Installed my Vogtland springs today...
Old Sep 29, 2002 | 10:22 PM
KWiK's Avatar
2002 C230 : 2007 C230
Thumbs up Installed my Vogtland springs today...
This morning I installed some Vogtland springs on my C230 Coupe. The drop is spec'd at 30mm and that appears to be correct. The front is down to a 2 finger gap and the rear (with 4 dot pads) is a 0 finger gap.
Vogtland claims these spring would work fine with the OEM shocks. After putting 47 miles on the car since the install, I would agree. The springs feel slightly firmer than stock and provide a nice compliant ride. I still think the car needs sway bars, but I expected that.
Do I like these springs? YES
Did these springs give the drop and ride claimed? YES
Would I buy Vogtland again? YES
Over rating?
pictures to follow...
Old Sep 29, 2002 | 10:25 PM
KWiK's Avatar
The is the front gap after install.
No, I don't have before pictures. My camera sucks and I was lucky to get it working to take these pics.
Old Sep 29, 2002 | 10:28 PM
KWiK's Avatar
Rear gap
Old Sep 29, 2002 | 10:31 PM
KWiK's Avatar
View along the side, from the rear.
This pic also shows how the C7 wheels fit with 20mm spacers.
Old Sep 29, 2002 | 10:36 PM
Xeon's Avatar
i dunno if it is the angle of photography..but the gap of the front wheel and the fender still looks wide..the rear looks nice though
Old Sep 29, 2002 | 10:42 PM
KWiK's Avatar
Must be the angle of the pic, because the gap was cut almost in half.
Old Sep 29, 2002 | 10:43 PM
Buellwinkle's Avatar
What made you go with Voglant springs? Are they available in the U.S.? Why not Eibach or H&R?
Old Sep 29, 2002 | 10:45 PM
E320's Avatar
Very nice ,Did you lower it by yourself?if yes ,did you use an mb spring compressor or just the regular ones?Where can i buy the vogtland springs?
Old Sep 29, 2002 | 10:54 PM
KWiK's Avatar
Several reasons, but the main 2...The Vogtland rep told me they targeted a ride and drop somewhere between H&R and Eibach with OEM shocks. That is what I was looking for. After riding in several cars, I believe they have succeded. Also, I play golf with the owner of PURE-Motorsport and won a nice discount.
I wasn't looking for a big increase in stiffness, if I wanted that, I would just drive my BMW.
Old Sep 29, 2002 | 10:59 PM
KWiK's Avatar
Yes and No, I did install it myself, but did have some help. Yes, I have a spring compressor ( like Randals at AutoWerks), and also a Branick. No, I would never use those regular(cheap $30) ones.
Old Sep 29, 2002 | 11:03 PM
Are they progressive? The price looks good, $244.
Old Sep 29, 2002 | 11:09 PM
KWiK's Avatar
No, they didn't look progressive to me and I don't recall the rep telling me that they were.
oh, and when the OEM springs are uncompressed, they are about 18" long
Old Sep 29, 2002 | 11:15 PM
Why hasn't anyone just cut the factory springs to lower the car? Then you can get whatever height you want.
Old Sep 29, 2002 | 11:18 PM
KWiK's Avatar
Would you?
Old Sep 30, 2002 | 09:16 AM
bagwell's Avatar
From: Houston,TX-moving to The Woodlands,TX SOON!!!
Toyota Tacoma & Lexus IS250
looks good...its lowered to where it should be.....not slammed !!
good job !
so the ride is not bouncy with OEM shocks ???
do these fit the C320 as well ?
Old Sep 30, 2002 | 10:25 AM
Originally posted by KWiK
Would you?
Absolutely, if someone else has done it and there's a recipe for doing it like cut 2 full coils lowers the car 1".
Old Sep 30, 2002 | 10:57 AM
KWiK's Avatar
good job !
No, the ride isn't bouncy.
Yes, they have springs for the C320.
Old Sep 30, 2002 | 11:00 AM
KWiK's Avatar
Well, somebody has to be first, so start cutting.
Be sure to share your results.
Old Sep 30, 2002 | 12:45 PM
bagwell's Avatar
I think HARRIS has some knowledge (and warnings) of cutting the springs.
Old Sep 30, 2002 | 01:23 PM
I keep hearing of people cutting the H&R springs to get more drop, might as well cut the factory springs, save the middleman. The problem with being first is that you have to cut & test a few times until you get the desired results. If I can do the springs myself and had the time I would but if I have to pay top dollar labor rates for doing it, the pre-made springs are way cheaper.
Old Sep 30, 2002 | 03:36 PM
JamE55's Avatar
Out Of Control!
Look pretty tyte Kwik!
Old Sep 30, 2002 | 04:59 PM
hokusbenz's Avatar
c230 Coupe
those look perfect to me
