)
    • Texas Instruments 5001C PWM Control circuit (5001C.pdf); I can only assume that this IC is used to control the brightness of the keys/LCD
    • Texas Instruments C3931: op-amp?
  • Main control circuit (4 layer PCB)
    • Blaupunkt FIS 3-MCM 8638340559A02 6104/1/2/R=
      • 16-bit CPU
      • Acording to cardumps.net, we can read this chip using by an 24C32 compatible I2C eeprom reader
    • Intel TB28F800 B5B90 Flash (with a firmware version sticker (965.28 ne, 03.04, 86122004406)) (TB28F800 B5B90.pdf)
      • This is my target
      • It's strange because most of the traces of this chip go to the BoschHD6437034E13F chip
      • I can find references to this chip in the firmware files present on the update disc MY-01 (MY01.zip)
        • I found firmwares of the Skoda MFD2, which also uses TravelPilot DX discs and in there are references to this chip too. I think it's safe to assume that all of those systems are basically the same system, but have different user-interfaces
    • NEC 90420
    • Philips 8583T RTC (8583T.pdf)
    • Texas Instruments 7751: voltage supervisor
    • Motorola ZC423273CFN
    • BoschHD6437034E13F
      • SuperH chip, using Sh-2 instructions
    • Bosch HG62G027S47FB (GRAFLOG); I assume this is somekind of GPU (GRAF=>Grafik?)
    • Bosch HG51D562CP (CLUT)
    • Intel AS82527 (AS82527.pdf); this is the canbus interface IC
    • 2x Philips TJA1053 (TJA1053.pdf); high speed can transceiver
    • 95BH LM-2903M: Dual differential comparator (LM2903M.pdf)
    • Siemens HYB5118160BSJ-60 (HYB5118160BSJ-60.pdf): 1M x 16-bit RAM
    • Hitachi A118104 Tripple video switch (HA118104.pdf)
    • ST Microelectronics 4949ED Low drop voltage regulator (L4949ED.pdf)
    • Texas Instruments DS892 Differential Line Driver and Receiver Pair (DS8921.pdf)
  • CD Drive
  • Navigation system
    • NEC 8 925 904 154 003KU207 (TEGA)
    • NEC V810B7B-25 (I'm not sure if this is the V810 processor that Is refered to by some of the binaries on the nav cd)
    • NEC D24260G5-60G-7JF
    • NEC D63724BGM (CD-ROM decoder)
    • NEC 784035YGC812 (784035YGC812.pdf)
    • Texas Instruments SN74ALVC164245 3-state level shifter (SN74ALVC164245.pdf)
    • Fairchild MM74HC (MM74HC.pdf)
    • OKI M9842 LSI Playback IC (MSM9842.pdf)
    • NEC D4218165LG5 (D4218165LG5.pdf)
    • NEC D424260G5 (D424260G5.pdf)
    • AMD 8925904554 (4554-96707); NOR flash
    • AMD AM29LV16001 (AM29LV16001.pdf)
    • AMD 8925904553 (4553-96707) NOR flash
    • Texas Instruments HB244 (HB244.pdf)
    • MAX 706TESA-949 (MAX 706TESA.pdf)
    • Fairchild P01AF
    • Texas Instruments TVL1544I
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: rar
Old May 13, 2022 | 09:14 AM
tim687's Avatar
CL 600 '00 5.8L V12
Reserved #3
Old Nov 14, 2023 | 02:35 AM
raez77's Avatar
w220 s320
how to update firmware please help
Old Nov 14, 2023 | 04:47 AM
GreasedFolgore's Avatar
2025 Maserati Grecale Folgore and 2024 Jaguar F-PACE SVR
      • This is my target
      • I can find references to this chip in the firmware files present on the update disc MY-01 (Attachment 434393)
I loop mounted the ISO and loaded the bin into a hex editor. Not sure what there is to reverse engineer. It's a 2002 Navigation system firmware update for a 2001 vehicle. If you had a few bin files you could diff them to locate where values are stored within the file, though. Then you could, say, change default settings and flash the file back... before resoldering it back onto the board. Sounds like a lot of work for an old car to me though.
Old Nov 14, 2023 | 06:48 AM
tim687's Avatar
CL 600 '00 5.8L V12
Yeah, I think we should give reverse engineering the .exe file a try. They are ELF files, which is the basic executable that one runs on a CPU
Old Nov 14, 2023 | 09:37 AM
I guess you could try a disassembler on the executable or its libraries. That might give you the names of some functions the update program uses. But without knowing what software they used to create it going any further sounds like a pain. I'd personally just stick with working with the flash chip. Take a before and after image and diff them. If you know something specific that changed, search for those values in the diff areas and tada, you can now modify that value to what you want instead of what they want.
I'm not as familiar with all the hardware as you but I've used stuff like this in the past to avoid desoldering and resoldering (lol, spell checker says those arent real words):
Old Nov 14, 2023 | 07:14 PM
I mean, the tools never get updated past chip obsolescence so it'll likely end up being an exercise in running old OS version in a VM with USB pass-through. Just as an example that really has nothing to do with this, I recall trying to get VADIS running so I could **** with my 2003 Volvo S80. It's even a Windows app so how hard could it be? Well, when it was written fully integrating Internet Exploder, er, Explorer into the OS was still a major focus at Microsloth. And VADIS relies on IE DLLs to run... so TL;DR version: I ended up having to run Windows Vista inside VirtualBox on my Linux PC and that's was just to get STARTED fookin' around with it.
Old Nov 16, 2023 | 01:47 AM
tim687's Avatar
CL 600 '00 5.8L V12
I've already probed around with such a firmware extraction kit and the binary that I've posted is what I could get off the EEPROM.
Based of the research that I did online, there is another piece of storage inside of the Blaupunkt chip, which holds it's firmware.
Have you got any experience with Ghidra?
Old Feb 29, 2024 | 03:44 AM
tim687's Avatar
CL 600 '00 5.8L V12
Any updates on this?
Old May 31, 2024 | 01:30 AM
GabeS06's Avatar
2002 CL500
Any updates to this? W215 here and I've been trying to dig around on it because there are some minor differences on the W215 COMAND 2.5 than listed for others that I had found, but I have had no progress other than some update CD files' assembly code showing up and some not. Nothing interesting.
EDIT: I ran Ghidra, and I exported the Ghidra Zip Files. I didn't realize on Ghidra it exports as 2 different programs? Here is the first, and here is the second. They seem to be different but both were extracted from the MY01 Update Disc COMP_DL.EXE file. Is this useful to anyone?
