WaveyKat Mods & questions
Old Nov 29, 2005 | 07:15 PM
  #176
nlpamg's Avatar
Super Moderator Alumni
2019 GT3 RS, 2017 M3 30 Jahre
alright, after this weekend, I'm 100% sure I need the rears rolled.
with 3 people in the car and a trunk full of luggage, there was ONE large speedbump that I probably took too fast (although I was going damn slow) where I heard it rub.
dammit!
Old Nov 29, 2005 | 07:24 PM
  #177
drexappeal's Avatar
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
dammit!
Phil, believe it or not, if you had a suspension with adjustable dampers, the rubbing can be prevented. When you stiffen up the dampers there will be less recoil on the springs...makes ya want the Super Streets, PSS-9's or the CR-S's doesn't it? :v
Old Nov 29, 2005 | 07:26 PM
  #178
nlpamg's Avatar
hahaha *******! I've always wanted those. but no $$$$. I was even thinking of saving up and getting the Basics, but they don't have the adjustable dampers. hopefully some used ones will pop up.
Old Dec 1, 2005 | 12:01 AM
  #179
ekimpay's Avatar
'06 C230WZ
just an fyi. i used to rub on deep freeway dips. after an alignment, i haven't rubbed so far.
Old Dec 1, 2005 | 04:08 PM
  #180
kaze81's Avatar
Mercedes
How much does it cost you for alignment if you dont mind me asking.
Old Dec 1, 2005 | 09:09 PM
  #181
ekimpay's Avatar
'06 C230WZ
had it done at MB Laguna Niguel for $89.95 (total price). caster bolts were not required (moderate drop).
Old Jan 8, 2006 | 02:15 PM
  #182
WaveyKat's Avatar
Something Slow
Question
are they coming out with 2006 Navigation Cd-Roms? does anyone know??
Old Feb 17, 2006 | 07:01 AM
  #183
WaveyKat's Avatar
Something Slow
ok well i change my sway bars to H&R but the Squeaky sound is still there damn that is really getting to me i just can find where this noise is coming from someone told me it can be the shocks is loose? am thinking of removing my rear shocks and springs and reinstalling them.. some people say change the bushings what other bushing is there to change??? sway bar bushing front and rear what else?
Old Feb 17, 2006 | 01:06 PM
  #184
Blake P's Avatar
'09 A4 S Line
Originally Posted by WaveyKat
ok well i change my sway bars to H&R...
How do you like the H&R bars?
Old Feb 17, 2006 | 02:13 PM
  #185
WaveyKat's Avatar
Something Slow
its sweet.... handles nice.. plus the thickness of the bars compare to the stock bars theres is a big difference.. the only thing is am getting this damn squeaking noise don't know where its coming from oday when i get some i will use some liquid silicone on the rear control arm
Old Feb 18, 2006 | 12:13 AM
  #186
lars's Avatar
05 CLK 500 cab
I had a squeak - stock suspension, AMG bars. It was one rear shock absorber.
Old Feb 18, 2006 | 02:12 AM
  #187
drexappeal's Avatar
Squeak is the sound form the spring coils. Ask the shop that you bought the BASIC's from if they can get the TEIN sleeves for you. These slip over the coils on the springs and reduce the noise.
Old Feb 18, 2006 | 02:14 AM
  #188
WaveyKat's Avatar
Something Slow
i got it From Carlab
Old Feb 18, 2006 | 03:29 AM
  #189
drexappeal's Avatar
That's easy then. Contact Darwin or Jose, ask them if they can get the TEIN spring sleeves and see how much those will cost.
Did you install these yourself or have someone do them for you? If you had a shop install for you, ask them how much it'll be to install the sleeves because the suspension will need to be taken off (I'm pretty sure) to have the sleeves slipped over the coils. These sleeves will reduce the spring noise. Basically, what you're hearing is the sound of the coils depressing when the weight distributes (based on turning, going over driveway, etc...)
