View Poll Results: Aftermarket Wheel Thread
W203
![](https://mbworld.org/forums/images/polls/bar2-l.gif)
![](https://mbworld.org/forums/images/polls/bar2.gif)
![](https://mbworld.org/forums/images/polls/bar2-r.gif)
![](https://mbworld.org/forums/clear.gif)
0
0%
CL203
![](https://mbworld.org/forums/images/polls/bar3-l.gif)
![](https://mbworld.org/forums/images/polls/bar3.gif)
![](https://mbworld.org/forums/images/polls/bar3-r.gif)
0
0%
Voters: 0. You may not vote on this poll
W203/CL203 Aftermarket Wheel Thread - All you want to know
#7726
W203 C200K (2001)
19" 8.5 front 9.5 back ?
Hey guys, i found a nice deal on a set of rims with tyres, but I don't think they'll fit, can someone let me know if this setup is possible ?? will install HR Lowering springs with that too.
Front: 8,5x19 ET36
Back: 9,5x19 ET46
I know the width is ok, i've seen lots of those fitments, it's the offset that worries me !, any thoughts ?, i'm ok with fender rolling, but i'm not sure if it's worth if it i'll have to do more than that !, I originally wanted 18" but who can say no to original AMGs ?![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
EDIT:
Forgot to tell you it's a '01 C200K, standard suspension/brakes !
Front: 8,5x19 ET36
Back: 9,5x19 ET46
EDIT:
Last edited by mostafaberg; 10-24-2013 at 07:55 AM. Reason: Forgot to add car specs
#7727
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
The offsets are wrong. You would have to use spacers to make them work which is not a great idea.
#7728
W203 C200K (2001)
I'm still planning to stick to the 8.5 and 9.5 setup, just not sure which offset should be the best ?
something that wouldn't require rolling would be ideal, but I'm ok if i'll need rolling !
Last edited by mostafaberg; 10-24-2013 at 08:50 AM. Reason: post wasn't well formatted. cleaned it up
#7729
Super Moderator
You need fronts in the ET 30/32 range & rears in the 35/37 range standard.
If you are happy to roll fenders you can go:
Front in the 25/30 range (front restriction is fouling the strut on the inside of the wheel/tyre)
Rear around 30.
Rear around 30.
#7731
hey im currently buyign rims for my w203 but im stuck on one thing. will they fit!!! 18x9+24
18x10+24
i dont mind the rears i plan on making the rears wider anyways but the front is the scary part!!
18x10+24
#7732
Super Moderator
The fronts will stick out & probably still foul the strut. You are going to have to do major bodywork to get 10" at ET24 into the rear wheel arch.
Unless you intend to widebody the car this setup is not practical.
#7734
Super Moderator
Thanks Phi ~ I'm sure that major rolling & pulling was required. Maybe you could give BenzoLenny clearance at the front strut dimple so that he can work back & whether you are stretching tyres or fitting standard for that rim size. I don't like stretching tyres as it runs the tyre outside it's design parameters but to each his own.
![](https://mbworld.org/forums/attachments/c-class-w203/142860d1225670461-staggered-wheel-set-up-4matic-all-you-want-know-wheel_offset.gif)
#7735
07 C230 (sold) 2009 E63 AMG (SOLD), 2015 E 63 AMG S
#7736
Hi Folks,
Got a chance to score some C36 AMG hammers, all 17x7.5, ET37, 66.6 centerbore, for my 4matic wagon. They're an old look but I've always loved them and have never seen them on a W203.
Will the centerbore work? Not sure what stock is...
Also, the calculator says they will be 12mm closer to the struts, is that enough clearance? My current wheels are stock 7-spoke, 16x7, ET31.
Thanks for the help!
#7737
Definitely wasn't easy but we were able to fit 19x9" with 225 and 19x10" with 245 tires on our 05 C230!
![](https://farm6.staticflickr.com/5550/10743970496_4bff332cd8_b.jpg)
#7739
Super Moderator
Note that this has been achieved by stretching smaller tyres than correct to fit the wheels & still achieve clearance.
#7740
Durty White 07 C230
^^^ I got your email brotha, that would be a good idea to take a vacation out here! the specs i was looking at was 18x9.5 R and 18x9 F. I'm still trying to figure out what would have the best stance on this vehicle. I came from subaru's where we put the same wheel size all the way around.
#7742
I bought Ronals AMG Style III -wheels. Front wheels are 8,5" ET 30 and rear wheels are 9,5" ET 33. Is there problems in front with 225/40/18 and rear with 255/35/18 Nankang tires ? I have H&R -40mm springs. My car is s203 -06 Avantgarde.
#7743
Anybody ? Am I ok with those offsets and any brand of tires with those sizes ?! My car is wagon model
#7745
Thx, TruTraig. Is there any change put other brand tires than Nangkang ? I mean Nankang is tight brand tire so can I put for examble Hankooks, Continental, Michelins etc. ? So is there space to put wideshoulder brand tires ?
#7746
06 C230 SS 6spd
I'm trying out some Hankook noble s2 for the rears right now to see how long they last.
#7748
Hey friends,
quick question here, Would these fit on my car? The offset and width seem to be okay but i'm not sure if these pups will clear my AMG brakes? I am aware i will most likely need to roll/pull fenders for these though.
http://www.stanceworks.com/forums/showthread.php?t=53680
17x9/10 +32/38 CCW LM20
I'm lowered on H&R Coilovers (front - less than finger space, rear - finger space)
thanks in advance !
** while i have your attention, What about these OZ Mitos?
http://www.stanceworks.com/forums/sh...ad.php?t=46316
Specs:
17x9 et44 with 2" lip
17x10 et44 with 2.5" lip
5x112
thanks in advance !
Specs:
5x112
#7749
06 C230 SS 6spd
Hey friends,
thanks in advance !
Specs:
5x112
thanks in advance !
Specs:
5x112
#7750
thanks for the help phister !
with the CCW you'll most likely need a 10mm spacer to clear the calipers. I have 18x9 + 25 when I ordered them thinking it'd clear but they way they machine the back of the face the calipers hit the spokes so I had to add a 10mm to clear my C32 calipers. I'd personally run 10mm spacers all around on the CCW LM20 to get a flush look.
