Why does the Kompressor not allow me to this?
I went to Floyd Bennet field today, a huge open field (ex military base) to learn my car better. It was raining out but regardless I tried to do burn outs. My friend suggested that I:
Go in Reverse, gas up until 20 mph, then quickly change to Drive and floor the gas pedal.... He has a fast Maxima and this is how he burns out.
This is what happend;
As soon as I switched to Drive (w/o braking, just switched from R to D), the car kept going in reverse anyway! Even if I gas'd up it would just go faster in Reverse until I came to a complete stop, then there would be a jerk and the car would be in D mode. Why did this happen? I did this with ESP off & ESP on, W mode & S mode. Someone explain.
I hope you saved up for transmission repair. Driving like this will cost you some money very soon.
Interesting theory, yet you did not answer my question.
Can't you just rev the engine in drive with the parking brake on, or even holding the brake pedal and just smoke the tires? or is the electronics still smart enough to keep you from doing this in an automatic? Yes this would still be bad for the mechanical parts, but gotta be better than slamming from reverse into drive!
02Impressor, I used to have a Dodge Ram pickup with a slant 6 and a practically bulletproof transmission. I reversed as fast as it would go in snow and threw it into drive, never heard such a bad sound as that before, and ended up in a spin and in a snow bank. I was 17, it was dumb, I learned my lesson on a truck that most likely can handle some abuse... I wouldn't be trying it on a brand new MB.
If you could see the temperature increase in your tranny when you do a hard brake/gas pedal on the floor start you would never, EVER do it again.
Keep this up and you'll be up with Buellwinkle in getting loaner cars from your dealer.........and..........abuse is not covered by your warranty nor should it be.
You want to do a burnout...........get a bottle of beach..........pour some out on the street. Back your car over the wet spot. Put tranny back into drive and hit it. Watch the smoke..........than please tell me what's the point.
But, to propose an answer to your question, it probably has a safeguard in the transmission electronics that prevents crap like that.
A question for those of you with automatics? Can you just hold the brake and give it gas. I know there is something built in that doesn't give it gas if you're on the brake, so you can't drag the brake like the old folks do. But it doesn't seem to do it in certain situations. My 6-speed even does it if I'm trying to clean the rotors by dragging the brake a little. (Had some bad wheel cleaner that looked terrible for the rotors.)
Anybody experience this while trying to do burnouts?
Reverse transmission drop???!!!!!!?!?!? Holy SHI*!!!!! And you expect no flames?????? Come on man, this is the Mercedes Forum, not the Hyundai Elantra Forum. Treat the car with a little more common sense, thats just plain dumb in my book.
I have an auto and do burn outs very easy just hold the brake down and press on the gas, till the tires spin. u dont even need to floor it unless u want it to go for a while.
This way is no where near as dangerous as what you tried.
Anyway, I figured I had to try it atleast once. I didn't think that one time would do anything critical to the tranny or anything else. It wasn't the right thing to do but hey I had to see what my car was all about, right? I simulated a spin out as well, just in case, God forbid I'm ever in that situation, so I don't completely freak out when car is out of control.
Point is, I don't do stupid **** like that on a daily basis. Heck, I've only had the car for about 5 months and still have under 3000 miles on it. The car doesn't get abused despite your opinions.
This car to me seems like it’s mostly computer controlled and can virtually get itself out of situations where the driver would panic. He asked a question and you flamed him. Continue your daily commuting from point a to point b and enjoy every moment of it because you are fools of the highest degree.
orgasmicNYC: The new FLAME Cop in town.
Yes fortunately the electronics are smart enough to know to shift into a gear only when the car is at the proper speed and going in the correct direction. Shifting from reverse to drive without stopping will cook the torque converter!
I'm not so sure that the "I want to find the limits of my car" argument holds true. There are far better ways of simulating an evasive maneuver than to try to do a burnout by changing from reverse to drive (which is totally unrealistic). Anyone who manages to defeat ESP in a normal driving condition is probably going far too fast for the conditions.
speaking of changing gears in an automatic without stopping, is it safe to switch into neutral from drive and vice-versa while driving an automatic? it may be a naive question as torque converter mechanics is something i know little about. however, it'd be nice to know if i can.
.. also, save some money for new tires as well.
back in my Camaro days...
