just done an alignment, how do i read this?
Old Feb 1, 2008 | 12:05 AM
KIRA's Avatar
2002 C230 coupe , NOt THE AVATAR!!
this was from Phil's M3 from what i remembered
https://mbworld.org/forums/showthrea...ight=alignment
all i was told from the SA was "your rear camber is mess up" so i was thinking.. am i over weighted coz it was rear left side??"
i told them my car was lowered and why just one side??
can anyone help me read this and did i spent the 60bux right compare to dealer ($170)
Old Feb 1, 2008 | 12:36 AM
06c230hwd's Avatar
06' C230SS
i'm no MB specialist. nor do i claim to know tons about tires and/or alignments. but i do know that from the numbers on the chart what he meant by "your camber is messed up" (<--lol by the way..) is that your rear left tire is leaning inwards. as in the top of the tire is leaning to close to the chassis of the vehicle. like a slash on your keyboard ----> /
anyways it seems as though its only what .1 degree away from the specified ranges.. in any case i'd say that your camber isn't too bad out of wack, but you should get it aligned properly
Old Feb 1, 2008 | 01:02 AM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
Disregard the ‘this value is not within specification…’ nonsense. If it has been read correctly, it’s within a minute of a degree of specification before their alignment. If it were mine, I would insist the technician set the toe much closer to the minimum tolerance. It only serves increase directional stability on straight-ahead uneven surfaces, at the expense of additional front tire wear.
How does it feel going down the road? Negative camber is a good if you like to hustle around the corners. It optimizes the load bearing (outside) tires’ contact patch during dynamic loading and helps to minimize tire wear while doing so.
Let us know if you ultimately seek to minimize tire wear, or prefer to get after it in a composed manner, so we can better answer your question(s).
Old Feb 1, 2008 | 01:07 AM
KIRA's Avatar
well i still get some pulling to the right, and all i am looking for are less tire wear
i don't need those Negative Camber for handling since is only a C-coupe i am driving
Old Feb 1, 2008 | 02:28 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
well, you can't adjust the camber on the w203 without the camber arms. The factory spec gives you some negative camber at stock height and when you lower the car the camber increases. what you can do is measure the ride height on both side for the rear and see if your driver side is lower than the passenger side.
there's a lot of variation that can cause the suspension to sit un-even even when you have the coilover set to the same height on both side.
still if you don't want to have the negative camber you need those camber arms.
Old Feb 1, 2008 | 03:00 AM
KIRA's Avatar
ahh at first i thought camber arm are for people that want negavtive camber..
yea i always remember stock BMW they all have a little Negative Camber for most of their car
anyway thx again
Old Feb 1, 2008 | 04:42 PM
KIRA's Avatar
soo what are suppose to be good number??
i always do alignment in dealer so they just print out what they done on my car but no result or test whatsoever
so i am newbie to this
Old Feb 1, 2008 | 04:51 PM
infected's Avatar
2007 ML500
Does anyone know who manufactures the camber arms?
Old Feb 1, 2008 | 05:27 PM
KIRA's Avatar
carlab does
Old Feb 1, 2008 | 05:37 PM
nlpamg's Avatar
Super Moderator Alumni
2019 GT3 RS, 2017 M3 30 Jahre
K1motorsport FTW!
Old Feb 1, 2008 | 05:45 PM
infected's Avatar
2007 ML500
Thanks Phil.
Old Feb 1, 2008 | 05:49 PM
nlpamg's Avatar
Thanks Phil.
no problem man! I don't see it on their website, but send them a message. I know quite a few of the other members are successfully running their camber arms.
Old Feb 1, 2008 | 06:10 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
+1....
got one on my rears from them as well...
shrug, all the pics on my thread are gone since my server died...
Old Feb 1, 2008 | 06:25 PM
infected's Avatar
2007 ML500
Just snatched this from Tom:
Very nice!
(not sure if I'm violating anything by posting a link from a non-sponsor, sorry and please remove if so)
Old Feb 1, 2008 | 06:38 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
http://k1motorsport.com/img/kmac.gif
Very nice!
replace "url" with "img"....
Old Feb 3, 2008 | 03:20 PM
KIRA's Avatar
i just notice my rear got raise after the alignment... it use to be slam with negative looking camber
Old Feb 3, 2008 | 04:10 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Or these.
Someone has a KMAC set in the classified section, but they are
a beeotch to install, and unlikely to find a shop who can properly adjust.
I'm running about -3 to -4 degrees on the rear of my car.
But oddly the tires aren't wearing on the inside too bad.
Old Feb 3, 2008 | 04:23 PM
infected's Avatar
2007 ML500
Is that site for the 202 only or will they fit on the 203 as well?
