View Poll Results: Aftermarket Wheel Thread
W203
0
0%
CL203
0
0%
Voters: 0. You may not vote on this poll
W203/CL203 Aftermarket Wheel Thread - All you want to know
#3901
'09 A4 S Line
Hi, please i want some advice on my next wheel upgrade, since now i´m running OEM AMG style IV 17 on my Sportcoupe 220 CDI with BILSTEIN coilover kit and AMG BBK
Next wheels are BBS LM The available sizes of BBS LM- 8,5 x 18 ET 30 (lm127) and 9,5 x 18 ET 32 (lm 128)
Am i going to experience some trouble with these wheels (rubing problems)
Thanks in advance
Thanks in advance
#3902
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Thanks in advance
Thanks in advance
#3903
'09 A4 S Line
You're thinking about it backwards Drex. Lower offset means the wheels will be pushed further out toward the fender so BBK clearance is less of a problem than with a higher offset. Other important factors are lip size and spoke thickness.
#3904
c240
FYI: https://mbworld.org/forums/showthrea...&highlight=lm6
Price is negotiable!!
These wheels look good on a desert silver car. Is yours pewter?
yes my car is pewter
#3905
Nah, B. I know what I was saying. It was with reference to a 9.5 inch wheel and assuming that there was going to be a larger lip (considering they are LM's and there's that 2 step deal on those rims).
#3906
'09 A4 S Line
I've never thought LM's had a large enough lip to interfere with rear BBK clearance, but I suppose that could be the case. Either way, @ you!
#3907
Yeah, if you look at the LM's because of the way the lip is designed it's kinda deceiving. It's got that 2 tier lip. first the outside barrell, then there's a 2nd lip that goes up to where the centers are attached. It's what sets the LM's apart and definitely my favorite part of the LM's.
#3909
S13, P100DX, E46 M3
on the rear 19x9.5 i can get 40mm offset, and run a 5mm spacer to bring to +35 offset, with 255 tires.
I hope this sizing will work well on the c230.. my last debate is what springs to run on this car to make it look decent with a nice drop to cover up the gap.
Many tks for your advice again!
#3910
'09 A4 S Line
since the 19x8.5 fronts i can get in +35 offset, i can easily run a 5mm spacer (and with 225 tire it should fit nice and flush?)
#3911
S13, P100DX, E46 M3
tks for the info! at least i have wheel/tire combo out of the way, as for suspension there is so much info in the suspension thread that is very vague, not really something where i can conclude what would be the best choice of springs, pretty much each owner has a different experience with different brand.. i always like Neuspeed as they are little on the stiffer side, vs say Eibach that was always too soft and saggy.. then you have H&R and others of course.. thats where my dilemma is now
#3912
01` Sportscoupé 220CDI
Those offsets seem nice and aggressive for a coilover setup and you should be ok. ET 32 in back is a few mm lower than ideal (35 would be perfect, IMO) but if you don't tuck the tires in the fender you should be fine. ET 28 up front would be my ideal offset, but again I think unless you really slam it you should be ok
This is a pretty aggressive offset. I'm assuming you're not planning on doing any big brake upgrades because you would most likely need a spacer for the rear if you do a big brake upgrade. The front should be fine
This LM setup is the only one that BBS has for mercedes.
SO the wheels with this set up wont stuk out to much away from the fenders right, and shoud be fine with amg bbk, or do i need a spacer for clearing the brake caliper.
#3914
EVE
I have a set of ALL BLACK BB5 LMs for sale if anyone's interested... I argued with my bro not to place them on his audi. ET35 all around. =D. $800? (Less than what he unfortunately paid for).
#3915
'09 A4 S Line
#3919
'09 A4 S Line
#3921
'09 A4 S Line
#3924
'09 A4 S Line