It's not a big deal, but if it annoys you, the spring sleeves should take away some of that noise. I hear they work great. I have the same noise, so it doesn't bother me (it's more like a creaking, not squeaking, right?). At any rate, that's what you want to do to take away a lot of that noise.
Old Feb 18, 2006 | 05:13 AM
  #190
sdsilverm3's Avatar
Are you sure it's your suspension squeaking? How low do you have the rear?
I had the same problem right after my coilovers were installed. It squeaked when going over bumps or on any type of turns. It sounded exactly like a squeaky shock or spring. We wasted almost 2 hours troubleshooting and guess what it was??? The tire was barely rubbing the little tab where the bumper meets the quarter panel. I hammered the tab upwards/out of the way and to our amazement, that was the problem!
Old Feb 18, 2006 | 12:24 PM
  #191
WaveyKat's Avatar
Something Slow
i had a shop do the install for me.. but know to remove and install it myself now... i will call carlab up on monday.. i don't have my 19" wheels on now i still hear the creaking and i don't have the setting on the coilover on the low settings... in the rear i have it almost all the way up in the front its like in the middle. but the thing is i don't have to be in the car and i can press down on the rear of the car like the trunk and i will hear a creaking noise but since after i change my Sway Bars the creaking is less not as loud as before.. today am thinking about removing the rear suspension and lube up every joints i can see even where the shocks get bolted to the control arm with some liquid silicone if this don't work well DAMN the NOISE i will have to get the Tein sleeves and live with a little creaking. thanks for the help Guys i will let you know how it goes
Old Mar 26, 2006 | 01:47 PM
  #192
WaveyKat's Avatar
Something Slow
Loose Projector BI-Xenon
I did do a search but no Fix DIY
ok so I have Euro Bi-xenon installed but the projector is kind of loose I found out that the adjusting rod popped out so I put the rod back in its place but the projector is still a little loose is this normal is there a way the make it a little less loose.. when am driving at night and I go thru bumpy roads u can actually see the projector shaking well the light shaking can someone help me and let me know if this is normal
Old Mar 26, 2006 | 01:57 PM
  #193
mig888's Avatar
EVE
Hey Wavey,
No, that isn't normal at all - I've fixed these on other cars as well but it's strictly by feel (difficult if you don't know what to feel for.. hell I can't even explain it). If I was in NYC i'd definitely come and help you out. Another way to do it is to open up the whole assembly - but I don't suggest it at all. Damn, good luck with that :\.
flip
Old Mar 26, 2006 | 02:33 PM
  #194
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
I could've sworn that Steve had some info posted on that. Are you sure?
Old Mar 26, 2006 | 03:35 PM
  #195
WaveyKat's Avatar
Something Slow
am looking inside the bix right now and i can see the black rod .. when i move the projector i see there is a little play/movement towards the back of the black rod . tired moving the rod i put it spot and i am getting no movement of the projector but am not sure if i should leave it like that or if it will move out of the spot once i go over bumpy roads.
Old Mar 26, 2006 | 04:13 PM
  #196
WaveyKat's Avatar
Something Slow
the last picture is when i move the black rod out of place
Old Mar 27, 2006 | 11:28 AM
  #197
WaveyKat's Avatar
Something Slow
can anyone help out please
Old Mar 27, 2006 | 08:31 PM
  #198
eddie081's Avatar
I adj. mines also and my passenger side BIX is shaking can that be fixed?
Ed
Old Mar 27, 2006 | 08:50 PM
  #199
mig888's Avatar
EVE
Ed
Yours is easier to fix because If I remember, you're located in the bay area. We'll have to PM each other on where to meet up . lol.
flip
Old Mar 27, 2006 | 08:52 PM
  #200
mig888's Avatar
EVE
Kat,
When I "fix" these bixenons I don't even know what I'm looking at, like I say, strictly by feel - thus the pictures don't help me much. I'll have to get in there and just mess around (and I'm being completely honest). I wish I could help you (got the PM) .
flip
After I installed BiX I got frisky and adjusted BOTH sides out of spec too ('course they're fine now - no oncoming flashes).
