Removing Rear Seats
Old Mar 3, 2009 | 12:27 PM
Tangerine's Avatar
Is @ Home
Removing Rear Seats
Does anyone know how I go about removing the rear seats? My e-brake is having issues and I read that I should grease the links which are located below the rear seats.
Searched but nothing.
TIA
Old Mar 3, 2009 | 12:41 PM
Glyn M Ruck's Avatar
Super Moderator
Just pull the lower seat out - There is a central cover you need to remove for access to the brake mechanism which is under a felt silencing pad. Don't fiddle with the two round covers. They are the fuel pump & your two fuel sensors in the dual fuel tanks.
Old Mar 3, 2009 | 12:43 PM
shivi1345's Avatar
MK IV .:R32
how much weight does this save?
Old Mar 3, 2009 | 12:49 PM
Super Moderator
HA HA - not sure !!!
Old Mar 3, 2009 | 12:54 PM
BlackC280's Avatar
C280
Glyn, You seem to have all types of Diagrams, etc. on how to fix, remove, replace things on these cars! Each thread that asks how to change, remove, or fix things your always there with a diagram. At least since I joined this forum! Good Job! I'm impressed!
Old Mar 3, 2009 | 02:30 PM
Tangerine's Avatar
Is @ Home
Glyn is the man, valued asset. Thanks a lot, you are a lifesaver.
Old Mar 3, 2009 | 02:54 PM
Super Moderator
Thanks - It's a pleasure. I collect them from all over the place but many come from the forum - It's just that they are hell to find. I spent a long while reading before I joined. Many are provided by great & helpful members like splinter.
I just think a picture paints a thousand words.
Old Mar 3, 2009 | 03:26 PM
Super Moderator
Trouble is my filing system sucks - Ha! found it - here's the rest
Old Mar 3, 2009 | 04:32 PM
shivi1345's Avatar
MK IV .:R32
Tangerine......
lemme know how much those things weigh when you take em out plz lol
Old Mar 3, 2009 | 10:18 PM
BF_JC230's Avatar
2005 w203 C230
I have put whole bunch on here too regarding this...If I learned anything it is that the good Plastics Engineers got the cover wrong...It is ABS/PC and it should be PP...The snaps break on these covers! I bought four spares to have incase one fails...All four of mine OEM are cracked, but are still holding.
Good luck!
Easy job!
Jake
Old Mar 3, 2009 | 11:42 PM
bumpnzx3's Avatar
W203 C230SS
Originally Posted by shivi1345
Tangerine......
the seat bottom doesn't weight much of anything. you would be better off dropping a duece for weight savings/performance gain. the seat back doesn't weigh a lot either, but more than the bottom. just a wild guess- but i would say less than 25# total for both the back and bottom.
Old Mar 4, 2009 | 12:42 AM
appnano's Avatar
bmw
Originally Posted by Glyn M Ruck
Trouble is my filing system sucks - Ha! found it - here"s the rest
it looks not easy.
Old Mar 4, 2009 | 01:02 AM
Super Moderator
Good luck!
Easy job!
Jake
+1
Old Mar 4, 2009 | 01:06 AM
Super Moderator
Originally Posted by appnano
it looks not easy.
Nah - it's easy - friend of mine achieved it and he's a paraplegic with spanners.
Old Mar 4, 2009 | 03:26 PM
shivi1345's Avatar
MK IV .:R32
lol damn
those pics/diagrams look complicated too lol
Old Mar 4, 2009 | 03:34 PM
Super Moderator
lol damn
Mercedes execution is always a little more complex.
Old Mar 4, 2009 | 03:39 PM
BOY-6's Avatar
Mercedes-Benz c230 kompressor
i found a link
Pages 12 & 13 deal with the rear seat and then goes on to show the C pillar removal etc...
http://www.buellwinkle.com/Comand/CO...oval%20WIS.pdf
Old Mar 6, 2009 | 03:20 PM
Cintoman's Avatar
2005 C230WZ SS Capri Blue/Ash
Glyn, I too do the same thing, and save any DIY pics I find onto my computer. I find more of an amazement in the engineering that goes into our cars every time I see one of our cars taken apart. For instance, your second picture with the tan/grey interior and the seat bottom removed. Just check out the little access panels to get at everything. All nice and neat, and well placed. Our backseat passengers have no idea what they are sitting on.
With the few mods I've done on my car, I've always taken pictures to document my process/progress. Also to help me put things back together I've posted quite a few things here, which I hope has been helpful to some. Most of my pics show more of the "what's behind this" areas. Most recently....my follow up to e1000's rear view mirror light replacement. e1000 posted the DIY pics, then I followed up with the "hey...look-what's-actually-inside-our-rear-view-mirror" pics.
And...as mentioned above, Glyn, you're an amazing asset to this forum!
Cintoman
Old Mar 7, 2009 | 05:56 AM
Super Moderator
Yes - the Dual tank sensing & pump arrangement you are sitting on is pretty sophisticated. If it came from the big 3 it would have a cap, a fill pipe & a plastic tank with a cork float level sensor - not this.
https://mbworld.org/forums/attachmen...k-function.pdf
Some models have some of the electronics under the seat as well although mostly under the trunk floor.
Old Mar 7, 2009 | 11:20 PM
Cintoman's Avatar
Good luck!
Easy job!
Jake
Jake, are you talking about the 4 bolt covers you remove to expose the bolts to take out the rear seat? If so, yes, I agree...they do crack. When installing my illuminated sills, I removed the seat, and managed to crack 2 or 3 of these. They still surprisingly hold, so I never got around to buying replacements.
Cintoman
Old Mar 8, 2009 | 11:54 PM
alpinweiss's Avatar
2005 C230K Sport Sedan, 6 speed manual
BMW also uses a similar system on the 3-Series. The quasi-dual fuel tank set-up is supposed to more evenly balance the fuel weight from side to side. I am not sure if BMW or Mercedes had the design first.
The removable access plates under the back seat are a great design. You can remove/replace the fuel pump, sending unit, or screen easily. Most German cars have this feature. In comparison, many Detroit or Japanese brands will make you remove the fuel tank for this type of service.
Old Jan 19, 2024 | 08:42 AM
cybero's Avatar
W203
can you please explain how did you remove the 4 plastic covers?
Old Jan 19, 2024 | 10:31 PM
BF_JC230's Avatar
2005 w203 C230
Screwdriver in side between carpet and clip, twist and pop off. The inner clips will most likely break - you might be able to clip them back on - or replace.
