Glycol Contamination in Transmission - Need some info..
Old Mar 12, 2008 | 11:31 AM
swiftbmx's Avatar
2003 C320 4matic sport
Hi Everyone,
For about 5 months I have been having problems with jerky shifting in my transmission and I took it to 4 different MB mechanics and none found a problem or could find a problem. Out of curiosity last night, I came across this whole glycol contamination problem through the search and my car (2003 C320 4matic) falls under every single symptom of this problem:
I'm having the vibration of the car in the first 2 gears. I have jerky transmission at gears 1-2 and slightly less(but definitely still noticeable) at 2-3 and the annoying thuds and clunks while downshifting. I just feel like I don't have control over the car. Unfortunately I am out of warranty and too late to purchase extended warranty.
Here is what I concluded needs to be done through searches:
-Replace the radiator with a Behr one
-Flush the cooling system, flush the radiator, flush the torque converter and complete flush of the transmission multiple times to make sure there is no glycol in there.
-Fresh new transmission fluid
I'm hoping to god my transmission is still ok as the driving experience has not changed over the last 5 months so contamination may not be that bad.
My questions: If I do have to purchase a torque converter, where can I get one the cheapest? A good buddy of mine is an excellent mechanic but deals primarily with Japanese and American cars. He is willing to do this for almost nothing in labor as long as I bring the parts but he can't do it if it requires special MB tools, so does it? Lastly, what are all the little parts I would need like "seals, o-rings, etc," I found them for a W211 but need to know about W203.
As always, any help is appreciated.
Old Mar 12, 2008 | 11:37 AM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
If 4 mechanics let this problem go and didn't catch it,
causing further damage I'd be having a cow in their faces.
Search on "free epc" to gain access to the info you request.
Old Mar 12, 2008 | 11:51 AM
swiftbmx's Avatar
You know, I actually got really worked up over it but the truth is they will just deny it and say there was no problem so its not worth the headache. I'm just looking to get it repaired at this point and freaking sell or trade in this thing. I learned a valuable lesson during this whole process. If you can afford to buy a Mercedes, it doesn't mean you can afford to maintain one. One valuable freaking lesson.
Old Mar 12, 2008 | 11:58 AM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
It may not be as bad as you think. Many times it could be a case of the transmission adaption needing to be cleared. I would get the test just to make sure you have all the information before making any decisions.
So, you definately have the Valeo radiator?
Old Mar 12, 2008 | 12:12 PM
swiftbmx's Avatar
Yup, definitely the Valeo Radiator. I have every single symptom of the problems described with the glycol contamination. Its almost a little frightening since I can't imagine it being anything else at this point. I have tires with less than 5000 miles and I couldn't figure out why there was vibration even after balancing.
Old Mar 12, 2008 | 02:57 PM
loungn14's Avatar
SPONSOR
Ouch, ya, unfortuantely it does sound like ur contaminated....
Sorry to hear that man....
Old Mar 12, 2008 | 03:25 PM
mike82y's Avatar
im having the same problem with a S211 E320 CDI.
going to get the transmission flushed using the following system.
http://www.automatikoelwechselsystem.de/
Mike
Old Mar 12, 2008 | 04:01 PM
Mike
Nice. Wish we had that here.
Actually this is pretty interesting, looks like a club of some sort and they did 16 fluid changes in 1 day.
Here it is in Engrish
http://translate.google.com/translat...hl=en&ie=UTF-8
Check out the W203 video!
Old Mar 12, 2008 | 05:14 PM
swiftbmx's Avatar
Mike
Wow, do they have anything like that in the U.S.? I was going to go to a Tranny shop to get mine flushed but this looks ways more efficient.
Old Mar 15, 2008 | 08:14 PM
NG C-Klasse's Avatar
02' C240 Luxury Model
https://mbworld.org/forums/showthread.php?t=227090
Worked for me, still going strong.
Old Mar 16, 2008 | 02:48 PM
I don't trust the tranny shop to use the correct stuff or do it right.
Old Oct 29, 2011 | 12:34 AM
junagui's Avatar
99 230slk
hi,
i am new to this forum. i bought an 03 c320 sport a week ago and i noticed a slight shudder on low speed and a slight vibration sound ( like running on a rough road ) at 40 mph, will go away when i release the gas pedal. the previous owner told me that it was just repaired , and that it was just a result of the repair. the previous owner is still looking for the paperwork from the shop.
i was reading about the glycol contamination and it's symptoms which i think is identical to what the car does. needs some advice on what to do next.
Old Oct 29, 2011 | 02:04 AM
Here's hoping the former owner didn't sell for exactly that reason.
Originally Posted by junagui
hi,
Old Jan 17, 2012 | 12:49 AM
junagui's Avatar
99 230slk
Shuddering, droning and buzzing sound gone.
Things done to the car...
> Replaced 2 bald tires ----- no improvement whatsoever, just a little bit quieter.
> Replaced plug wires and plugs (bosch )----- run's better but still shudders and the buzzing sound was still present.
> This was the real fix..... are you ready for this ? ? ? REPLACED TRANSMISSION OIL AND FILTER KIT. ( FUCHS )
> Have put about 2000 miles on it and the car run's awesome and I am loving it.... bye BMW.
I hope this will help people having the same issues.
Old Jan 17, 2012 | 02:09 AM
Amazing isn't it.
I was argueing with some dumasssses on benzworld about how
old fluid thats dead and gone can't be good for the tranny and to flush it.
Ah, but they were blathering on about the lifetime fill, and doing a flush being bad might wash away something good along with the bad.
Yes, running completely wasted, burnt, oxidized tranny fluid is good for your tranny. Can't believe people still pass on this sheeet.
Old Jan 18, 2012 | 12:06 AM
mtnman82's Avatar
'16 E350, gone: '03 c230k
^ +1 - I'm amazed at the difference it made with just a simple 4 qt flush and filter change.
Old Jan 18, 2012 | 07:05 AM
Glyn M Ruck's Avatar
Super Moderator
Originally Posted by C230 Sport Coup
Amazing isn't it.
The bollocks spoken on the internet about not changing fluid is just that!
There are some real plonkers out there.
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
