View Poll Results: Aftermarket Wheel Thread
W203
![](https://mbworld.org/forums/images/polls/bar2-l.gif)
![](https://mbworld.org/forums/images/polls/bar2.gif)
![](https://mbworld.org/forums/images/polls/bar2-r.gif)
![](https://mbworld.org/forums/clear.gif)
0
0%
CL203
![](https://mbworld.org/forums/images/polls/bar3-l.gif)
![](https://mbworld.org/forums/images/polls/bar3.gif)
![](https://mbworld.org/forums/images/polls/bar3-r.gif)
0
0%
Voters: 0. You may not vote on this poll
W203/CL203 Aftermarket Wheel Thread - All you want to know
#6976
I just threw some 18x8.5 and 18x9.5 on my C230 SS with 35 offset all around.
I was wondering if I'd be able to throw a 5mm spacer up front and a 10mm in the rear without rubbing? 5mm does look like it might just work up front, but the 10mm in the rear worries me. I think a 7mm would likely do the job, but I can't find any that are hubcentric to the hub and wheel.
Would i need to do a fender pull in the rear? Also, people who have their fenders pulled, how does it look, considering there are plastic trim pieces/bumper cover relatively close to the fender?
#6977
06 C230 SS 6spd
#6978
The time has finally come! ![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
![](https://fbcdn-sphotos-a.akamaihd.net/hphotos-ak-snc7/301099_295801100437047_100000214798354_1387937_1254220854_n.jpg)
![](https://fbcdn-sphotos-a.akamaihd.net/hphotos-ak-ash4/294164_295801133770377_100000214798354_1387938_1085091131_n.jpg)
I could of picked them up today.. but I didn't read my email until now and it's too late![wwf](https://mbworld.org/forums/images/smilies/chairshot.gif)
![wall](https://mbworld.org/forums/images/smilies/banghead.gif)
So I'm picking them up tomorrow
and hopefully put them on if it fits fine without any spacers.
#6980
Thanks Frank ![Stick Out Tongue](https://mbworld.org/forums/images/smilies/tongue.gif)
Quick question guys. I'm in a dilemma right now. There were tires on it when it went in and since I can't use them I told them not to mount/balance it(cost $50 per wheel) or throw it away because it have about 80%+ thread left.
The thing is.. now i have to pick up the 4 wheels and the 4 tires. I don't want to wait for my brother to be available for his truck (which is thursday). I'm impatient and wanted to pick them up tomorrow with my w203. The question is .. can I just put the tires around the wheels like if i were mounting them by hand? (not actually mounting them) or would I need a machine to do that?
I'm just trying to save space so i can fit them all
#6982
They're HRE 563 with Stepped Lip in Clear Brushed.
They're 18x9 et 37 all around. I couldn't choose the offsets because it came from a messed up set of HRE 540.
#6985
#6986
you should be fine, 2 or 3 tires in the trunk, 1 or 2 upfront and 4 boxes in the back seat.. youre good. install and post up pics asap!
#6987
2007 C230 Sport 6spd
i dont think you'll be able to FIT 4 HRE boxes in the back.. for the year i worked @ Pioneer Porsche every time we ordered HRE wheels the boxes were pretty big. you will be able to filt the rims without the boxes tho
#6988
Hell yeah I couldn't haha! The boxes are huge but they're so nicely packed/fitted. Yeah if it didn't have the boxes I could of fit them, but hey who wouldn't want them neatly packed in boxes? Make you feel like it's christmas ![Stick Out Tongue](https://mbworld.org/forums/images/smilies/tongue.gif)
Now I need to make another trip back to pick up the tires so I can sell them! or trade them for tires that I can use.
I'll try to get them installed ASAP. Roland do you know a tire place that mount without messing up the lip? 714 tires or HMS? Do you know if HMS sells lug bolts too? So I won't have to order online.
#6994
C350 Coupe (CL203)
Damage is going to vary based on a number of things, obviously some are going to be stonger than others simply because of materials used or design.
Now for my question......
Does anyone know what spacers wold be considered the standard for these Brabus rims on my Coupe ?
http://www.alloywheelsdirect.net/mer..._vi_wheel_1591
using the following tyres...
Front: 235/40/18
Rear: 255/35/18
Front: 235/40/18
Rear: 255/35/18
#6995
MBworld Guru
white and whiter
i don't think you will need spacers for the 18" authentic Brabus. i could be wrong tho. If you do need spacers you can get the Brabus spacers that bolts to the wheel in 5mm, 10mm, 12mm, 15mm, and up.
#6996
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Pretty sure you'r right, Frank, at least from what I remember. It's been so long, researching Brabus rims is such a blur...LOL. That was 7 years ago that I researched on Brabus rims.
#6997
I have a question on finding the correct bolt I need. So basically I need to take my stock bolt and put it in the stock wheel and measure how far the bolt stick out? I do the same with the aftermarket wheel and measure how far the stock bolt stick out. I then subtract the difference from both bolts.
So let's say the bolt in the stock wheel sticks out 5mm more than the aftermarket wheeks. I would then need 45mm bolts right? But since I'm using 10mm spacers I would need 55mm shank and if i use 15mm spacer I would need 60mm shank?. These are for the fronts.
Would I have to take off the rears too and measure the difference? Or does the rear stock wheel bolts stick out the same as the front stock wheel bolt?
#6998
MBworld Guru
white and whiter
yes, pretty much. if it sticks out more you subtract it and then if you run spacers you add the thickness of the spacers.
front and rear should accept the same bolt length.
check out radusadirect.com for bolts.
#6999
So despite the stock wheels front and rears different offsets, how much the stock bolt sticks out it's the same length? That makes it less work for me :P because I only took out the fronts to measure haha.
Thanks Frank, just wanted to make sure because both spacers and lug bolts are non refundable
#7000
ok I am currently running this set up:
TSW Bremma's: I believe these are the correct offsets, I just got them online.
Front- 19x8.5 et 32 with a 10mm hubcentric spacer. Tires are 225/35 19 which rub barely on the inside on my coilover (KW), and barely on the outside of the fender when I hit a small dip. My KW coilovers are maxed out as low as they will go.
Rear- 19x9.5 et 35 with 265/30 19 tires and no rubbing issues whatsoever.
Question: Will these wheels fit? and if so any recommended tire sizes?
Front- 18x8.5 et 35 (not sure if I will need the spacer or not)
Rear- 18x9.5 et 35 (I do not see an issue as to why this wouldnt work perfectly)
The wheels are not hubcentric from what I have read, but I am not sure if that is a big deal. I have yet to see them on a w203 either. They are the Konig Milligram's. Here is a pic I got from D2 Autosport's ad...
![W203/CL203 Aftermarket Wheel Thread - All you want to know-milligram.jpg](https://mbworld.org/forums/attachments/c-class-w203/380972d1542321740t-w203-cl203-aftermarket-wheel-thread-all-you-want-know-milligram.jpg)
Thanks in advance for any help. I just am not sure where to add or subtract on the offset with the 10mm spacer up front or how to see if I'll still need it, etc.
