Aero Wiper Retrofit Discussion Thread
Old Jan 19, 2008 | 02:05 PM
  #226
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Originally Posted by zoomie
Most of us are clueless about this. Can someone post photos of it installed?
Not if you've been following the forum.
Zoom, zoom, zoom.
Old Jan 20, 2008 | 04:36 AM
  #227
slammer111's Avatar
2003 C230K Coupe Orion Blue
Pics
Okay, just took a pic. It's at night right now so the pic isn't the best, but you get the idea.
Pretty much all MBs 2004 and newer will have aero wipers, so you'll probably see them all over the street as well
Oh yeah, the only tool you need (instead of all that fancy schmancy OEM angle-adjusting stuff) is a 13mm hex socket. Try a position, tighten the bolts by hand, go switch on the wipers and see if you are happy with the positions. In the ideal position, the passenger wiper *just* overlaps (maybe 1-2cm) where the driver's blade sweeps, ensuring maximum coverage, and that the driver's side wipes as close to the windshield trim (driver's side edge)without hitting. Of course, you also want to make sure that nothing else (ie bottom of the windshield) gets hit by the blades or arms.
Don't use the socket until you are absolutely sure, as the bolt will jam the wiper arm into the spindle (it's an interference fit), making adjusting a real PITA, not to mention you slightly damage the arm "hole" each time you do this. Each time you adjust the arms, you slightly damage the arm hole (think of it as stripping threads off screw hole)
One recommendation is that you mark the old blade positions with a water-soluble marker as a reference. I found that I liked my aeros slightly "higher" than before during the rest position (to wipe closer to the driver's edge) and the passenger side slightly "lower" (to ensure they were out of sight when not in use). Personal preference here.
Old Jan 20, 2008 | 06:04 PM
  #228
Saprissa's Avatar
From: San Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
here's a pic of my MB aero wipers, installed on my 2003 Coupé in Sept 2004.
My wife's 2004.5 C320 SS came with aero wipers.
I love 'em !
Carlos
Saprissa@aol.com
Old Jan 21, 2008 | 02:41 PM
  #229
slammer111's Avatar
Pics of Aero Wipers
Here is the finished product.
Yes my car is dirty as hell, no need to tell me
Attached Thumbnails Aero Wiper Retrofit Discussion Thread-wiper1.jpg   Aero Wiper Retrofit Discussion Thread-wiper2.jpg
Old Sep 23, 2008 | 04:46 PM
  #230
Rev 2 Liv's Avatar
is it possible to retrofit aeroblade wiper arms on early MY203?
Hi,
When did MB make the switch to the bracketless aerowiper blade assemblys on the W203?
Also, is it possible to retrofit the newer style aeroblade compatible arms on an early model W203?
thanks!
Old Sep 23, 2008 | 05:22 PM
  #231
WaveyKat's Avatar
Something Slow
Yes... people did this Mod Already including me do a Search for Aero Wipers
Old Sep 24, 2008 | 02:40 AM
  #232
Saprissa's Avatar
Originally Posted by Rev 2 Liv
When did MB make the switch to the bracketless aerowiper blade assemblys on the W203? 2004
Also, is it possible to retrofit the newer style aeroblade compatible arms on an early model W203? YES, STFF !
Old Sep 24, 2008 | 04:05 AM
  #233
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
I just saw these pn's recently...and it was expensive! Like over $100 a side.
Sorry Carlos, yeh he should STFF, but I have the #'s handy.
I haven't done this mod, so verify the pn's.
"Here are the parts needed to retrofit the Aero Wipers on pre-2004 W203s:
203-820-32-44 wiper arm
203-820-27-44 wiper arm
203-824-07-49 cap
203-824-05-49 cap
203-820-10-45 blade
203-820-15-45 blade"
From what I've read they make the wipers work much better when driving in the rain at 100+ mph. Which doesn't happen often in the US.
Old Sep 24, 2008 | 05:33 AM
  #234
Saprissa's Avatar
I quickly typed in "aero wipers" into the search function and came up with this:
I'm sure the part #'s are on there somewhere. Maybe all those threads should be merged.
I'm a couple hundred miles away from both of my C-Classes with 04+ Aero Wipers, so I can't check part #'s right now.
Carlos
Saprissa@aol.com
Attached Thumbnails Aero Wiper Retrofit Discussion Thread-aero-wipers-search.jpg
Old Sep 24, 2008 | 07:17 AM
  #235
Glyn M Ruck's Avatar
Super Moderator
Carlos
Saprissa@aol.com
Uncle Carlos - you are so right - I see Drex has merged all those damn grille threads for those that can't find enough grille photos - (as you said - "Good God!")
