Super Moderator Alumni
drexappeal
close
This is a concept that I had brought up a while ago, but I guess someone actually came out with a filter for it. Anybody try this?
http://cgi.ebay.com/ebaymotors/Merce...00571407QQrdZ1
i made a thread about that a month ago.Originally Posted by drexappeal
This is a concept that I had brought up a while ago, but I guess someone actually came out with a filter for it. Anybody try this?http://cgi.ebay.com/ebaymotors/Merce...00571407QQrdZ1
i didnt buy it becaust i think its just made of cheap foam
https://mbworld.org/forums/c-class-w203/151417-m271-ramfilter.html
Quote:
were did u get this piece from ? if u dont mind askingOriginally Posted by mig888
Quote:
flip
Didn't go with stainless :\.
flip
Very nice ! Where did you found this carbon look pipe ?
drexappeal
close
Quote:
This was a custom "one-off" piece that flip made himself. You won't find this anywhere else.Originally Posted by Pascal_TTH
so how do i make one of these pipes? looks good.. metal or plastic? how does it connect? i cut the cloth and then? can some one explain... please...
Quote:
that one above is carbon fiber.....very expensive Originally Posted by c230kompressor2
you can choose plastic or metal.....its a 12" long pipe, 3.5" diameter
use 3.5" silicone turbo/intercooler couplers to connect the ends.
basically, cut all the stock plastic pipe off but leave the plastic ends and clamp the new pipe onto there.
So were can i find a carbon fiber pipe? or can i put a stainless steal pipe and wrap it with a carbon fiber look a like sticker? any performance gains or better sound? It looks better than cloth thats for sure....
ExploreJunior Member
whats better Plastic or metal? is stainless steel okay?
Haha.. okay, why I did the CF piping is because 1) it looked damn good 2) presumably CF is a natural heatshield (and that was DRY CF piping). Generally you want to stay from metallic pieces as they just warm up and soak heat, so a thin plastic you might be able to get away with...but it has nothing close to the strength of a CF mold.
flip (whew)
flip (whew)
i made one of these pipes too... take a look...
nicely done! love when people do custom work. notice a change in noise comign from intake? any increase on throttle response?
drexappeal
close
Quote:
Is it real carbon fiber or wrapped? What flip did was cut a full carbon fiber pipe that was already pre-made for something else. If this is wrapped, you may not get as good of results, but looks good! Originally Posted by c230kompressor2
Super Moderator
Quote:
Nice work...and welcome to the forum!Originally Posted by c230kompressor2
its not real carbon fiber.. i wrapped it.. it's an 3.5" aluminum pipe. i got silicone connectors. but it looks good.. looks close enough to carbon fiber.. i cant find a carbon fiber pipe so this will do for now... but i dont think this gives any performance... sounds the same too... i might be wrong...
the more i looked at it, i was a bit more skeptical. you may end up losing performance/hp on this due to the pipe getting heat soak. hope for the best.....
the stock pipe is cloth.. so it gets heat soak too... what ever you put it still gets heat soak... everyone has a cold air intake the pipe is still under the hood right? the filter could be under the bumper or in the trunk... the pipe is still under the hood... heat soak is normal... how can you make a air intake with out heat soak?
the cloth pipe is there cause it handle heat better then metal, which im sure you know. but since you asked...
https://mbworld.org/forums/c-class-w203/202838-m271-gruppe-flip-intake-scoop-direct-bolt-fabrication.html
drexappeal
close
Quote:
If it's wrapped aluminum piping, then it wouldn't have the same effect as the carbon fiber pipe Jose used before. Either way, it looks very nice, however it basically is for aesthetic reasons rather than practical or performance reasons. If that's what you wanted, then it'll work.Originally Posted by c230kompressor2
i did the same thing for my kompressor, it looks clean and all, but it shouldnt really gain that many horses. what i did was connect one of those intake filters from kragen and put it right on the front, near that area in your grille where air is meant to flow through. this is suppose ti give me at least 10hp.
check it out.
http://memimage.cardomain.com/ride_i...0023_large.jpg
this pic is when i first put it on, so it was just hanging right near the pulley, and fan belt. the next day i changed it so it wasnt hanging there anymore, unfortunately i dont have a pic of that.
nonetheless, this is idea works
check it out.
Quote:
10HP? Yeah right, highly doubt that. Like to see your dyno's there...Originally Posted by dskompress24
this is suppose ti give me at least 10hp...
Quote:
mostly all intakes for mercedes benz increase their performance to about 10hp. i am going to dyno it soon through hyevon, so i'll have a conformation on that for you.Originally Posted by nickgailloux
So glad the M112 has both air intakes put to use.. Don't have to waste my time with a PVC pipe that does nothing..
Quote:
hater
