Sidemarkers
European regulations do not require amber side markers. As a result, the European impact strip is different than the US market in that it does not have the amber side marker light. Many on the forum prefer this cleaner look. Some purchase these impact strips (see Steve, aka MBenzNL); others replace their amber light with a clear, black, or smoked light; still others paint their side marker their car's body color.
Cintoman
Cintoman
Did you get these on eBay? Because they look exactly like a set I bought on eBay back late last year. I still haven't put them on my car yet. But I will really soon, now that the weather's much nicer.
Looks good on your car.
Cintoman
just wrap the bulb in aluminum foil if you don't want the light to shine through after you paint the marker.
Regarding bulbs. Aren't they technically just using resistance and gas to light up the bulb?
to save work and hassle tin foil is the best way to go. they shouldn't burn unless directly in contact with fire.
in fact in my sig you can see them on the far right (its the lil spec of light showing through) notice how white it is and that it blends into the headlights HID quite well
I found clear ones on ebay. They say 02-07, but some other side markers say 02-06.
Will the 02-06 fit on my 07 w203?
You should contact Steve at MBenzNL and get the European Impact Strips...like the Designer intened!
