how many K from factory xenons?
Old Mar 9, 2005 | 09:33 AM
inFiniTE LooP's Avatar
2005 Volvo S40 T5 AWD, 2004.5 C230 Sport Sedan, 2005 E320 CDI, 2008 C300 4-Matic Luxury
k, so i did a search and have gotten that factory mercedes xenons are anywhere from 3200K to 5000K and everything in between (4000 and 4200K etc...) so which numbers are correct? thanks for any input!
Old Mar 9, 2005 | 10:48 AM
brabusCcoupe's Avatar
Talking
Contact GASTON REY
786-412-0302
gastonrey@bellsouth.net
He should be able to get you some for less than US1500.00 new. Tell him Mike BrabusCcoupe sent you and hell help you out.
Good luck.
Old Mar 9, 2005 | 12:10 PM
bizdee's Avatar
a C
Are you referring to the Kelvin measurement of the factory xenons?
Old Mar 9, 2005 | 12:24 PM
yes i am
Old Mar 9, 2005 | 12:25 PM
Originally Posted by brabusCcoupe
Contact GASTON REY
786-412-0302
Good luck.
does he do the installation as well or just provide them and i would install them on my own? thanks~!
Old Mar 9, 2005 | 01:21 PM
CitronC230K_03's Avatar
2003 Citron Green C230KMT
4300k (or somewhere around there) i believe. you dont want it too high otherwise it defeats its purpose.
Old Mar 9, 2005 | 01:48 PM
str8ridin's Avatar
05 E55
Correct, 4300K is the somewhat standard. The bulbs, depending on whether they are a DS2 or DR2 and if in a projector assembly or regular housing will look different depending on the bulb/housing. If you want to upgrade, 6000K is the best/max for color and brighness, however anything over that has been proven to produce more glare than anything.
Old Mar 9, 2005 | 01:50 PM
factory BiX on a W203 are DS2.
Old Mar 9, 2005 | 02:00 PM
mbny's Avatar
08' BMW E92 Coupe
i have the 6000k philipps ultinons in my 330 and they're pretty sweet. bmw offers two different stock xenon bulbs. Osram 4100k and philipps 4300k. i was one of the unlucky ones to get the osrams and they sucked. i compared them to my infiniti I30t's (had it at the time) w/ PIAA halogens and the PIAA's actually looked better and offered better visibility. i don't know why but the philipps 4300k looked and performed noticeably better. had my car come equipped with those, i wouldn't have spent the money on the 6000k's. Personally i like the Osram Xenarc 5400k's. If they still make them, not sure. I believe philipps ultinon 6000k's actually burn at 5800k or 5600k. something like that. anything higher than that and your gonna really notice a loss in visibility, especially in wet weather.
Old Mar 10, 2005 | 11:34 AM
PsssTkiD's Avatar
'02 c230k coupe
how much kelvin does factory halogen have? 3200k?
Old Mar 10, 2005 | 09:59 PM
blkc230k's Avatar
2005 Obsidian Black C230 Komp Sports Sedan, 2006 Iridium Silver ML350 SUV
VERY CORRECT! note in wet weather....it will just shines on the rain/show/fog and wont shine thru them... thats why the fogs are yellow
Old Mar 10, 2005 | 10:07 PM
mbny's Avatar
08' BMW E92 Coupe
here's what i've noticed with the 6000k's in wet weather. street signs and parkway signs illuminate great, but the road itself does not. except in the snow, then it looks cool as hell
Old Mar 10, 2005 | 10:48 PM
ok, so i think i'm gonna get the H7's from PIAA that are rated at 4000K, they should be the closest match to factory BiX. so as for the fogs, you would recommend not changing these out since the stock ones are meant for shining through fog and changing them to match the other lights would in fact make it more difficult to drive through the fog than the stock ones?
Old Mar 10, 2005 | 10:56 PM
PsssTkiD's Avatar
'02 c230k coupe
i changed my foglights to same as the piaa~4000k, i didnt really have any problems on fogs and rain. BUT on regular days, its really better
Old Mar 10, 2005 | 11:35 PM
mbny's Avatar
08' BMW E92 Coupe
with the 6000k's it's really not that much of a difference. i've been in car w/ 8000k's and it's ridiculous the difference over stock. you'll be ok w/ 4000k PIAA's. I think there's even a real xenon bulb in the mid 3k range that supposedly provides great visibility when used in your fogs.
Old Mar 11, 2005 | 01:23 PM
Tariq's Avatar
S500 W223 2021
Any one have an idea on any online store that i can get the 6000K ?
Old Mar 11, 2005 | 01:34 PM
mbny's Avatar
08' BMW E92 Coupe
there should be a forum sponsor that sells them no? i got mine at hids4less.com but last i checked they were out of business. sorry i can't help you out more.
Old Mar 11, 2005 | 01:37 PM
8000k is way too purplish. defeats the purpose of having Xenon for safety.
Old Mar 11, 2005 | 02:05 PM
1Lop2K5C's Avatar
C63
Correction ! the bulb types are D2S and D2R, the S is used in projector housing and the R is used in reflective type housing (there are also the D1 series which we wont talk about). Here is a trick that I learned: if you want to make them blue (meaning that from down the road, you want people to see your lights appear to have more blue hue) pull the shield a little more closer to the front of the bulb, this way you will not have that yellow/brown spec that you see right where the cut off is. This trick will not effect the amount of light or the color of the light below the shield.
ps. here is an example of the diff type of bulbs are out there http://www.ambulbs.com/products/category.php/CA=4
