View Poll Results: Aftermarket Wheel Thread
W203
![](https://mbworld.org/forums/images/polls/bar2-l.gif)
![](https://mbworld.org/forums/images/polls/bar2.gif)
![](https://mbworld.org/forums/images/polls/bar2-r.gif)
![](https://mbworld.org/forums/clear.gif)
0
0%
CL203
![](https://mbworld.org/forums/images/polls/bar3-l.gif)
![](https://mbworld.org/forums/images/polls/bar3.gif)
![](https://mbworld.org/forums/images/polls/bar3-r.gif)
0
0%
Voters: 0. You may not vote on this poll
W203/CL203 Aftermarket Wheel Thread - All you want to know
#7677
#7678
06 C230 SS 6spd
my 18s ride better than the factory 17s. your tires also have a significant affect in the handling. what tires do you have and the specs. I'm running Conti DWS and couldnt be more pleased with them.
#7681
after market wheels for c240 16x7 wheels and tires
Are there after market wheels for c240 16x7 wheels and original tires if so what is the brand. I saw voxx
Voxx Wheels Legra Silver Wheel with Machined Face (16x7"/5x112mm)what about these???
#7682
Let's see who can help with this:
Gonna be running some 3-pc AMG Aero II's, need to run 20 mm spacers up front and 12 mm in the back. I can't seem to find any info about what type/size/seat bolts they take. If anyone can find out what I need to be running, I owe you big time.
#7683
06 C230 SS 6spd
are you referring to the Aero IIs like I use to have? They take a ballseat 39.9mm shank without spacers.
You're referring to these right?
![](http://img219.imageshack.us/img219/7443/dsc00490a9as.jpg)
heres what the OEM bolts use to look like because the bolt hole is so deep
![](http://a248.e.akamai.net/origin-cdn.volusion.com/abwf3.4vz39/v/vspfiles/photos/958-2.jpg?1352828700)
![](http://ezaccessory.com/v/vspfiles/photos/bolt_ball_958_draw.jpg)
#7684
#7687
you dont need to remove the calipers to put lug bolts on, on european cars they use lug bolts instead of lug nuts to hold the wheels in. so if you get 10mm spacers you'll have to buy lug bolts with a longer shaft to make up the difference. you'll have to add 10mm to the shaft length to the right length. Just measure your lug bolt shaft length and then add 10mm to it to get the length you need for it with spacers.
Got the spacer and everything is fine except...my thin wall splined deep socket ( gorilla impact grade) will not fit over the new 17mm hex bolt!!!! Any suggestions on where to purchase deep thin wall 17mm hex socket?
#7689
2007 C230 SS 6MT
#7690
w203 C230
Brada Wheels BR7
Hey guys, thought I would start sharing! @Phister although we have never talked, you and all the information you gave on mbworld have been a major part of getting to where we are on our Project W203... I just wanted to say thank you! On to the pictures....
![](https://fbcdn-sphotos-a-a.akamaihd.net/hphotos-ak-ash3/946997_174517009377163_1853910217_n.jpg)
![](https://fbcdn-sphotos-c-a.akamaihd.net/hphotos-ak-ash4/383429_174517019377162_4880750_n.jpg)
#7693
2006 C230 Sport
Hey all,
Been reading through and I've seen a lot of info and think I'll be just find but would love to confirm with you guys.
I have an 06 c230 sport (big calipers) and the wheels I want to run are Avantgarde m368 (maybe, not totally sold yet). They are 19x8.5 et35 in front and 19x9.5 et40 in rear with concave spokes. Hub bore is correct, and manufacturer has guaranteed fitment over the larger calipers. Only issue is I cannot run their center caps because of the c230's large grease caps. No biggie I'll source some / make my own.
I'm looking for a slightly flush fit, which is where I feel the +40 might be too low, but more importantly want to run 235/35/19 and 265/30/19 tires (Conti DWS'), which is where I think the offset might be ok. I'll be lowering her on KW Sport Comforts, and don't mind rolling the fenders , grinding the bumper tab if necessary. I want about a 1 finger gap, so def not slammed.
Phister or any of the knowledgeable gentlefolk on here know if this setup should be alright?
here's a link to the wheels if you'd like to see. Black barrel with gunmetal/ machined face.
http://avantgardewheels.com/m368.php
thanks in advance
James
thanks in advance
James
#7694
06 C230 SS 6spd
They should build the wheels to your specs. My team might be getting sponsored by them so I know they do custom setups. For fronts I'd go around +25 offset for close to flush. And rears around +30 or so. For tires I'd do 225/35/19 and 255/30/19 for a very light stretch to allow for a little more clearance.
#7695
2006 C230 Sport
Was just reading through some of your DIY threads and such, great write ups!
**edit, Just spoke to Scott over @ Avantgarde; unfortunately since these aren't part of their higher end lines of wheels, they don't offer custom offsets. Some 10mm spacers will sort everything out though, offset and center cap issues.
Off to search for which are lightest / strongest / best, not trying to add too much unsprung weight.
James
#7698
2006 C230 Sport
Neither actually! I made my screen name a long time before I even owned my benz. I'm looking into the Avantgarde M368 wheels. I had rpf1's on my s2000 so they were my favorite wheels back then.
#7699
2006 C230 Sport
#7700
