View Poll Results: MB & AMG wheels
AMG
0
0%
OEM MB
0
0%
Voters: 0. You may not vote on this poll
W203/CL203 OEM MB & AMG Wheel Thread - All you want to know
Old Mar 6, 2009 | 08:37 PM
  #276
ChrisBrown's Avatar
2005 C240 4MATIC, 2020 GLC300 4MATIC
Originally Posted by bbrain
last question, i hope..
what about these 17" wheels on my c240?
sry for alot of questions, but i want to be sure when i buy. thx alot
Mercedes made those for the C class - they fit on a few models.
Old Mar 12, 2009 | 01:50 PM
  #277
phatmitzu's Avatar
2005 E55
CLS wheels for $250
I just read through Trutaing's thread. The wheels looked nice on his car.
I have two rear ones for sale for cheap. So I want wondering if anyone here wants them?
https://mbworld.org/forums/wheels-ti...eap-250-a.html
Old Mar 14, 2009 | 12:52 AM
  #278
Grim001's Avatar
White 2005 C240
Rims from 2003 SL55 fit a 05 C240
I want to see if the rims from a sl55/sl500 will fit on my 05 C240. Here are the specs of the sl model rims:
front is 18 x 8.5 with 30 offset
rear is 18 x 9.5 with 33 offset
Old Mar 14, 2009 | 01:54 AM
  #279
Glyn M Ruck's Avatar
Super Moderator
They will fit perfectly as long as you don't have some strange brake set up, Excessive lowering, stick to reasonable tyre sizes & the specs are as you state above.
Old Mar 15, 2009 | 08:08 PM
  #280
Grim001's Avatar
White 2005 C240
I have a stock C240 so far, I plan on getting whatever makes it the same diameter as the stock system, so I don't have to worry about my speedometer being off,
Thanks for the info.
Anyone know what the stock offset is for my car? Want to see how different they will be from the the rim above
Old Mar 15, 2009 | 08:17 PM
  #281
Super Moderator
Just make sure you select back & front tyres that have a rolling circumference within a couple of percent of one another or the ESP will throw a fit.
Old Mar 19, 2009 | 01:28 AM
  #282
BerBer63's Avatar
2009 C63
18" C63 Wheels
Would they fit a 2006 C230? or what would be needed to make them work?
FRONTS: 18" X 8" ET 45 with Pirelli P-Zero 235/40/18
REARS: 18" X 9" ET 54 with Pirelli P-Zero 255/35/18
Old Mar 19, 2009 | 01:33 AM
  #283
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
not without spacers
Old Mar 19, 2009 | 01:34 AM
  #284
BerBer63's Avatar
2009 C63
What size spacers would make it work?
Old Mar 19, 2009 | 01:46 AM
  #285
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
15mm front and 10mm rear should do.
Old Mar 19, 2009 | 07:04 AM
  #286
91RS's Avatar
2016 Chevrolet SS, 2006 Cadillac STS-V
A 15mm in the front would bring the offset to 30mm correct? I didn't think that was enough to clear the larger brakes on the 2006s?
Old Mar 19, 2009 | 09:38 AM
  #287
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
it's an 8" with no lip.
Old Mar 19, 2009 | 06:14 PM
  #288
91RS's Avatar
Right, I didn't realize that. I think I was thinking of the 19" replicas on eBay, they are a little wider.
Old Mar 19, 2009 | 06:44 PM
  #289
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
i have the 19'' ebay replicas running 15mm fronts and 12mm rears. Its fine long as you get mercedes hubcentric spacers.
Old Mar 19, 2009 | 07:58 PM
  #290
Krytech's Avatar
2014 Ghibli S Q4 & 2008 C350
Any pics? Any problems with the replicas?
Old Mar 19, 2009 | 10:14 PM
  #291
TemjinX2's Avatar
no problems...they were designed for w204 offsets so i needed the spacers.
https://mbworld.org/forums/c-class-w...onda-meet.html
Old Mar 20, 2009 | 09:39 PM
  #292
Krytech's Avatar
Nice Looks like you guys had a good time.
Do you recall where you ordered them? These are the only ones I've seen on ebay recently but they're not true C63 replicas that I was looking for in a 19".
ebay link - These look different than yours though...
Old Mar 20, 2009 | 09:43 PM
  #293
TemjinX2's Avatar
http://www.lakeshorewheelandtire.com...cedes-19.shtml
just call and make sure they ship them out. there cheap but there customer service sux
  #294
91RS's Avatar
That same seller has them. http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem=
I would probably buy those if they were 18s. I wouldn't mind 19s, but the tires are just too much money for me.
Old Mar 21, 2009 | 05:40 PM
  #295
BossInTheGame's Avatar
Mercedes C320
would 15mm spacers in the front and 10mm in the rear also work for an 01 c320?
Old Mar 22, 2009 | 04:49 PM
  #296
c180 sonny's Avatar
C180 Kompressor Saloon
wheels - will they fit?
hiya im a newbie to the site and this is my first post.
if i could please ask a question as in if these wheels will fir my W203 2004 c180 komp saloon
here are the links
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=280323634599
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=130293987973
top ones are off an e-class and the other is off a CLS
i like these whees but unsure if they will will fit
thanks in advance
Old Mar 22, 2009 | 05:14 PM
  #297
BlackC280's Avatar
C280
as far as i'm concerned yes. Both wheels will fit. But wait for other more exp guys to chime in.
Old Mar 22, 2009 | 05:33 PM
  #298
HellsAngel's Avatar
03 c320 coupe
second 1 should fit,
1st one i didnt find the offset...
Old Mar 22, 2009 | 05:34 PM
  #299
c180 sonny's Avatar
what about tyre size?
Old Mar 22, 2009 | 06:48 PM
  #300
HellsAngel's Avatar
03 c320 coupe
they are used wheels with tires mounted on.. so you have no problem
