what mods first for my '03 C230 Kompressor Coupe 1.8
Old Oct 2, 2006 | 08:58 PM
linkmustang's Avatar
what mods first for my 03 C230 Kompressor coupe 1.8
im doing swaybar endlinks and a Bservice and spark plugs and coolent flush so i know when the last owner did it
so what should my first mods be for my 03 C230 Kompressor coupe 1.8
and links to where i can buy them
Old Oct 2, 2006 | 09:03 PM
rlee02135's Avatar
2004 C32 ///AMG
depends on your budget
Old Oct 2, 2006 | 09:07 PM
drexappeal's Avatar
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Thank God someone else actually asked first.
I don't know how many times I've seen threads like this where there is no mention of budget and then there's complaints of "everything is too expensive."...LOL
Thanks for stepping in, rlee.
Old Oct 2, 2006 | 09:15 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
First things first.
Please watch the MBWorld movie and then search the stickies and the forums because your questions have already been answered.
Old Oct 2, 2006 | 09:25 PM
i read the stickes they are all for styleing and all i wont more power and not styling
Old Oct 2, 2006 | 09:39 PM
SeaCoupe's Avatar
2002 C230K, 2013 BMW 328, 2015 BMW X5
What did I tell you in another post? Sheez. You don't have many good options. A previous member just put in the full Kleeman kit for the M271 engine, but he has yet to come back with power results.
I think Tifosi or Tifosiv (sp?) had the full Kleeman kit too. You can try pm'ing him directly.
Honestly, use the search feature, look up Kleeman pulley, then Read to your hearts content. Lots of fun stories and info.
In my opine, you should get some 17" rims, and the best tires you can afford. If you still have the stock Michelin XGTs on the car they leave alot to be desired. Do immediately check the service records to insure all the services are current. Look at the coolant, oil, brake fluid, power steering fluid. Go nuts getting familiar with your engine. Just don't take anything apart until you have the right tools and the knowledge to put it back together again.
Pay attention to people's sig lines, and aks those that show performance mods what they thought of what they put on. I'm huge about wanting to see before and after dyno's. This will tell you if the mod was all gain, or simply a trade in where the power is.
Good luck.
E
Old Oct 2, 2006 | 11:30 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
ur current list of mods, ur budget and type of mod (body kit, rims, suspension, audio, engine, etc..) u want to do will HELP u get the right answers here...
Old Oct 3, 2006 | 05:41 AM
slammer111's Avatar
2003 C230K Coupe Orion Blue
Bang for your buck-wise, AMG sways.
Best mod ever? Bi-xenons. Ooh yeah baby.
Old Oct 3, 2006 | 10:35 AM
C230SportsCoupe's Avatar
Best advice: trade in your car for something else
You bought a heavy (3400lb+) car with a small SC I4 engine, so keep that in mind when looking around for parts. Most cars in the same category are either turbo'd I4s or V6s and much better basis for engine performance. Mercedes made this engine to be quiet, good on fuel, and have little vibration.
There is very little available in terms of engine performance for the M271 1.8L engine. A full Kleemann install will run $5K and get maybe 30-40 rwhp/tq. You can try variations, yet because a tuner has not cracked the Seimens ECU, there is an upper limitation of how much power can be generated before the ECU pulls the timing and you lose all power.
There's lots of performance mods you can do, yet it depends on how far you want to go, bolts on or custom.
Bolt ons:
OD SC pulley (Renntech, Kleemann)
filter (K&N, Green)
colder plugs (NGK, Iridium)
header (Kleeman, Carlab)
high-flow cat (Kleemann, Carlab)
cat-back exhaust (Remus, Eisenmann, SuperSprint)
larger IC
better intake piping
Custom:
resonator delete
SC port (8-10 hp/tq gains)
TB bore (57->59.5mm)
Alternatively you could tackle the drivetrain:
lightweight wheels
3.67 rear (sacrifice high-end for faster acceleration)
This forum is more concerned with styling mods, other forums will be more informative for performance mods. Evosport was involved with performance mods for this engine yet they have seemed to let it slip, and due to sponsorship reasons on this site, its difficult to discuss the competitors products.
Old Oct 3, 2006 | 08:21 PM
o ok
what is a beeter moter and how hard would it be to sway the moter i know all the wle **** will be different and has anyone done it
Old Oct 3, 2006 | 09:14 PM
o ok
No offense, yet you need to go back to a Mustang, things aren't so simple on German cars.
pshek swapped a AMG SC 3.2L V6 into his W203 and another member (pudgy?) has swapped a AMG 4.3L V8 into his WB W203. Both are $10K+ swaps due to all the electronics that must be swapped, and must be purchased new since they can only be programmed with < 1K miles on them.
Swap is out of the question unless you've got a ton of cash, if so Brabus will gladly swap in a 6L and you'll have ***** of fun!
Sell your car, buy a 2002 with the SC 2.3L, or buy an AMG with the SC 3.2L. Pull it, PnP it, bore it out, upgrade the SC to something bigger, then throw on every bolt on you can find. Should be good for 300+ rwhp if built properly.
Old Oct 3, 2006 | 09:35 PM
this is my daily drive the stang is my race car and drag car im just trying to squeeze some power out of the c 230
Old Oct 3, 2006 | 10:37 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
You already asked this question...
and it was answered....
https://mbworld.org/forums/c-class-w203/164342-looking-into-c-class-coupes.html
and apparently in 20 other threads....
and I see you're asking the same question on mbklasse.
It all just depends on what you want to spend.
Old Nov 7, 2006 | 06:14 PM
c230 fi addict's Avatar
2003 c230k
trying to find info on the 3.67:1 rear
where does one find this rear? I have contacted Potomac and have been bouncing emails back and forth. I spoke w/ Renntech to try and grab some info too! who has a year for this magical c240 auto!???
Old Nov 7, 2006 | 10:48 PM
advans's Avatar
C55 ///AMG, 535xi
hey jeff man, you can squeeze power out of this c230 of yours, but it requires cash. like I have said to you, might as well start out with a straight pipe and a nice clean exhaust. then pulleys, headers then chip it. if not, be like italianstallion and throw in a 100shot!
Old Nov 7, 2006 | 11:22 PM
clkballin's Avatar
02 CLK 430, 05 C230 SS
First Mod would be Bi-Xenons
Old Nov 7, 2006 | 11:40 PM
advans's Avatar
C55 ///AMG, 535xi
he wanted to sqeeze some juice out of his c230
