Supercharger oil
Rating: Thread Rating: 3 votes, 5.00 average.
Old Apr 22, 2007 | 11:45 PM
deltadude388's Avatar
School bus
Supercharger oil
Anyone ever tried changing the oil for yr supercharger(M271)?
Difficult, easy task?
Old Apr 22, 2007 | 11:48 PM
BabyBenz6spd's Avatar
2005 C230 Sedan 6spd
Correct me if I'm wrong, but I always thought supercharger share oil with the engine (motor oil)
Old Apr 23, 2007 | 12:53 AM
rtking's Avatar
2002 C230 Coupe
The Eaton M45 has its own oil that is used to lubricate the bearings in the snout. I'm not sure how someone would service that on the car though - seems like it would be hard to get to. It's certainly difficult on the M111 cars, I can only imagine how hard it would be on the M271 cars. Luckily the SC oil should be a "lifetime" fluid (i.e. good for 100K miles) If you're going to pull of the SC to change the fluid, that might be a good time to port the SC and maybe rebuild the snout too...
Bob
Old Apr 23, 2007 | 01:51 AM
cla 1000's Avatar
2002 C230 K, 6 speed
Bob
Hei . How long ago didi you get your pulley. o you know if they still reimburse you for the stock one?
Old Apr 23, 2007 | 01:35 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Bob
Yeh, that was my conclusion too.
There's no access to drain and change the oil, it's a lifetime fill.
If you are changing the oil, it's time to do the seals, etc. and heck, port it while yer at it.
Old Apr 23, 2007 | 07:39 PM
rtking's Avatar
2002 C230 Coupe
I installed my pulley at 50K miles (car now has 74K miles) and that was about 2 years ago. Install wasn't too bad and the results are very noticeable. People do run lean with the pulley but I haven't heard of any failures due to running lean since most people don't drive at WOT all the time.
I paid for the pulley and the core charge. I believe ASP will reimburse you for the core once they receive it back. I elected to keep mine since, if I ever sell the car, I'll want to return it to stock.
Bob
Old Jan 6, 2010 | 04:13 PM
hellowmbowners's Avatar
2005 C230
One of the shops that worked on my car said it had a fill and drain plug... this has not been the experience of others?
Thanks.
Old Jan 7, 2010 | 11:42 PM
loudandheard's Avatar
C32/C55 AMG
Check out this thread in the C32 forum, it has all the answers on where to buy the oil and how to change it. Relatively cheap and easy.
https://mbworld.org/forums/c32-amg-c...-their-sc.html
Old Jan 8, 2010 | 09:48 PM
There is a drain plug on the front. I tried to open it while the M45 was off the car.
No dice.
Your best bet, is keep your eyes open for new one on ebay, swap it before it dies and
sell the old one.
I did that, 650 for new, old one sold for 250, so I'm only out about 400 for a new one instead of rebuilt.
Old Jan 9, 2010 | 08:35 AM
Glyn M Ruck's Avatar
Super Moderator
If Eaton are doing as they should the SC should be filled for life with a Diester synthetic which will outlast the unit comfortably. Just leave it alone until you need a new one.
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
