BRAKE Pad, Rotors, & Calipers Discussion Thread (OEM, aftermarket, etc...)
The only advantage of the MB pads is they are cheap, about $50. Actually on my 2004.5 C230 SS with the 4 piston calipers, I get very little dust from MB pads. It's the cars with the single (2001-2004) or dual piston (2005+) calipers that get tons of dust from the MB pads.
As for using Simple Green on aluminum wheels, its corrosive to aluminum, I wouldn't use it for that. I use Eagle One A2Z Wheel/Tire cleaner and it works great on removing dust on the tires and wheels. But just because it does a great job at removing dust doesn't mean I want to spend my time doing it.
Majority of people have had good experiences with either OEM or Porterfield.
Akebonos seem to be getting a good reputation also.
If you read through this thread (merged from so many threads talking about pads), you'd get a guage for what people seem to use. If you're too lazy to read, just say so, but don't think that people will hand answers to you on a silver platter, especially with something that there really isn't a definitive answer for.
.i'l just get hawk HPSpads 80 bucks for the front
As far as dust, the small single piston brakes they put in the older W203 and the newer C240/C280 and similarly on the SLK230 dust the most and benefit from any other brake pad than MB. On the C32 and 2004.5 C230, I have little to no dust form the factory pad. It's posssible they use a different company like Jurid for the pads since these are Brembo brakes. The 2005 SS brakes are 2 piston and are about half way in-between when it comes to dust. I know some of you believe MB engineered the brakes and pads but the reality is, they just go with low bid and typically use pads from Pagid, Textar or Jurid because they are local in Europe. That doesn't mean pads from other companies are any less safe, if anything they are probably safer since they are not "low bid"
for "Service B" and brake job. Also how do I change the oil in this thing, no dip stick?, I have been letting the dealer handle oil changes but I think I will try the next one. How do you reset the light for service "A" or "B"? Sorry post is so long but I need help.
Let me first say I never did brakes on your specific model with 2 pistons (my last MB brake job was on a single piston caliper). Usually, there's two allen screws holding the caliper to the caliper bracket. Just remove those and do the usual to get the caliper off the bracket. The pads should just fall out and use one of the pads and a c-clamp to push the piston back in and put the new pads in. I usually use a bead of anti-squeal paste on the back of the pad where it makes contact with the caliper. Let it dry for 15 min or so before putting them on or it will drip all over the place, not fun. Also put brake grease on the metal to metal contact spots on the caliper bracket where the pads ride and also on the screws I took out that hold the caliper as it slides on them. I hope I don't have to tell you not to put grease on anything else. Put it all back together and pump the brakes a few times until the pistons extend and you are good to go. Check the brake reservoir to make sure it's not overfilled. I do one side at a time and pump the brakes in between so that it doesn't overfill. If it is about to overflow, I use a turkey baster to remove extra brake fluid. If your brake sensor tripped (and even if not), get a brake sensor, a few bucks, you only need one per car. The brake sensor get inserted in the top of the pad, just look at the old one.
There is no dip stick, they've outgrown that. You remove the old oil the old fashion way, with a pump from the dipstick tube or you can do it the fancy way and remove the belly pan and then the drain bolt but then you have jack up the car and get under it and get dirty. The filter is on top, it's a cartridge, you remove the cover and the cartridge and put it back in. You check the oil just like most people here do, by using the MFD and steering wheel controls or you can, if you are so inclined, buy a service dipstick from the dealer.
For my car, I got Akebono Ceramic brake pads, work great, smooth, no dust at all. Don't know if they make it for your car though, the 2 piston brakes are too new. They have them for the 4 piston on my 2004 and the single piston brakes used on the older cars and the non-SS cars (ie C240).
Don't be fooled by any Sport labeling, all C230 sedans where sport sedans. The brakes are not from the AMG (only 2004.5 had the AMG brakes). Check Tirerack and see if they have the Akebonos yet for your car. I have only been using ceramic pads on all my cars, they are great.
You reset the service light the same way you reset the odometer, display the screen that shows how many miles you have left and press and hold the reset button.
BTW, put your city and car yr/model on your profile, makes it easier to answer questions in the future. Then you can scout out a cool avatar.
2005 and newer C230 SS -
2004.5 Brakes, uses same pad as C32 brakes, maybe on some early 2005
C32 AMG Brakes, uses same pad as 2004.5 C230 even though they look different.
another thing..can a ceramic one be replaced with what i have now..2004.5 ones..bec seen some treads and they say ceramics dont produce and dust at all..
I am definately going to find out if it is available in the UK..
so basically swap my present ones for the ceramic ones when it needs replacing of course..
