View Poll Results: Aftermarket Wheel Thread
W203
0
0%
CL203
0
0%
Voters: 0. You may not vote on this poll
W203/CL203 Aftermarket Wheel Thread - All you want to know
Old Jun 14, 2008 | 02:53 AM
  #5051
grossmeisterb's Avatar
2006 S203 C280 T
Originally Posted by Blake P
Did you get new shocks to go with the springs? The stock shocks can't handle the shorter, stiffer springs and will eventually blow. My recommendation is a set of Koni adjustable shocks so that you can dial the firmness to your liking.
Nope, no new shocks yet, I will go with the stock shocks first, if they break or if the ride doesn't feel like I want it, I will get new shocks, and yeah, Koni yellows are the best I think...but as I said, stock shocks first - many guys over here use stock shocks with the 1,6"-lowering-H&R-springs, and they nearly all use stock shocks - and their rides feel great...
Old Jun 14, 2008 | 04:42 PM
  #5052
Liqued12's Avatar
2002 C230 Coupe
MAE (O.Z. Racing) Crown Jewels with Kodiak lips and painted centers with Mercedes center caps.
Front
18x8.5 Et 32-15mm spacer = et17
Tire size 215/35/18
Toyo Proxy T1R's
I had to have the hub centric part milled out on the front, but the cars hub still extends, holding the wheel.
About 39mm shank on the lug bolt.
Rear
18x10.5 et52-12mm spacer = et 40
Tire size 235/40/18
About 34mm shank on the lug bolt.
Running tein coils, the fronts are all the way down now, the rears I have about a half inch left. The rear is rubbing right now on the fender, need to go in a few more millamenters and roll the fenders a tad. I havent measured but I belive I still have about half inch left on the inside of the car so I can move the rear wheels in a bit. Also going to raise it up a bit.
Old Jun 14, 2008 | 05:11 PM
  #5053
nlpamg's Avatar
Super Moderator Alumni
2019 GT3 RS, 2017 M3 30 Jahre
Front
Tire size 215/35/18
Toyo Proxy T1R's
Rear
Tire size 235/40/18
that looks pretty good, but is it just me, or do those tire sizes seem awfully narrow?
Old Jun 14, 2008 | 05:12 PM
  #5054
nlpamg's Avatar
Originally Posted by pawe
I am looking at the AZA Z1 19" wheels at wheelmax but they dont have a size specific for a 2005 c class kompressor sedan. Any of you guys running on these shoes? can you give me an idea if the wheels will fit OR what measurements should I have?
My car is on stock AMG sport suspension with stock big brake calipers..well everything is stock. Thanks and I appreciate the help.
SSR GT3 replica's FTL!
Old Jun 14, 2008 | 07:12 PM
  #5055
Mu9enx's Avatar
01' C32o
super stretchedd
Old Jun 15, 2008 | 12:04 AM
  #5056
anson.w203's Avatar
05 C230SS
[QUOTE=rdscklasse;2871300]
Originally Posted by rdscklasse
Here's how mine look like.
. . . with new wheels:
So far I have H&Rs Springs and no rubbing at all. OEM struts/shocks are holding up for now but I will soon change them for maybe Koni or Bilstein.
19x8 et32 235/35/19
19x9 et35 265/30/19
No Spacers!!!
rdscklasse
looks really good!
Old Jun 15, 2008 | 12:56 AM
  #5057
Blake P's Avatar
'09 A4 S Line
Trust me... your shocks will blow so you might as well do it right the first time instead of paying labor twice. I made the same mistake trying to be cheap and am just trying to help.
Old Jun 15, 2008 | 01:03 AM
  #5058
pawe's Avatar
'05 C230
Reps vs authentic smackfest again? Im just trying to get info on the wheels man.
They're like $1500 with tires and that is great value. Now if you or someone else is willing to sell me their SSR GT3s for the same price then I'd buy that instead of the reps.
Old Jun 15, 2008 | 02:27 AM
  #5059
anson.w203's Avatar
05 C230SS
well said
Old Jun 15, 2008 | 02:44 AM
  #5060
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
before asking for info you should post more info on the wheels first.
from the information you've given (19") I can't tell you **** and not going to bother searching for specs on that wheel for you.
some info you should list before asking would be 1. diameter and width 2. offset 3. size of the lip 4. bolt pattern.