Old Sep 24, 2008 | 10:39 AM
  #236
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
bosch icon blade is your friend!
Old Sep 24, 2008 | 04:37 PM
  #237
Kompressive's Avatar
2006 CLK350 Cabriolet Previous: W203,W202,W201, 2 Porsche 914s, 1965 Jaguar XKE Roadster
The last pair of aero blades that I puchased for my 2004 sedan were exactly the same size. They used to be different, with the one in front of the driver slightly longer. I don't have the exact specs in front of me right now, but I just replaced them about a month ago.
The problem is, with the new shorter blade on the drivers side, there isn't enough tension to hold the blade to the glass at the top of its sweep. That leaves a portion the size of a slice of bread untouched at the extreme left of the windshield as you're looking out of it from the drivers seat. I find that very annoying.
Old Sep 24, 2008 | 06:42 PM
  #238
slammer111's Avatar
I've done the mod and posted the part #s a while back, run a search.
Before it was 24" L (driver) 22" R (passenger), but now both sides use 22". Doesn't really matter as it's not like you use the edge of your windshield.
Old Sep 24, 2008 | 09:28 PM
  #239
Kar don's Avatar
Mercedes-Benz
haha i love it, my thread came up first. I bought my set (arms and rubber) off ebay for like 30 bucks shipped. Easy to install, just requires a socket wrench and mark the old wipers resting position. Didn't even have to replace the rubber... still wipes perfect a year later!
Old Sep 25, 2008 | 04:13 AM
  #240
Saprissa's Avatar
What's weird is that when I click on your thread... it seems like it's already been merged with Slammer111's original w00t~ thread.
Aero Wipers Installed, w00t~
I think it's time to merge ALL the Aero Wiper threads....
Carlos
Saprissa@aol.com
Old Sep 25, 2008 | 05:18 AM
  #241
Waste of money.
Old Nov 22, 2008 | 02:11 AM
  #242
oel's Avatar
oel
C230 coupe, 335i
hmm, I put a set of aero arms and 22" blades both sides on my coupe, they came off a sedan. The passenger side wiper hits the black trim on the side of the windshield. I can't seem to make any adjustments on that part. Anybody knows what's going on? Slammer111 fit a set of sedan arms on his coupe and they worked.
Old Mar 18, 2009 | 08:24 AM
  #243
marzecmike's Avatar
2003 C230 Coupe
C230 Sport Coupe
I have same problem on my '03 Coupe, I have aero arms both with 22" blades pulled off from smashed 2006 Sedan and the passenger side arm hits the trim on the side, doesn't seem to be adjustable unless if I used 21" blade it would probably work. On the other hand, 21" blade with Top-Lock Gen 1 is really hard to find. I think the arm is different on the coupe than it is in sedan.
Has anyone found a solution to this problem ?
Old Mar 18, 2009 | 09:14 AM
  #244
W203E35's Avatar
2006 C350 Sport 6MT
I don't want to sound like a smart *** but why not use RainX? I use this and I think it helps a lot.
http://www.rainx.com/
Old Mar 18, 2009 | 11:04 AM
  #245
Super Moderator
Sedans with Aero wipers as fitted OE on my car are supposed to have 2 X 20" blades.
Old Mar 18, 2009 | 03:07 PM
  #246
tommy's Avatar
2004 Civic Si. FWD for the Win!
Originally Posted by C230 Sport Coup
Waste of money.
I'd have to agree - buying the MB valve stem caps that are stolen a week later is a smarter financial decision.
Old Mar 19, 2009 | 02:27 AM
  #247
slammer111's Avatar
Just checked with a tape measure. My blades are 22".
I still don't get why all you guys are having problems???
Old Mar 19, 2009 | 01:08 PM
  #248
marzecmike's Avatar
2003 C230 Coupe
Seems like the aero 22" blades are longer than the original crud factory put in. I mean it wipes 22" however the body extends quite a bit. I will be playing around with it again and try to adjust the passenger side. This is really frustrating. If I can't get it to work right I will sell the aero arms and blades on ebay and put original arms on and adjust to work with bosh icon or rainx latitude blades.
Old Mar 19, 2009 | 02:03 PM
  #249
infected's Avatar
2007 ML500
I'll take them if you decide to sell.
Old Mar 19, 2009 | 05:15 PM
  #250
W203E35's Avatar
2006 C350 Sport 6MT
Check these out. This is what I got on my car and knock on wood no one has jacked them yet.
http://cgi.ebay.com/ebaymotors/Anti-...Q5fAccessories
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