Old Jun 15, 2008 | 03:04 AM
  #5061
ROLLNNN's Avatar
2005 CLK320 Vert & 2005 CLK55 AMG
tires rubbing
Hey, got a question:
my front wheel is 19x8 +32 with a 5mm spacer, makes it a +27,
tire 235/35-Falken 452. At slower speeds, when i turn, the tire rubs the front of the wheel well (black plastic inner lining)
since its only an 19x8 should i have gotten 225/35 to make the sidewall a little more rounded. Right now its pretty straight. If i do get the 225/35 will this get rid of the rubbing? if i lower a little with coilovers, will it still rub or get better/worse?
im sitting on the stock 2005 sport suspension. what do you guys think??
Thanks..
Old Jun 15, 2008 | 03:14 AM
  #5062
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
Thanks..
rubbing on the front plastic cover is pretty much normal when you go 19". I wouldn't worry about it.
Old Jun 15, 2008 | 03:43 AM
  #5063
pawe's Avatar
'05 C230
Sorry bout that, first time to mod and replace a wheel. Anyways, Im trying to figure out the best way to go.
Performance is not really a big deal for me, I just go for aesthetics, hoping for no rubbing issues and roads here in Phoenix is really not that bad.
18x8.5 (bolt 5x114.5) and 18x9.5 (bolt 5x20). offset is 40mm
19x8.5 and 19x9.5 (not sure bout bolt pattern but I can always buy bolts from another 3rd party seller right?) offset is 45mm all around.
-Offset can be changed as special request
-No tires yet coz I still dont know if these wheels will fit
-Should I get the 18s or the 19s?
Thanks again and I will give a review/feedback/update as contribution so it can be used as a future reference.
Old Jun 15, 2008 | 05:55 AM
  #5064
2006 S203 C280 T
Thanks for your help man!! I will do the installation of the springs with a friend, so if the shocks blow out early or the ride feels bad, I will get the Koni yellows right away and install them - doesn't cost me anything extra... ...we allready installed some H&R springs and later on the H&R coilovers on my friend's R171, so that's no big problem for us/him...
Can't really wait to get those wheels...
Old Jun 15, 2008 | 03:38 PM
  #5065
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
NP...now that you have more info on the wheel that i can tell you those won't fit.
MB bolt pattern is 5x112. for 8.5 and 9.5 width to fit on the W203 you need ET27-30 for the front and ET35 for the rear.
Old Jun 15, 2008 | 08:09 PM
  #5066
ROLLNNN's Avatar
Sounds good, Thanks!!!!
Old Jun 20, 2008 | 10:33 AM
  #5067
e34m20's Avatar
n/a
The fitment guide at http://www.alloywheelsdirect.net/inf.../mercedes-benz
shows multiple possible offsets for my car. Which ones are the stock 2005 SS specs for the standard 17x7.5 / 17x8.5?
F/R
36/30
36/34
37/30
35/30
37/34
Old Jun 22, 2008 | 03:37 PM
  #5068
Rareamg's Avatar
E55 AMG Black on Carlsson 1/6 EVO
New wheels again!!!!
Quick pic of my new setup HRE C21 Comp. My DPEs are for sale so PM me if your interested.
Old Jun 22, 2008 | 04:33 PM
  #5069
SlvrC230SS's Avatar
2006 C230SS & 2009 E350
Wow, man, you keep changing your rims. I like the step lip.
Old Jun 22, 2008 | 04:37 PM
  #5070
Rareamg's Avatar
I know... but I like the step lip too...
Old Jun 22, 2008 | 05:27 PM
  #5071
infected's Avatar
2007 ML500
Sick!!
Old Jun 22, 2008 | 05:45 PM
  #5072
WaveyKat's Avatar
Something Slow
nice looking good!
Old Jun 22, 2008 | 08:09 PM
  #5073
kcheng86's Avatar
03 c320
nice + 1 on the step lip!
Old Jun 23, 2008 | 12:52 AM
  #5074
Blake P's Avatar
'09 A4 S Line
Wow, I thought your last set of wheels was perfect, but these take the cake! I think I want some HRE Comps, so we're going to have to talk. The step lips are gorgeous.
Old Jun 23, 2008 | 01:32 AM
  #5075
Rareamg's Avatar
Hey Blake,
I totally love the step lip. Will talk manyana man!
You have already rated this thread Rating: Thread Rating: 16 votes, 5.00 average.
